Rebuild target 'Target 1'
assembling STARTUP.A51...
compiling main.c...
main.c(118): warning C290: missing return value
main.c(148): warning C290: missing return value
linking...
BL51 BANKED LINKER/LOCATER V6.22 - SN: Eval Version
COPYRIGHT KEIL ELEKTRONIK GmbH 1987 - 2009
".\Objects\STARTUP.obj",
".\Objects\main.obj"
TO ".\Objects\qqqq"
PRINT(".\Listings\qqqq.m51")
* RESTRICTED VERSION WITH 0800H BYTE CODE SIZE LIMIT; USED: 184AH BYTE (303%) *
Program Size: data=126.0 xdata=0 code=6971
LINK/LOCATE RUN COMPLETE. 0 WARNING(S), 0 ERROR(S)
*** FATAL ERROR L250: CODE SIZE LIMIT IN RESTRICTED VERSION EXCEEDED
MODULE: E:\KEIL\C51\LIB\C51S.LIB (-----)
LIMIT: 0800H BYTES
Target not created.
Build Time Elapsed: 00:00:01
(27.8 KB, 下載次數: 36)
2017-5-4 21:56 上傳
看不懂,求講解
