查看: 4405|回復: 1
SM160128液晶模擬射擊游戲游戲仿真
模擬射擊游戲仿真沒問題,實物也做出來了
單片機程序源碼:
  1. #include<reg52.h>
  2. #include <intrins.h>
  3. #include <string.h>
  4. #include <stdlib.h>
  5. #include <stdio.h>
  6. #include <lcd_160128.h>
  7. extern uchar LCD_Initialise();
  8. extern uchar LCD_Write_Command(uchar cmd);
  9. extern uchar LCD_Write_Command_P1(uchar cmd,uchar paral);
  10. extern uchar LCD_Write_Command_P2(uchar cmd,uchar paral,uchar para2);
  11. extern uchar LCD_Write_Data(uchar dat);
  12. extern void Set_LCD_POS(uchar row,uchar col) reentrant;
  13. extern void Line(uchar x1,uchar y1,uchar x2,uchar y2,uchar Mode) reentrant;//以上在中斷中也有用到所以定義為可重入函數
  14. extern void Draw_Image(uchar *G_Buffer,uchar Start_Row,uchar Start_Col)reentrant;
  15. extern void Display_Str_at_xy(uchar x,uchar y,char *Buffer,uchar wb) reentrant;
  16. extern void cls();
  17. void Show_Score_and_Bullet() reentrant;
  18. sbit K1=P1^4;
  19. sbit K2=P1^5;
  20. sbit K3=P1^6;
  21. sbit K4=P1^7;
  22. sbit BEEP=P1^0;
  23. //開機界面繪制//
  24. code uchar const Game_Surface[]=
  25. {160,110,
  26. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  27. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  28. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  29. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0F,0xFC,0x00,
  30. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  31. 0x0E,0x1F,0xFC,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  32. 0x00,0x00,0x00,0x00,0x7F,0xDF,0xFC,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  33. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x7F,0xFF,0xFC,0x00,0x00,0x00,0x00,0x00,
  34. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x7F,0xFF,0xFC,0x00,
  35. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  36. 0x1F,0xFF,0xFC,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  37. 0x00,0x00,0x00,0x00,0x03,0xFF,0xFC,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  38. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x40,0x7F,0xFF,0x80,0x00,0x00,0x00,0x00,
  39. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x78,0xFF,0xFF,0xE0,
  40. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  41. 0x7F,0xFF,0xFF,0xFC,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  42. 0x00,0x00,0x00,0x00,0x7F,0xFF,0x7F,0xFF,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  43. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x7F,0xFE,0x7F,0xFF,0xF0,0x00,0x00,0x00,
  44. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x7F,0xFF,0xFC,0xFF,
  45. 0xFE,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  46. 0x0F,0xFF,0xFC,0x3F,0xFF,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  47. 0x00,0x00,0x00,0x00,0x01,0xFF,0xFC,0x07,0xFF,0xF8,0x00,0x00,0x00,0x00,0x00,0x00,
  48. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x3F,0xFF,0x80,0xFF,0xFF,0x00,0x00,
  49. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x07,0xFF,0xF0,
  50. 0x1F,0xFF,0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  51. 0x00,0x00,0xFF,0xFE,0x03,0xFF,0xF8,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  52. 0x00,0x00,0x00,0x00,0x00,0x00,0x1F,0xFF,0xC0,0x7F,0xFF,0x00,0x00,0x00,0x00,0x00,
