QN8027 FM發(fā)射模塊的資料和程序源碼,還有QN8027開發(fā)資料
2017-4-1 22:37 上傳
2017-4-1 22:38 上傳
下載:
qn8006b1_sdk_driver_v1.00.rar
(474.06 KB, 下載次數(shù): 270)
2017-4-1 11:18 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
QN8027.zip
(1.9 MB, 下載次數(shù): 288)
2017-4-1 11:18 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
For C51
Before using this code:
- Make sure I2C address is matching datasheet
- If i2c driver existed, then just ignore qnio.c/h
- Modify QND_Deley(ms) to get accurate platform related miliseconds delay,
otherwise all chip's functionality may not working properly
- Detail please read related doc or get FAE's help
- #include "qndriver.h"
- extern UINT8 QND_ReadReg(UINT8 adr);
- extern UINT8 QND_WriteReg(UINT8 adr, UINT8 value);
- #define R_TXRX_MASK 0xd0
- UINT8 S_XDATA qnd_RSSIns = 255;
- UINT8 S_XDATA qnd_Crystal = QND_CRYSTAL_DEFAULT;
- UINT8 S_XDATA qnd_RSSIn[QND_BAND_NUM];
- UINT8 S_XDATA qnd_PrevMode;
- UINT8 S_XDATA qnd_Country = COUNTRY_CHINA ;
- UINT16 S_XDATA qnd_CH_START = 7600;
- UINT16 S_XDATA qnd_CH_STOP = 10800;
- UINT8 S_XDATA qnd_CH_STEP = 1;
- UINT8 qnd_ClearScanFlag = 0;
- UINT16 qnd_ClearChannel = 0;
- UINT8 qnd_FirstScan = 1;
- UINT8 S_XDATA qnd_AutoScanAll;
- UINT8 S_XDATA qnd_IsStereo;
- UINT8 S_XDATA qnd_ChCount;
- UINT16 S_XDATA qnd_RSSInBB[QND_BAND_NUM+1];
- UINT16 S_XDATA qnd_ChList[QN_CCA_MAX_CH];
- UINT8 S_XDATA qnd_StepTbl[3]={5,10,20};
- QND_SeekCallBack qnd_CallBackFunc = 0;
- void QNF_RXInit()
- Description: set to SNR based MPX control. Call this function before
- tune to one specific channel
- Parameters:
- None
- Return Value:
- None
- void QNF_RXInit()
- QNF_SetRegBit(77,0x80,0x80); // Set to High-Z
- QNF_SetRegBit(40,0x80,0x80); // Set SNR as criteria for MPX control
- QNF_SetRegBit(64,0x3f,SMSTART_VAL); //set SMSTART
- QNF_SetRegBit(66,0x3f,HCCSTART_VAL); //set HCCSTART
- QNF_SetRegBit(65,0x7f,SNCSTART_VAL); //set SNCSTART
- void QNF_SetMute(UINT8 On)
- Description: set register specified bit
- Parameters:
- On: 1: mute, 0: unmute
- Return Value:
- None
- if(On)
- QNF_SetRegBit(REG_PD2, 0x0c, 0x0c); // mute/unmute to avoid noise
- // QNF_SetRegBit(3, 0x80, 0x80); // mute/unmute to avoid noise
- else
- QND_Delay(QND_DELAY_BEFORE_UNMUTE);
- QNF_SetRegBit(REG_PD2, 0x0c, 0x00); // mute/unmute to avoid noise
- // QND_Delay(50);
- // QNF_SetRegBit(3, 0x80, 0x00); // mute/unmute to avoid noise
- void QNF_SetRegBit(UINT8 reg, UINT8 bitMask, UINT8 data_val)
- Parameters:
- reg: register that will be set
- bitMask: mask specified bit of register
- data_val: data will be set for specified bit
- Return Value:
- None
- UINT8 temp;
- temp = QND_ReadReg(reg);
- temp &= (UINT8)(~bitMask);
- temp |= data_val & bitMask;
- // temp |= data_val;
- QND_WriteReg(reg, temp);
- void QNF_InitRSSInBB()
- Description: init RSSI noise floor band
- Parameters:
