查看: 2597|回復: 0
雙色點陣沙漏圖形顯示源碼
ID:154175 發表于 2016-12-13 15:07 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
下載:
雙色點陣沙漏圖形顯示哦.zip (22.87 KB, 下載次數: 16)
  1.
  2. #include<reg52.h>    //包含頭文件,一般情況不需要改動,頭文件包含特殊功能寄存器的定義
  3. #include <intrins.h>
  4. //unsigned char  segout[8]={0,1,2,3,4,5,6,7}; //8列
  5. unsigned char  segout[8]={0x01,0x02,0x04,0x08,0x10,0x20,0x40,0x80}; //8列
  6. unsigned char code tab[]={//沙漏流動圖形表格
  7.
  8.                                         //        0x81,0xC3,0xA5,0xD9,0xF9,0xE7,0xC3,0x81,
  9.
  10.                                                 0xFF,0x7E,0x3C,0x18,0x18,0x24,0x42,0xFF,
  11.                                                 0xFF,0x76,0x3C,0x18,0x18,0x24,0x4A,0xFF,
  12.                                                 0xFF,0x66,0x3C,0x18,0x18,0x24,0x5A,0xFF,
  13.                                                 0xFF,0x46,0x3C,0x18,0x18,0x24,0x7A,0xFF,
  14.                                                 0xFF,0x42,0x3C,0x18,0x18,0x24,0x7E,0xFF,
  15.                                                 0xFF,0x42,0x34,0x18,0x18,0x2C,0x7E,0xFF,
  16.                                                 0xFF,0x42,0x24,0x18,0x18,0x3C,0x7E,0xFF,
  17.                                                 0x81,0xC3,0xA5,0x9B,0x9F,0xE7,0xC3,0x81
  18.                         };
  19. /*------------------------------------------------
  20.                 硬件端口定義
  21. ------------------------------------------------*/
  22. sbit LATCH = P1^0;
  23. sbit SRCLK= P1^1;
  24. sbit SER  = P1^2;
  25. sbit LATCH_B = P2^2;
  26. sbit SRCLK_B= P2^1;
  27. sbit SER_B= P2^0;
  28. /*------------------------------------------------
  29. uS延時函數,含有輸入參數 unsigned char t,無返回值
  30. unsigned char 是定義無符號字符變量,其值的范圍是
  31. 0~255 這里使用晶振12M,精確延時請使用匯編,大致延時
  32. 長度如下 T=tx2+5 uS
  33. ------------------------------------------------*/
  34. void DelayUs2x(unsigned char t)
  35. {
  36. while(--t);
  37. }
  38. /*------------------------------------------------
  39. mS延時函數,含有輸入參數 unsigned char t,無返回值
  40. unsigned char 是定義無符號字符變量,其值的范圍是
  41. 0~255 這里使用晶振12M,精確延時請使用匯編
  42. ------------------------------------------------*/
  43. void DelayMs(unsigned char t)
  44. {
  45.
  46. while(t--)
  47. {
  48.      //大致延時1mS
  49.      DelayUs2x(245);
  50.          DelayUs2x(245);
  51. }
  52. }
  53. /*------------------------------------------------
  54.                 發送字節程序
  55. ------------------------------------------------*/
  56. void SendByte(unsigned char dat)
  57. {
  58.   unsigned char i;
  59.
  60.    for(i=0;i<8;i++)
  61.         {
  62.          SRCLK=0;
  63.          SER=dat&0x80;
  64.          dat<<=1;
  65.          SRCLK=1;
  66.          }
  67.
  68. }
  69. /*------------------------------------------------
  70.                 發送雙字節程序
  71.      595級聯,n個595,就需要發送n字節后鎖存
  72. ------------------------------------------------*/
  73. void Send2Byte(unsigned char dat1,unsigned char dat2)
  74. {
  75.    SendByte(dat1);
  76.    SendByte(dat2);
  77. }
  78. /*------------------------------------------------
  79.                    595鎖存程序
  80.                   595級聯發送數據后,鎖存有效
  81. ------------------------------------------------*/
  82. void Out595(void)
  83. {
  84.         LATCH=0;
  85.         _nop_();
  86.         LATCH=1;
  87. }
  88. /*------------------------------------------------
  89.                 發送位碼字節程序
  90.                使用另外一片單獨595
  91. ------------------------------------------------*/
  92. void SendSeg(unsigned char dat)
  93. {
  94. unsigned char i;
  95.
  96.    for(i=0;i<8;i++)  //發送字節
  97.         {
  98.          SRCLK_B=0;
  99.          SER_B=dat&0x80;
  100.          dat<<=1;
  101.          SRCLK_B=1;
  102.          }
  103.       LATCH_B=0;    //鎖存
  104.       _nop_();
  105.       LATCH_B=1;
  106.
  107.
  108. }
  109. /*------------------------------------------------
  110.                    主程序
  111. ------------------------------------------------*/
  112. void main()
  113. {
  114. unsigned char i,j,k;
  115. while(1)
  116. {
  117.           for(j=0;j<8;j++)
  118.                     for(k=0;k<100;k++)//這個主要用于延時顯示動畫效果
  119.               for(i=0;i<8;i++) //8列顯示
  120.                   {
  121.
  122.                                         SendSeg(segout[i]);
  123.                                          Send2Byte(~tab[i+j*8],0xff);
  124.                                          Out595();
  125.                      DelayMs(1);
  126.                                          Send2Byte(0xff,0xff); //防止重影
  127.                                          Out595();
  128.                   }
  129.        //另外一種顏色
  130.                  for(j=0;j<8;j++)
  131.                     for(k=0;k<40;k++)//這個主要用于延時顯示動畫效果
  132.               for(i=0;i<8;i++) //8列顯示
  133.                   {
  134.
  135.                                         SendSeg(segout[i]);
  136.                                          Send2Byte(0xff,~tab[i+j*8]);
  137.                                          Out595();
  138.                      DelayMs(1);
  139.                                          Send2Byte(0xff,0xff); //防止重影
  140.                                          Out595();
  141.                   }
  142.                           for(j=0;j<8;j++)
  143.                     for(k=0;k<40;k++)//這個主要用于延時顯示動畫效果
  144.               for(i=0;i<8;i++) //8列顯示
  145.                   {
  146.
  147.                                         SendSeg(segout[i]);
  148.                                          Send2Byte(~tab[i+j*8],~tab[i+j*8]);
  149.                                          Out595();
  150.                      DelayMs(1);
  151.                                          Send2Byte(0xff,0xff); //防止重影
  152.                                          Out595();
  153.                   }
  154.         }
  155. }