  53. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x07,0xFF,0xF8,0x0F,0xFF,0xE0,
  54. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,
  55. 0xFF,0x01,0xFF,0xFC,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  56. 0x00,0x00,0x00,0x1F,0xFF,0xE0,0x3F,0xFF,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  57. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x03,0xFF,0xFC,0x0F,0xFF,0xF0,0x00,0x00,0x00,
  58. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x7F,0xFF,0x01,0xFF,
  59. 0xFE,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  60. 0x0F,0xFF,0xE0,0x3F,0xFF,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  61. 0x00,0x00,0x00,0x00,0x01,0xFF,0xFC,0x07,0xFF,0xF0,0x00,0x00,0x00,0x00,0x00,0x00,
  62. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x3F,0xFF,0x80,0xFF,0xFE,0x00,0x00,
  63. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x07,0xFF,0xF0,
  64. 0x1F,0xFF,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  65. 0x00,0x01,0xFF,0xFE,0x03,0xFF,0xF8,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  66. 0x00,0x00,0x00,0x00,0x00,0x00,0x3F,0xFF,0xC0,0x7F,0xFF,0x00,0x00,0x00,0x00,0x00,
  67. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x07,0xFF,0xF8,0x0F,0xFF,0xC0,
  68. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,
  69. 0xFE,0x03,0xFF,0xF8,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  70. 0x00,0x00,0x00,0x1F,0xFF,0xC0,0x7F,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  71. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x03,0xFF,0xF0,0x0F,0xFF,0xE0,0x00,0x00,0x00,
  72. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x7F,0xFE,0x01,0xFF,
  73. 0xFC,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  74. 0x0F,0xFF,0xC0,0x7F,0xFF,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  75. 0x00,0x00,0x00,0x00,0x03,0xFF,0xF8,0x0F,0xFF,0xF0,0x00,0x00,0x00,0x00,0x00,0x00,
  76. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x7F,0xFF,0x01,0xFF,0xFE,0x00,0x00,
  77. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0F,0xFF,0xE0,
  78. 0x3F,0xFF,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  79. 0x00,0x03,0xFF,0xFC,0x07,0xFF,0xF8,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  80. 0x00,0x00,0x00,0x00,0x00,0x00,0x7F,0xFF,0x83,0xFF,0xFF,0xFC,0x00,0x00,0x00,0x00,
  81. 0x00,0x00,0x7F,0xF0,0x00,0x00,0x00,0x00,0x00,0x00,0x0F,0xFF,0xE7,0xFF,0xFF,0xFF,
  82. 0x07,0x80,0x00,0x00,0x00,0x03,0xFF,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x01,0xFF,
  83. 0xFF,0xFF,0xFF,0xFF,0xCF,0xC0,0x00,0x00,0x00,0x07,0xFF,0xFF,0x80,0x00,0x00,0x00,
  84. 0x00,0x00,0x00,0x3F,0xFF,0xFF,0xFF,0xFF,0xFF,0xC0,0x00,0x00,0x00,0x1F,0xFF,0xFF,
  85. 0xE0,0x00,0x00,0x00,0x00,0x00,0x00,0x07,0xFF,0xFF,0xFF,0xFF,0xFF,0xE0,0x00,0x00,
  86. 0x00,0x3F,0xFF,0xFF,0xF0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0xFF,0xFE,0x03,0xFF,
  87. 0xFF,0xE0,0x00,0x00,0x00,0x7F,0xC0,0x07,0xF8,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  88. 0x3F,0xFF,0xC0,0x7F,0xFF,0xE0,0x00,0x00,0x00,0xFF,0x00,0x03,0xFC,0x00,0x00,0x00,
  89. 0x00,0x00,0x00,0x00,0x0F,0xFF,0xF8,0x0F,0xFF,0xF0,0x00,0x00,0x01,0xFC,0x00,0x00,
  90. 0xFE,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x1F,0xFF,0xFF,0x01,0xFF,0xFE,0x00,0x00,
