查看: 5423|回復(fù): 4
SHT11溫濕度傳感器的單片機(jī)驅(qū)動(dòng)程序 有成品圖
ID:140725 發(fā)表于 2017-3-5 23:56 | 顯示全部樓層 |閱讀模式
SHT11是一個(gè)一體化的溫濕度傳感器.
下圖是SHT11溫度測(cè)量的結(jié)果:
下圖是SHT11濕度測(cè)量的結(jié)果:
SHT11測(cè)溫度的程序:
  1. #include<reg51.h>
  2. #include<intrins.h>
  3. #include<math.h>
  5. #define uint unsigned int
  6. sbit led1=P1^7;
  7. sbit led2=P1^6;
  8. sbit DATA=P1^1;
  9. sbit SCK=P1^0;
  10. #define noACK 0
  11. #define ACK 1 //adr command r/w
  12. #define STATUS_REG_W 0x06 //0000 0110
  13. #define STATUS_REG_R 0x07 //0000 0111
  14. #define MEASURE_TEMP 0x03 //0000 0011
  15. #define MEASURE_HUMI 0x05 //0000 0101
  16. #define RESET 0x1e        //0001 1110
  17. sbit dula=P2^6;
  18. sbit wela=P2^7;
  19. uchar code table[]={ 0x3f,0x06,0x5b,0x4f, 0x66,0x6d,0x7d,0x07, 0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};
  20. uchar code table_dian[]={ 0xbf,0x86,0xdb,0xcf, 0xe6,0xed,0xfd,0x87, 0xff,0xef,0xf7,0xfc,0xb9,0xd1,0xf9,0xf1};
  21. uchar error=0;
  22. void delayms(uint z)
  23. {
  24.         uint i,j;
  25.         for(i=z;i>0;i--)
  26.         for( j=110;j>0;j--);
  27. }
  28. //啟動(dòng)時(shí)序
  29. void transstart()
  30. {
  31.         SCK=1;
  32.         _nop_();
  33.         DATA=0;
  34.         _nop_();
  35.         SCK=0;
  36.         _nop_();
  37.         _nop_();
  38.         _nop_();
  39.         SCK=1;
  40.         _nop_();
  41.         DATA=1;
  42.         _nop_();
  43.         SCK=0;
  44. }
  45. //寫入命令子函數(shù)
  46. uchar write_byte(uchar value)
  47. {
  48.         uchar i;
  49.         for(i=0x80;i>0;i=i/2)
  50.         {
  51.                 if(i&value) DATA=1;
  52.                 else DATA=0;
  53.                 SCK=1;
  54.                 _nop_();
  55.                 _nop_();
  56.                 _nop_();
  57.                 SCK=0;
  58.         }
  59.         DATA=1;
  60.         SCK=1;
  61.         error=DATA;
  62.         SCK=0;
  63.         return error;
  64. }
  65. //從傳感器讀數(shù)據(jù)
  66. uchar read_byte(bit ack)
  67. {
  68.         uchar i,val=0;
  69.         DATA=1;
  70.         for(i=0x80;i>0;i=i/2)
  71.         {
  72.                 SCK=1;
  73.                 if(DATA) val=val|i;
  74.                 SCK=0;
  75.         }
  76.         DATA=!ack;
  77.         SCK=1;
  78.         _nop_();
  79.         _nop_();
  80.         _nop_();
  81.         SCK=0;
  82.         DATA=1;
  83.         return val;
  84. }
  85. //
  86. void connectionreset()
  87. {
  88.         uchar i;
  89.         DATA=1;
  90.         SCK=0;
  91.         for(i=0;i<9;i++)
  92.         {
  93.                 SCK=1;
  94.                 SCK=0;
  95.         }
  96.         transstart();
  97. }
  98. //測(cè)量函數(shù),溫度和濕度
  99. uint measure()
  100. {
  101.         uchar value_1,value_2;
  102.         uint tempvalue;
  103.         transstart();
  104.         error+=write_byte(MEASURE_TEMP);
  105.         if(error!=0) connectionreset();
  106.         else
  107.         {
  108.                 while(DATA==1)
  109.                 _nop_();
  110.                 if(DATA==0)
  111.                 {
  112.                         value_1=read_byte(ACK);
  113.                         value_2=read_byte(noACK);
  114.                         tempvalue=value_2+value_1*256;
  115.                 }
  116.                 //轉(zhuǎn)換成 16 位的 int 型
  117.                 else error=1;
  118.         }
  119.         return tempvalue;
  120. }
  121. //數(shù)碼管顯示函數(shù)
  122. void display(float dis_value)
  123. {
  124.         float value;
  125.         int qian,bai,shi,ge;
  126.         value=dis_value*100;
  127.         qian=(int)value/1000;
  128.         bai=(int)value%1000/100;
  129.         shi=(int)value%100/10;
  130.         ge=(int)value%10;
  131.