- None
- Return Value:
- None
- UINT8 i,d2,d,step;
- UINT16 d1;
- // get frequency leap step
- step = qnd_StepTbl[qnd_CH_STEP];
- // total frequency span
- d1 = qnd_CH_STOP - qnd_CH_START;
- // make sure d2 value <= 255, normally QND_BAND_NUM should < 10
- d2 = step * QND_BAND_NUM;
- d = d1/d2;
- // first one should be CH_START
- qnd_RSSInBB[0] = qnd_CH_START;
- for(i=1; i<QND_BAND_NUM; i++) {
- qnd_RSSInBB[i] = qnd_RSSInBB[i-1] + d * step;
- // last one set one more step higher for convenience
- qnd_RSSInBB[i] = qnd_CH_STOP+step;
- UINT8 QNF_GetRSSInBandIndex(UINT16 chfreq)
- Description: get band index
- Parameters:
- chfreq: channel frequency (10Khz unit, eg: for 101.10Mhz, input 10110)
- Return Value: band index for input CH frequency
- UINT8 i;
- for(i=0; i<QND_BAND_NUM; i++) {
- if(chfreq < qnd_RSSInBB[i+1]) {
- // finally come to here, if no wrong input
- return i;
- UINT8 QNF_GetRSSIn(UINT16 chFreq)
- Description: get RSSI noise floor
- Parameters:
- Return Value:
- the RSSI noise floor
- UINT8 idx;
- idx = QNF_GetRSSInBandIndex(chFreq);
- return qnd_RSSIn[idx];
- UINT16 QNF_GetCh()
- Description: get current channel frequency
- Parameters:
- None
- Return Value:
- channel frequency
- UINT8 tCh;
- UINT8 tStep;
- UINT16 ch = 0;
- // set to reg: CH_STEP
- tStep = QND_ReadReg(CH_STEP);
- tStep &= CH_CH;
- ch = tStep ;
- tCh= QND_ReadReg(CH);
- ch = (ch<<8)+tCh;
- return CHREG2FREQ(ch);
- UINT8 QNF_SetCh(UINT16 freq)
- Description: set channel frequency
- Parameters:
- freq: channel frequency to be set
- Return Value:
- 1: success
- // calculate ch parameter used for register setting
- UINT8 tStep;
- UINT8 tCh;
- UINT16 f;
- f = FREQ2CHREG(freq);
- // set to reg: CH
- tCh = (UINT8) f;
- QND_WriteReg(CH, tCh);
- tStep &= ~CH_CH;
- tStep |= ((UINT8) (f >> 8) & CH_CH);
- QND_WriteReg(CH_STEP, tStep);
- return 1;
- void QNF_ConfigScan(UINT16 start,UINT16 stop, UINT8 step)
- Description: config start, stop, step register for FM/AM CCA or CCS
- Parameters:
- start
- Set the frequency (10kHz) where scan to be started,
- eg: 7600 for 76.00MHz.
- stop
- Set the frequency (10kHz) where scan to be stopped,
- eg: 10800 for 108.00MHz
- step
- 1: set leap step to (FM)100kHz / 10kHz(AM)
- 2: set leap step to (FM)200kHz / 1kHz(AM)
- 0: set leap step to (FM)50kHz / 9kHz(AM)
- Return Value:
- None
- UINT8 tStep = 0;
- UINT8 tS;
- UINT16 fStart;
- UINT16 fStop;
- fStart = FREQ2CHREG(start);
- fStop = FREQ2CHREG(stop);
- // set to reg: CH_START
- tS = (UINT8) fStart;
- QND_WriteReg(CH_START, tS);
- tStep |= ((UINT8) (fStart >> 6) & CH_CH_START);
- // set to reg: CH_STOP
- tS = (UINT8) fStop;
- QND_WriteReg(CH_STOP, tS);
- tStep |= ((UINT8) (fStop >> 4) & CH_CH_STOP);
- tStep |= step << 6;
- void QNF_SetAudioMono(UINT8 modemask, UINT8 mode)
- Description: Set audio output to mono.