  91. 0x01,0xF8,0x00,0x00,0x7E,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x1F,0x9F,0xFF,0xC0,
  92. 0x3F,0xFF,0x80,0x00,0x03,0xF0,0x00,0x00,0x3F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  93. 0x1F,0x03,0xFF,0xF8,0x0F,0xFF,0xF0,0x00,0x07,0xE0,0x00,0x00,0x1F,0x80,0x00,0x00,
  94. 0x00,0x00,0x00,0x00,0x3F,0x00,0x7F,0xFF,0x07,0xFF,0xFE,0x00,0x07,0xE0,0x00,0x00,
  95. 0x1F,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x3E,0x00,0x0F,0xFF,0xE7,0xFF,0xFE,0x00,
  96. 0x07,0xC0,0x00,0x00,0x0F,0x80,0x00,0x00,0x00,0x00,0x00,0x00,0x3E,0x00,0x01,0xFF,
  97. 0xFF,0xFF,0xFE,0x00,0x0F,0xC0,0x00,0x00,0x0F,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,
  98. 0x3E,0x00,0x00,0x7F,0xFF,0xFF,0xFE,0x00,0x0F,0x80,0x00,0x00,0x07,0xC0,0x00,0x00,
  99. 0x00,0x00,0x00,0x00,0x3E,0x00,0x00,0x0F,0xFF,0xFF,0x9E,0x00,0x0F,0x80,0x00,0x00,
  100. 0x07,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x3E,0x00,0x00,0x01,0xFF,0xFF,0x82,0x00,
  101. 0x0F,0x80,0x00,0x00,0x07,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x1E,0x00,0x00,0x00,
  102. 0x3F,0xFF,0xC0,0x00,0x1F,0x80,0x00,0x00,0x07,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,
  103. 0x1F,0x00,0x00,0x00,0x0F,0xFF,0xF0,0x00,0x0F,0x00,0x00,0x00,0x07,0xC0,0x00,0x00,
  104. 0x00,0x00,0x00,0x00,0x1F,0x80,0x00,0x00,0x1F,0xFF,0xFE,0x00,0x0F,0x80,0x00,0x00,
  105. 0x07,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x1F,0xC0,0x00,0x00,0x3F,0xFF,0xFE,0x00,
  106. 0x0F,0x80,0x00,0x00,0x07,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x0F,0xE0,0x00,0x00,
  107. 0x7F,0xFB,0xFE,0x00,0x0F,0x80,0x00,0x00,0x07,0xC0,0x03,0xFF,0xC0,0x00,0x00,0x00,
  108. 0x07,0xF8,0x00,0x01,0xFE,0xFF,0xFE,0x00,0x07,0x80,0x00,0x00,0x07,0x80,0x1F,0xFF,
  109. 0xF8,0x00,0x00,0x00,0x03,0xFE,0x00,0x07,0xFC,0xFF,0xFE,0x00,0x07,0xC0,0x00,0x00,
  110. 0x0F,0x80,0x3F,0xFF,0xFC,0x00,0x00,0x00,0x01,0xFF,0xFF,0xFF,0xF8,0xFF,0xFE,0x00,
  111. 0x07,0xE0,0x00,0x00,0x1F,0x80,0x7F,0xFF,0xFE,0x00,0x00,0x00,0x00,0xFF,0xFF,0xFF,
  112. 0xF0,0xFF,0xFE,0x00,0x07,0xE0,0x00,0x00,0x1F,0x80,0xFF,0xFF,0xFF,0x00,0x00,0x00,
  113. 0x00,0x3F,0xFF,0xFF,0xC0,0xFF,0xFE,0x00,0x03,0xF0,0x00,0x00,0x3F,0x01,0xFE,0x00,
  114. 0x7F,0x00,0x00,0x00,0x00,0x0F,0xFF,0xFF,0x00,0xFF,0xFF,0x00,0x01,0xF8,0x00,0x00,
  115. 0x7E,0x01,0xF8,0x00,0x1F,0x00,0x00,0x00,0x00,0x03,0xFF,0xF8,0x00,0xFF,0xFF,0x00,
  116. 0x01,0xFC,0x00,0x00,0xFE,0x01,0xF0,0x00,0x0F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  117. 0x00,0x7F,0xFF,0x80,0x00,0xFF,0x00,0x03,0xFC,0x01,0xF0,0x00,0x0F,0x00,0x00,0x00,
  118. 0x00,0x00,0x00,0x00,0x00,0x7F,0xFF,0xC0,0x00,0x7F,0xC0,0x07,0xF8,0x01,0xF8,0x00,
  119. 0x1F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x7F,0xFF,0xC0,0x00,0x3F,0xFF,0xFF,
  120. 0xF0,0x01,0xFE,0x00,0x7F,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x7F,0xFF,0xE0,
  121. 0x00,0x1F,0xFF,0xFF,0xE0,0x00,0xFF,0xFF,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  122. 0x00,0x7F,0xFF,0xE0,0x00,0x07,0xFF,0xFF,0x80,0x00,0x7F,0xFF,0xFE,0x00,0x00,0x00,
  123. 0x00,0x00,0x00,0x00,0x00,0x7F,0xFF,0xF0,0x00,0x03,0xFF,0xFF,0x00,0x00,0x3F,0xFF,
  124. 0xFC,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x7F,0xFF,0xF8,0x00,0x00,0x7F,0xF0,