  132.         dula=1;
  133.         P0=table[qian];
  134.         dula=0;
  135.         P0=0xff;
  136.         wela=1;
  137.         P0=0xfe;
  138.         wela=0;
  139.         delayms(3);
  140.         dula=1;
  141.         P0=table_dian[bai];
  142.         dula=0;
  143.         P0=0xff;
  144.         wela=1;
  145.         P0=0xfd;
  146.         wela=0;
  147.         delayms(3);
  148.         dula=1;
  149.         P0=table[shi];
  150.         dula=0;
  151.         P0=0xff;
  152.         wela=1;
  153.         P0=0xfb;
  154.         wela=0;
  155.         delayms(3);
  156.         dula=1;
  157.         P0=table[ge];
  158.         dula=0;
  159.         P0=0xff;
  160.         wela=1;
  161.         P0=0xf7;
  162.         wela=0;
  163.         delayms(3);
  164.         wela=1;
  165.         P0=0xff;
  166.         wela=0;
  167. }
  168. //計(jì)算溫度值子函數(shù)
  169. float calc_temp(uint tempvalue)
  170. {
  171.         uchar i;
  172.         const float d1=-39.9;
  173.         const float d2=+0.01;
  174.         float temp_final;
  175.         tempvalue=tempvalue&0x3fff; //取出低 14 位
  176.         temp_final=d1+d2*((float)tempvalue);
  177.         for(i=100;i>0;i--)
  178.                 display(temp_final);
  179.         return temp_final;
  180. }
  181. //主函數(shù)
  182. void main()
  183. {
  184.         float dis_tempvalue;
  185.         uint tempvalue;
  186.         while(1)
  187.         {
  188.                 connectionreset();
  189.                 error=0;
  190.                 tempvalue=measure();
  191.                 if(error==0)
  192.                 {
  193.                         led1=0;
  194.                         delayms(200);
  195.                         led1=1;
  196.                         delayms(200);
  197.                         dis_tempvalue=calc_temp(tempvalue);
  198.                 }
  199.                 else
  200.                 {
  201.                         continue;
  202.                 }
  203.         }
  204. }
下載:
測(cè)濕度.rar (21.71 KB, 下載次數(shù): 52)
測(cè)溫度.rar (20.34 KB, 下載次數(shù): 29)
相關(guān)帖子
ID:168456 發(fā)表于 2017-3-6 09:30 | 顯示全部樓層
我這邊有飛思卡爾的,有人用嗎
ID:151348 發(fā)表于 2017-3-6 15:44 | 顯示全部樓層
綻放吧... 發(fā)表于 2017-3-6 09:30
我這邊有飛思卡爾的,有人用嗎
飛思卡爾的溫濕度傳感器?
ID:312978 發(fā)表于 2019-7-24 15:54 | 顯示全部樓層
謝謝!分享!
ID:312978 發(fā)表于 2019-7-25 14:52 | 顯示全部樓層
溫濕度傳感器?