- Parameters:
- modemask: mask register specified bit
- mode
- QND_RX_AUDIO_MONO: RX audio to mono
- QND_RX_AUDIO_STEREO: RX audio to stereo
- QND_TX_AUDIO_MONO: TX audio to mono
- QND_TX_AUDIO_STEREO: TX audio to stereo
- Return Value:
- None
- if (mode == QND_TX_AUDIO_MONO||mode == QND_RX_AUDIO_MONO)
- // set to 22.5K (22.5/0.69 ~= 32)
- QND_WriteReg(TX_FDEV, 0x20);
- else
- // back to default
- QND_WriteReg(TX_FDEV, 0x6c);
- QNF_SetRegBit(SYSTEM2,modemask, mode);
- void QNF_UpdateRSSIn(UINT16 chFreq)
- Description: update the qnd_RSSIns and qnd_RSSIn value
- Parameters:
- None
- Return Value:
- None
- UINT8 i,j;
- UINT8 r0;
- UINT16 ch;
- // backup SYSTEM1 register
- r0 = QND_ReadReg(SYSTEM1);
- if(!chFreq)
- for (i = 0 ; i < QND_BAND_NUM; i++)
- ch = QND_TXClearChannelScan(qnd_RSSInBB[i], qnd_RSSInBB[i+1]-qnd_StepTbl[qnd_CH_STEP], qnd_CH_STEP, 15);
- qnd_RSSIn[i] = QND_GetRSSI(ch);
- if (qnd_RSSIns > qnd_RSSIn[i])
- qnd_RSSIns = qnd_RSSIn[i];
- qnd_ClearChannel = ch;
- else
- i = QNF_GetRSSInBandIndex(chFreq);
- // restore SYSTEM1 register
- QND_WriteReg(SYSTEM1, r0);
- int QND_Delay()
- Description: Delay for some ms, to be customized according to user
- application platform
- Parameters:
- ms: ms counts
- Return Value:
- None
- void QND_Delay(UINT16 ms)
- UINT16 i,k;
- for(i=0; i<3000;i++)
- for(k=0; k<ms; k++)
- UINT8 QND_GetRSSI(UINT16 ch)
- Description: Get the RSSI value
- Parameters:
- Return Value:
- RSSI value of the channel setted
- UINT8 delayTime;
- QND_SetSysMode(QND_MODE_RX|QND_MODE_FM);
- delayTime = QND_READ_RSSI_DELAY;
- QNF_SetCh(ch);
- QNF_SetRegBit(SYSTEM1, CCA_CH_DIS, CCA_CH_DIS);
- QND_Delay(delayTime);
- return QND_ReadReg(RSSISIG);
- void QN_ChipInitialization()
- Description: chip first step initialization, called only by QND_Init()
- Parameters:
- None
- Return Value:
- None
- QND_WriteReg(0x01,0x89); //sw reset
- QND_WriteReg(0x50,0x00);
- QND_WriteReg(0x01,0x49); //recalibrate
- QND_WriteReg(0x01,0x09);
- QND_Delay(40); //wait more than 400ms
- QND_WriteReg(0x3C,0x89); //for RDS SYNC
- QNF_SetRegBit(0x49,0xc0, 0x00);
- QND_WriteReg(0x4a,0xba);
- QND_WriteReg(0x5c,0x05);
- QND_WriteReg(0x52,0x0c);
- QNF_SetRegBit(49,0x30,0x00); //minimize rxagc_timeout; WQF0717
- QND_WriteReg(0x38,0x2d); //for SNR CCA ccnclk2=2'b00
- QND_WriteReg(0x39,0x88); //for SNR CCA ccnclk1=2'b00
- QND_WriteReg(0x52,0x0c); //mute
- QND_WriteReg(0x00,0x81);
- QND_WriteReg(0x57,0x80);
- QND_WriteReg(0x57,0x00);
- QND_Delay(10); //wait more than 100ms
- QND_WriteReg(0x00,0x01);
- QND_WriteReg(0x52,0x00);
- QNF_SetRegBit(31,0x38,0x28); //WQF0717
- //WQF0717
- QND_WriteReg(HYSTERSIS, 0xff);
- QND_WriteReg(MPSTART, 0x12);
- QNF_SetRegBit(58,0xf,0xf);//set ccth11
- void QND_LoadDefalutSetting(UINT8 country)
- Description: load some defalut setting for a certain country
- Parameters:
- country :
- COUNTRY_CHINA: China
- COUNTRY_USA: USA
- COUNTRY_JAPAN: Japan (not supported yet)
- Return Value:
- None
- switch(country)
- case COUNTRY_CHINA:
- break;
- case COUNTRY_USA:
- QND_ConfigFMModule(QND_CONFIG_AUDIOPEAK_DEV,75);
- QND_ConfigFMModule(QND_CONFIG_PILOT_DEV,9);
- QND_ConfigFMModule(QND_CONFIG_RDS_DEV,2);
- QNF_SetRegBit(0x01,0x08,0x08);
- QNF_SetRegBit(0x04,0x3f,0x3f);
- QND_TXConfigAudio(QND_CONFIG_SOFTCLIP,1);
- break;
- case COUNTRY_JAPAN:
- break;
- default:
- break;
- int QND_Init()
- Description: Initialize device to make it ready to have all functionality ready for use.