  125. 0x00,0x00,0x1F,0xFF,0xF8,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x7F,0xFF,0xF8,
  126. 0x00,0x00,0x00,0x00,0x00,0x00,0x03,0xFF,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  127. 0x00,0x7F,0xFF,0xFC,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  128. 0x00,0x00,0x00,0x00,0x00,0x3F,0xFF,0xFC,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  129. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x1F,0xFF,0xFC,0x00,0x00,0x00,0x00,
  130. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x07,0xFF,0xFC,
  131. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  132. 0x00,0x01,0xFF,0xFC,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  133. 0x00,0x00,0x00,0x00,0x00,0x00,0x7F,0xFC,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  134. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x3F,0xFC,0x00,0x00,0x00,0x00,
  135. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x0F,0xF8,
  136. 0x00,0x00,0x00,0x00,0x00,0x00,0x20,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  137. 0x00,0x00,0x03,0xF8,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  138. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  139. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  140. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  141. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  142. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  143. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  144. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  145. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  146. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  147. 0x00,0x00,0x00,0x00,0x00,0x00,0x60,0x30,0x00,0x30,0x00,0x30,0xC1,0x80,0x20,0x30,
  148. 0x00,0x21,0x80,0x00,0x0C,0xC0,0x00,0x00,0x00,0x00,0x40,0x30,0x00,0x30,0x00,0x38,
  149. 0xC9,0x80,0x33,0xFF,0x06,0x31,0x80,0x00,0x0D,0xC0,0x00,0x00,0x00,0x01,0xFC,0x30,
  150. 0x07,0xFF,0x00,0x06,0xC9,0x80,0x63,0xFE,0x03,0x89,0xF8,0x0F,0xCE,0x00,0x00,0x00,
  151. 0x00,0x01,0xFB,0xF8,0x07,0xB0,0x00,0x00,0xC9,0x80,0x88,0x40,0x00,0x7E,0x80,0x18,
  152. 0xDF,0xE0,0x00,0x00,0x00,0x01,0x8F,0x3E,0x00,0x30,0x00,0xF8,0xC9,0x81,0xFB,0xF0,
  153. 0x08,0x35,0xF8,0x0C,0xBE,0x00,0x00,0x00,0x00,0x01,0xF9,0x30,0x3F,0xFF,0xF8,0xC8,
  154. 0xC9,0x81,0x25,0xB0,0x0F,0x3C,0x70,0x0F,0xAC,0xC0,0x00,0x00,0x00,0x07,0xF9,0xB0,
  155. 0x3C,0x33,0xF8,0x08,0xC9,0x80,0xCB,0xFE,0x00,0x24,0x60,0x03,0x8D,0x80,0x00,0x00,
  156. 0x00,0x07,0xB8,0xB0,0x02,0x31,0x30,0x18,0xC9,0x81,0xF3,0x30,0x00,0x6F,0xFE,0x03,
  157. 0x87,0x80,0x00,0x00,0x00,0x00,0xE8,0x30,0x02,0x30,0x80,0x1E,0xC9,0x80,0x01,0xB4,
  158. 0x07,0x48,0x20,0x0E,0x47,0x00,0x00,0x00,0x00,0x03,0x88,0x30,0x06,0x30,0x80,0x1D,
  159. 0xC9,0x80,0xFB,0xB3,0x0E,0xC8,0x20,0x3C,0x1F,0x80,0x00,0x00,0x00,0x0F,0x58,0x70,
  160. 0x07,0xFF,0x80,0x3B,0x89,0x83,0xC6,0x31,0xC1,0x98,0x60,0x10,0xFB,0xF8,0x00,0x00,
  161. 0x00,0x00,0x79,0xE0,0x07,0xFF,0xC0,0x37,0x09,0x82,0x19,0xF1,0x82,0x77,0xE0,0x00,
  162. 0x00,0xF8,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x80,0x00,0xE0,
  163. 0x00,0x00,0xC0,0x00,0x00,0x20,0x00,0x00
  164. };
  165. //槍支繪制//
  166. uchar code Gun_Image[]=
  167. {24,12,
  168. 0x03,0x00,0x00,0x07,0x80,0x00,0x07,0x80,0x00,0x7F,0xFE,0xFE,0xFE,0xFE,0xFE,0xFE,
