查看: 4262|回復: 2
LED模擬交通燈(帶左轉向)資料分享!(含仿真和程序)
ID:102056 發表于 2016-12-9 22:32 | 顯示全部樓層 |閱讀模式
源程序:
  1. #include <reg52.h>
  3. #define uint unsigned int
  4. sbit RED_A=P0^0;
  5. sbit YELLOW_A=P0^1;
  6. sbit GREEN_A=P0^2;
  7. sbit LEFT_A=P2^0;
  8. sbit RED_B=P0^3;
  9. sbit YELLOW_B=P0^4;
  10. sbit GREEN_B=P0^5;
  11. sbit LEFT_B=P2^1;
  12. uchar Flash_Count = 0;
  13. Operation_Type = 1;
  14. void DelayMS(uint x)
  15. {
  16.          uchar t;
  17.         while(x--)
  18.         {
  19.                  for(t=120;t>0;t--);
  20.         }
  21. }
  22. void Traffic_lignt()
  23. {
  24.          switch(Operation_Type)
  25.         {
  26.                  case 1:
  27.                         RED_A=1;YELLOW_A=1;GREEN_A=0;LEFT_A=1;
  28.                         RED_B=0;YELLOW_B=1;GREEN_B=1;LEFT_B=1;
  29.                         DelayMS(10000);
  30.                         Operation_Type = 2;
  31.                         break;
  32.                 case 2:
  33.             GREEN_A=1;
  34.                         DelayMS(300);
  35.                         YELLOW_A=~YELLOW_A;
  36.                         if(++Flash_Count !=10)
  37.                                 return;
  38.                         Flash_Count=0;
  39.                         Operation_Type = 3;
  40.                         break;
  41.                 case 3:
  42.                         RED_A=1;YELLOW_A=1;GREEN_A=1;LEFT_A=0;
  43.                 //        RED_B=0;YELLOW_B=1;GREEN_B=1;LEFT_B=1;
  44.                         DelayMS(4000);
  45.                         Operation_Type = 4;
  46.                         break;
  47.         case 4:
  48.                         LEFT_A=1;
  49.             DelayMS(300);
  50.                         YELLOW_A=~YELLOW_A;
  51.                         if(++Flash_Count !=10)
  52.                                 return;
  53.                         Flash_Count=0;
  54.                         Operation_Type = 5;
  55.                         break;
  56.         case 5:
  57.             RED_A=0;YELLOW_A=1;GREEN_A=1;LEFT_A=1;
  58.             RED_B=1;YELLOW_B=1;GREEN_B=0;LEFT_B=1;
  59.             DelayMS(10000);
  60.                         Operation_Type = 6;
  61.                         break;
  62.         case 6:
  63.                    GREEN_B=1;
  64.             DelayMS(300);
  65.                         YELLOW_B=~YELLOW_B;
  66.                         if(++Flash_Count !=10)
  67.                                 return;
  68.                         Flash_Count=0;
  69.             Operation_Type = 7;
  70.                         break;
  71.          case 7:
  72.          //  RED_A=0;YELLOW_A=1;GREEN_A=1;LEFT_A=1;
  73.            RED_B=1;YELLOW_B=1;GREEN_B=1;LEFT_B=0;
  74.            DelayMS(4000);
  75.            Operation_Type = 8;
  76.                    break;
  77.         case 8:
  78.             LEFT_B=1;
  79.            // RED_A=0;YELLOW_A=1;GREEN_A=1;LEFT_A=1;
  80.             DelayMS(300);
  81.                         YELLOW_B=~YELLOW_B;
  82.                         if(++Flash_Count !=10)
  83.                                 return;
  84.                         Flash_Count=0;
  85.             Operation_Type = 1;
  86.                         break;
  87.
  88.         }
  89. }
  90. void main()
  91. {
  92.          while(1)
  93.         {
  94.                  Traffic_lignt();
  95.         }
  96. }
資料下載:
LED模擬交通燈(帶左轉向).zip (70.12 KB, 下載次數: 41)
參與人數 1黑幣 +90 收起 理由
admin + 90 共享資料的黑幣獎勵!
ID:234609 發表于 2017-9-21 11:32 | 顯示全部樓層
感謝分享
ID:242290 發表于 2017-10-23 23:49 來自觸屏版 | 顯示全部樓層
可以私發一份給我嗎?沒有黑幣了,跪求