- Parameters:
- None
- Return Value:
- 1: Device is ready to use.
- 0: Device is not ready to serve function.
- UINT8 QND_Init()
- QN_ChipInitialization();
- QNF_SetMute(1);
- QNF_InitRSSInBB(); // init band range
- QND_WriteReg(0x00, 0x01); //resume original status of chip /* 2008 06 13 */
- QNF_SetMute(0);
- return 1;
- void QND_SetSysMode(UINT16 mode)
- Description: Set device system mode(like: sleep ,wakeup etc)
- Parameters:
- mode: set the system mode , it will be set by some macro define usually:
- SLEEP (added prefix: QND_MODE_, same as below): set chip to sleep mode
- WAKEUP: wake up chip
- TX: set chip work on TX mode
- RX: set chip work on RX mode
- FM: set chip work on FM mode
- AM: set chip work on AM mode
- TX|FM: set chip work on FM,TX mode
- RX|AM; set chip work on AM,RX mode
- RX|FM: set chip work on FM,RX mode
- Return Value:
- None
- UINT8 val;
- switch(mode)
- case QND_MODE_SLEEP: //set sleep mode
- qnd_PrevMode = QND_ReadReg(SYSTEM1);
- QNF_SetRegBit(SYSTEM1, R_TXRX_MASK, STNBY);
- break;
- case QND_MODE_WAKEUP: //set wakeup mode
- QND_WriteReg(SYSTEM1, qnd_PrevMode);
- break;
- case QND_MODE_DEFAULT:
- QNF_SetRegBit(SYSTEM2,0x80,0x80);
- break;
- default:
- val = (UINT8)(mode >> 8);
- if (val)
- if(val == (QND_MODE_TX >> 8))
- QND_WriteReg(73, 0x44);
- else if(val == (QND_MODE_RX >> 8))
- QND_WriteReg(73, 0x04);
- // set to new mode if it's not same as old
- if((QND_ReadReg(SYSTEM1) & R_TXRX_MASK) != val)
- QNF_SetMute(1);
- QNF_SetRegBit(SYSTEM1, R_TXRX_MASK, val);
- // QNF_SetMute(0);
- // make sure it's working on analog output
- QNF_SetRegBit(SYSTEM1, 0x08, 0x00);
- break;
- void QND_TuneToCH(UINT16 ch)
- Description: Tune to the specific channel. call QND_SetSysMode() before
- call this function
- Parameters:
- ch
- Set the frequency (10kHz) to be tuned,
- eg: 101.30MHz will be set to 10130.
- Return Value:
- None
- UINT8 rssi;
- UINT8 minrssi;
- QNF_RXInit();
- // if chip working on TX mode, just set CH
- if(QND_ReadReg(SYSTEM1) & TXREQ)
- QNF_SetCh(ch);
- return;
- QNF_SetMute(1);
- if ((ch - 7710) % 240 == 0)
- QNF_SetRegBit(TXAGC_GAIN, IMR, IMR);
- else
- QNF_SetRegBit(TXAGC_GAIN, IMR, 0x00);
- QNF_SetCh(ch);
- //Free filter without RDS and Set filter 2 for Non-RDS
- QNF_SetRegBit(GAIN_SEL,0x38,(QND_ReadReg(SYSTEM2) & 0x20) ? 0x00 : 0x28);
- QNF_SetMute(0);
- void QND_SetCountry(UINT8 country)
- Description: Set start, stop, step for RX and TX based on different
- country
- Parameters:
- country:
- Set the chip used in specified country:
- CHINA:
- USA:
- JAPAN:
- Return Value:
- None
- qnd_Country = country;
- switch(country)
- qnd_CH_START = 7600;
- qnd_CH_STOP = 10800;
- qnd_CH_STEP = 1;
- break;
- case COUNTRY_USA:
- qnd_CH_START = 8810;
- qnd_CH_STOP = 10790;
- qnd_CH_STEP = 2;
- break;
- break;
- void QND_UpdateRSSIn(UINT16 ch)
- Description: in case of environment changed, we need to update RSSI noise floor
- Parameters:
- None
- Return Value:
- None
- UINT8 temp;
- UINT8 v_abs;
- if (qnd_FirstScan == 0 )
- temp = QND_GetRSSI(qnd_ClearChannel);
- if(temp > qnd_RSSIns)
- v_abs = temp - qnd_RSSIns;
- else
- v_abs = qnd_RSSIns - temp;
- if (v_abs< RSSINTHRESHOLD)
- qnd_ClearScanFlag = 0;
- else
- qnd_ClearScanFlag = 1;
- if (qnd_ClearScanFlag||qnd_FirstScan||ch)
- QNF_UpdateRSSIn(ch);
- qnd_FirstScan = 0;
- return;
- void QND_ConfigFMModule(UINT8 optiontype, UINT8 option)
- Description: Config the FM modulation setting
- country
- Parameters:
- optiontype:
- QND_CONFIG_AUDIOPEAK_DEV : audio peak deviation
- QND_CONFIG_PILOT_DEV: pilot deviation
- QND_CONFIG_RDS_DEV: rds deviation
- option:
- QND_CONFIG_AUDIOPEAK_DEV: 0~165khz
- QND_CONFIG_PILOT_DEV: 8~10
- QND_CONFIG_RDS_DEV: 1~7.5khz
- Return Value:
- None
- UINT8 tmp8;
- UINT16 tmp16;
- switch (optiontype)
- case QND_CONFIG_AUDIOPEAK_DEV:
- tmp16 = option*100;
- tmp8 = tmp16/69;
- QND_WriteReg(0x0e,tmp8);
- break;
- case QND_CONFIG_PILOT_DEV:
- tmp8 = option<<2;
- QNF_SetRegBit(0x0f,0x3c,tmp8);
- break;
- case QND_CONFIG_RDS_DEV:
- tmp8 = tmp16/35;
- QNF_SetRegBit(0x18,0x7f,tmp8);
- break;
- default:
- break;
- Description: set call back function which can be called between seeking
- channel
- Parameters:
- func : the function will be called between seeking
- Return Value:
- None
- void QND_SetSeekCallBack(QND_SeekCallBack func)
- qnd_CallBackFunc = func;
- UINT16 QND_RXSeekCH(UINT16 start, UINT16 stop, UINT16 step, UINT8 snr_th, UINT8 up);
- Description: Automatically scans the frequency range, and detects the
- first channel(AM or FM, it will be determine by the system mode which set
- by QND_SetSysMode).
- A threshold value needs to be passed in for channel detection.
- Parameters:
- start
- Set the frequency (10kHz) where scan will be started,
- eg: 76.00MHz will be set to 7600.
- stop
- Set the frequency (10kHz) where scan will be stopped,
- eg: 108.00MHz will be set to 10800.
- step
- FM:
- QND_FMSTEP_100KHZ: set leap step to 100kHz
- QND_FMSTEP_200KHZ: set leap step to 200kHz
- QND_FMSTEP_50KHZ: set leap step to 50kHz
- AM:
- QND_AMSTEP_***:
- snr_th:
- Set threshold for quality of channel to be searched.
- up:
- Set the seach direction :
- Up;0,seach from stop to start
- Up:1 seach from start to stop
- Return Value:
- The channel frequency (unit: 10kHz)
- -1: no channel found
- UINT16 QND_RXSeekCH(UINT16 start, UINT16 stop, UINT8 step, UINT8 db, UINT8 up)
- UINT8 regValue;
- UINT16 c, chfreq;
- UINT16 ifcnt;
- UINT8 savevalue;
- UINT8 rssi,mprssi;
- UINT8 scanFlag = 1;
- UINT8 stepvalue;
- UINT8 timeout = 0;
- UINT8 pilot_snr;
- UINT8 minrssi;
- if (qnd_AutoScanAll == 0)
- QNF_SetMute(1);
- QNF_SetRegBit(GAIN_SEL,0x38,0x38);
- QND_UpdateRSSIn(0);
- up=(start<stop) ? 1 : 0;
- stepvalue = qnd_StepTbl[step];
- do
- minrssi = QNF_GetRSSIn(start);
- QNF_SetCh(start);
- c = start;
- if ((c - 7710) % 240 == 0)
- else
- QNF_SetRegBit(TXAGC_GAIN, IMR, 0);
- QNF_SetRegBit(SYSTEM1,0xA1,0x81);
- QND_Delay(10); //10ms delay
- rssi = QND_ReadReg(RSSISIG); //read RSSI
- if (rssi > minrssi+6+db)
- QNF_ConfigScan(start, start, step);
- QNM_SetRxThreshold(minrssi-22+db);
- QNF_SetRegBit(SYSTEM1,0xA1,0xA0);
- timeout = 0;
- do
- QND_Delay(5);
- regValue = QND_ReadReg(SYSTEM1);
- timeout++;
- while((regValue &CHSC)&&timeout < 200);
- if (timeout < 200)
- regValue = QND_ReadReg(CCA5);
- ifcnt = regValue;
- regValue = QND_ReadReg(CCA4);
- ifcnt =(((ifcnt&0x1f)<<8)+regValue);
- if ((ifcnt < 2268) && (ifcnt > 1828))
- if (rssi > minrssi + 20 + db)
- scanFlag = 0;
- else
- QND_Delay(PILOT_READ_OUT_DELAY_TIME);
- pilot_snr = (QND_ReadReg(STATUS1) & 0x01) ? 0 : 1;
- if (pilot_snr)
- scanFlag = 0;
- else
- QND_Delay(PILOT_SNR_READ_OUT_DELAY_TIME);
- pilot_snr = QND_ReadReg(SNR);
- if (pilot_snr > 5 && pilot_snr < 55)
- scanFlag = 0;
- chfreq = start;
- if (scanFlag)
- start = chfreq + (up ? stepvalue : -stepvalue);
- if ((up && (stop < start)) || (!up && (start < stop)))
- scanFlag = 0;
- chfreq = 0;
- else
- if(qnd_CallBackFunc)
- qnd_CallBackFunc(chfreq, BAND_FM);
- while (scanFlag != 0);
- //Move the filter setting to TunetoChannel
- //QNF_SetRegBit(32,0x08,0x08);
- QND_TuneToCH((chfreq==0) ? stop: chfreq);
- //QND_LOG("=== Done QND_AutoScan_FMChannel_One ===");
- return chfreq;
- UINT8 QND_RXSeekCHAll(UINT16 start, UINT16 stop, UINT16 step, UINT8 db, UINT8 up)
- Description: Automatically scans the complete FM or AM band and detects
- all the available channels(AM or FM, it will be determine by
- the workmode which set by QND_SetSysmode). A threshold value
- needs to be passed in for the channel detection.
- Parameters:
- start
- stop
- Step
- FM:
- AM:
- QND_AMSTEP_***:
- db
- Set signal noise ratio for channel to be searched.
- up:
- Return Value:
- The channel count found by this function
- UINT8 QND_RXSeekCHAll(UINT16 start, UINT16 stop, UINT8 step, UINT8 db, UINT8 up)
- UINT16 prevCh = 0;
- //UINT16 chfreq;
- UINT8 stepvalue;
- UINT16 temp;
- UINT16 pStart = start;
- UINT16 pStop = stop > qnd_CH_STOP ? qnd_CH_STOP : stop;
- QNF_SetMute(1);
- qnd_AutoScanAll = 1;
- qnd_ChCount = 0;
- do
- temp = QND_RXSeekCH(pStart, pStop, step, db, up);
- if (temp)
- qnd_ChList[qnd_ChCount++] =temp;
- else
- temp = pStop;
- pStart = temp + (up ? stepvalue : -stepvalue);
- while((up ? (pStart<=pStop):(pStart>=pStop)) && (qnd_ChCount < QN_CCA_MAX_CH));
- QND_TuneToCH((qnd_ChCount >= 1)? qnd_ChList[0] : pStop);
- qnd_AutoScanAll = 0;
- QNF_SetMute(0);
- return qnd_ChCount;
- void QND_RXConfigAudio(UINT8 optiontype, UINT8 option )
- Description: config audio
- Parameters:
- optiontype: option
- QND_CONFIG_MUTE; ‘option’control muteable, 0:mutedisable,1:mute enable
- QND_CONFIG_MONO; ‘option’control mono, 0: QND_AUDIO_STEREO,1: QND_AUDIO_STEREO
- QND_CONFIG_EQUALIZER: 'option' control the EQUALIZER,0:disable EQUALIZER; 1: enable EQUALIZER;
- QND_CONFIG_VOLUME: 'option' control the volume gain,range : 0~83(0: -65db, 65: 0db, 83: +18db
- QND_CONFIG_BASS_QUALITY: 'option' set BASS quality factor,0: 1, 1: 1.25, 2: 1.5, 3: 2
- QND_CONFIG_BASS_FREQ: 'option' set BASS central frequency,0: 60Hz, 1: 70Hz, 2: 80Hz, 3: 100Hz
- QND_CONFIG_BASS_GAIN: 'option' set BASS control gain,range : 0x0~0x1e (00000 :-15db, 11110 :15db
- QND_CONFIG_MID_QUALITY: 'option' set MID quality factor,0 :1, 1 :2
- QND_CONFIG_MID_FREQ: 'option' set MID central frequency,0: 0.5KHz, 1: 1KHz, 2: 1.5KHz, 3: 2KHz
- QND_CONFIG_MID_GAIN: 'option' set MID control gain,range : 0x0~0x1e (00000 :-15db, 11110 :15db)
- QND_CONFIG_TREBLE_FREQ: 'option' set TREBLE central frequency,0: 10KHz, 1: 12.5KHz, 2: 15KHz, 3: 17.5KHz
- QND_CONFIG_TREBLE_GAIN: 'option' set TREBLE control gain,range : 0x0~0x1e (00000 :-15db, 11110 :15db
- Return Value:
- none
- switch(optiontype)
- case QND_CONFIG_MONO:
- if (option)
- QNF_SetAudioMono(RX_MONO_MASK, QND_RX_AUDIO_MONO);
- else
- QNF_SetAudioMono(RX_MONO_MASK, QND_RX_AUDIO_STEREO);
- break;
- case QND_CONFIG_MUTE:
- if (option)
- QNF_SetMute(1);
- else
- QNF_SetMute(0);
- break;
- default:
- break;
- UINT16 QND_TXClearChannelScan(UINT16 start, UINT16 stop, UINT16 step,UINT8 db)
- Description: Clean channel scan. Finds the best clear channel for transmission.
- Parameters:
- Start
- Stop
- Step
- QND_FSTEP_100KHZ: Set leap step to 100kHz.
- QND_FSTEP_200KHZ: Set leap step to 200kHz.
- QND_FSTEP_50KHZ: Set leap step to 50kHz.
- db
- Return Value:
- UINT16 QND_TXClearChannelScan(UINT16 start, UINT16 stop, UINT8 step,UINT8 db)
- UINT8 regValue;
- UINT16 chnFreq;
- QNF_ConfigScan(start, stop, step);
- QNF_SetRegBit(CCA, 0xe0, 0x20); // set TXCCAAqn
- QNF_SetRegBit(SYSTEM1, 0xe1, 0x60); // &0xfe |0x60
- do{
- QND_Delay(20);
- regValue =QND_ReadReg(SYSTEM1);
- }while(regValue&0x20);
- // suppose it's time to get right TX ch
- chnFreq = QNF_GetCh();
- QND_LOGB("BestChannel ",chnFreq);
- return chnFreq;
- UINT8 QND_TXSetPower( UINT8 gain)
- Description: Sets FM transmit power attenuation.
- Parameters:
- gain: The transmission power attenuation value, for example,
- setting the gain = 0x13, TX attenuation will be -6db
- look up table see below
- BIT[5:4]
- 00 0db
- 01 -6db
- 10 -12db
- 11 -18db
- BIT[3:0] unit: db
- 0000 124
- 0001 122.5
- 0010 121
- 0011 119.5
- 0100 118
- 0101 116.5
- 0110 115
- 0111 113.5
- 1000 112
- 1001 110.5
- 1010 109
- 1011 107.5
- 1100 106
- 1101 104.5
- 1110 103
- 1111 101.5
- for example:
- 0x2f, //111111 89.5
- 0x2e, //111110 91
- 0x2d, //111101 92.5
- 0x2c, //111100 94
- 0x1f, //111011 95.5
- 0x1e, //111010 97
- 0x1d, //111001 98.5
- 0x1c, //111000 100
- 0x0f, //001111 101.5
- 0x0e, //001110 103
- 0x0d, //001101 104.5
- 0x0c, //001100 106
- 0x0b, //001011 107.5
- 0x0a, //001010 109
- 0x09, //001001 110.5
- 0x08, //001000 112
- 0x07, //000111 113.5
- 0x06, //000110 115
- 0x05, //000101 116.5
- 0x04, //000100 118
- 0x03, //000011 119.5
- 0x02, //000010 121
- 0x01, //000001 122.5
- 0x00 //000000 124
- void QND_TXSetPower( UINT8 gain)
- UINT8 value = 0;
- value |= 0x40;
- value |= gain;
- QND_WriteReg(PAG_CAL, value);
- void QND_TXConfigAudio(UINT8 optiontype, UINT8 option )
- Description: Config the TX audio (eg: volume,mute,etc)
- Parameters:
- optiontype:option :
- QND_CONFIG_AUTOAGC:‘option'set auto AGC, 0:disable auto AGC,1:enable auto AGC.
- QND_CONFIG_SOFTCLIP;‘option’set softclip,0:disable soft clip, 1:enable softclip.
- QND_CONFIG_MONO;‘option’set mono,0: QND_AUDIO_STEREO, 1: QND_AUDIO_STEREO
- QND_CONFIG_AGCGAIN;‘option’set AGC gain, range:0000~1111
- Return Value:
- none
- if (option)
- QNF_SetAudioMono(0x10, QND_TX_AUDIO_MONO);
- else
- QNF_SetAudioMono(0x10, QND_TX_AUDIO_STEREO);
- break;
- if (option)
- QNF_SetRegBit(0x28, 0x18,0);
- else
- QNF_SetRegBit(0x28, 0x18,0x18);
- break;
- case QND_CONFIG_SOFTCLIP:
- if (option)
- QNF_SetRegBit(TXAGC_GAIN,0x80, 0x80);
- else
- QNF_SetRegBit(TXAGC_GAIN,0x80, 0x00);
- break;
- case QND_CONFIG_AUTOAGC:
- if (option)
- QNF_SetRegBit(TXAGC_GAIN,0x40,0);
- else
- QNF_SetRegBit(TXAGC_GAIN,0x41,0x41);
- break;
- case QND_CONFIG_AGCGAIN:
- QNF_SetRegBit(TXAGC_GAIN, 0x1f,option);
- break;
- default:
- break;
- UINT8 QND_RDSEnable(UINT8 mode)
- Description: Enable or disable chip to work with RDS related functions.
- Parameters:
- on: QND_RDS_ON: Enable chip to receive/transmit RDS data.
- QND_RDS_OFF: Disable chip to receive/transmit RDS data.
- Return Value:
- QND_SUCCESS: function executed
- UINT8 QND_RDSEnable(UINT8 on)
- UINT8 val;
- QND_LOG("=== QND_SetRDSMode === ");
- // get last setting
- val = QND_ReadReg(SYSTEM1);
- if (on == QND_RDS_ON)
- val |= RDSEN;
- // if RDS enabled, channel conditional filter is auto selected
- QNF_SetRegBit(GAIN_SEL,0x08,0x00);
- else if (on == QND_RDS_OFF)
- val &= ~RDSEN;
- // if RDS disabled, channel conditional filter is set to filter 2
- QNF_SetRegBit(GAIN_SEL,0x38,0x28);
- else
- return 0;
- QND_WriteReg(SYSTEM1, val);
- return 1;
- UINT8 QND_DetectRDSSignal(void)
- Description: detect the RDSS signal .
- Parameters:
- None
- Return Value:
- the value of STATUS3
- UINT8 QND_RDSDetectSignal(void)
- UINT8 val = QND_ReadReg(STATUS3);
- return val;
- void QND_RDSLoadData(UINT8 *rdsRawData, UINT8 upload)
- Description: Load (TX) or unload (RX) RDS data to on-chip RDS buffer.
- Before calling this function, always make sure to call the
- QND_RDSBufferReady function to check that the RDS is capable
- to load/unload RDS data.
- Parameters:
- rdsRawData :
- 8 bytes data buffer to load (on TX mode) or unload (on RXmode)
- to chip RDS buffer.
- Upload:
- 1-upload
- 0--download
- Return Value:
- QND_SUCCESS: rds data loaded to/from chip
- UINT8 i;
- UINT8 temp;
- if (upload)
- { //TX MODE
- for (i = 0; i <= 7; i++)
- QND_WriteReg(RDSD0 + i, rdsRawData[i]);
- else
- //RX MODE
- temp = QND_ReadReg(RDSD0 + i);
- rdsRawData[i] = temp;
- UINT8 QND_RDSCheckBufferReady(void)
- Description: Check chip RDS register buffer status before doing load/unload of
- RDS data.
- Parameters:
- None
- Return Value:
- QND_RDS_BUFFER_NOT_READY: RDS register buffer is not ready to use.
- QND_RDS_BUFFER_READY: RDS register buffer is ready to use. You can now
- load (for TX) or unload (for RX) data from/to RDS buffer
- UINT8 val;
- UINT8 rdsUpdated;
- rdsUpdated = QND_ReadReg(STATUS3);
- if (QND_ReadReg(SYSTEM1) & TXREQ)
- //TX MODE
- QND_WriteReg(SYSTEM2,QND_ReadReg(SYSTEM2)^RDSTXRDY);
- return QND_RDS_BUFFER_READY;
- do {
- val = QND_ReadReg(STATUS3)^rdsUpdated;
- }while(!(val&RDS_RXUPD)) ;