  169. 0xFE,0xFC,0x7F,0xFE,0xFC,0x00,0x01,0xFC,0x00,0x01,0xFC,0x00,0x00,0x7F,0x00,0x00,
  170. 0x7F,0x00,0x00,0x1F
  171. };
  172. uchar tCount =0;
  173. uchar HCount,LCount;
  174. uchar Score =0; Bullet_Count = 20;
  175. uchar Target_x=0,Target_y=0;
  176. uchar Pre_Target_y = 0;
  177. uchar gun_y = 20;
  178. void delay(uint ms)
  179. {
  180.         uchar i;
  181.         while (--ms)for(i=0;i<120;i++);
  182. }
  183. void EX_INT0() interrupt 0
  184. {
  185.         if(K1==0)
  186.         {
  187.                 if(gun_y !=0)Display_Str_at_xy(16*8,gun_y,"  ",0);
  188.                 gun_y -=8;
  189.                 if(gun_y < 20)gun_y = 20;
  190.                 Draw_Image(Gun_Image,gun_y,16);
  191.         }
  192.         else
  193.         if(K2==0)
  194.         {
  195.                 if(gun_y !=0)         Display_Str_at_xy(16*8,gun_y,"   ",0);
  196.                 gun_y +=8;
  197.                 if(gun_y>100) gun_y = 100;
  198.                 Draw_Image(Gun_Image,gun_y,16);
  199.         }
  200.         else
  201.         if(K3==0)
  202.         {
  203.                 if(Bullet_Count !=0) TR1=1;else return;
  204. //彈道繪制//
  205.                 Line(10, gun_y +4,125,gun_y +4,1);
  206.                 delay(150);
  207.                 Line(10, gun_y +4,125,gun_y +4,0);
  208.                 if(Bullet_Count !=0)
  209.                 {
  210.                         Bullet_Count--;
  211.                         if((gun_y +4) >Target_y && (gun_y +4)<Target_y +11 &&Pre_Target_y !=Target_y)
  212.                         {
  213.                                 Score++; Pre_Target_y = Target_y;
  214.                         }
  215.                 }
  216.                 Show_Score_and_Bullet();
  217.         }
  218.         else
  219.         if(K4==0)
  220.         {
  221.                 Score = 0;Bullet_Count = 20;
  222.                 Show_Score_and_Bullet();
  223.         }
  224. }
  225. void T0_INT() interrupt 1
  226. {
  227.         TH0 = -50000/256;
  228.         TL0 = -50000%256;
  229.         if(++tCount !=70) return;
  230.         tCount = 0;
  231.         if(Target_x!=0 && Target_y!=0)
  232.         Display_Str_at_xy(Target_x,Target_y,"   ",0);
  233.         Target_x = rand() %60 +8;
  234.         Target_y = rand() %80+20;
  235.         while ( abs(Pre_Target_y - Target_y )< 4) Target_y =rand() % 80 + 20;
  236.         Display_Str_at_xy(Target_x,Target_y,"■",0);
  237. }
  238. void T1_INT () interrupt 3
  239. {
  240.         BEEP = ~BEEP;
  241.         if(LCount !=0 )
  242.         {
  243.                 TH1 =HCount;TL1 = --LCount;
  244.         }
  245.         else
  246.         if(--HCount !=0xFB)
  247.         {
  248.                 TH1 = HCount;TL1 = --LCount;
  249.         }
  250.         else
  251.         {
  252.                 TH1 = HCount = -420 / 256;
  253.                 TL1 = LCount = -420 % 256;
  254.                 BEEP = 1;
  255.                 TR1 = 0;
  256.         }
  257. }
  258. void Show_Score_and_Bullet()reentrant
  259. {
  260.         char dat_str[4] = {' ',0,0,0};
  261.         dat_str[1] = Score / 10+ '0';
  262.         dat_str[2] = Score % 10+ '0';
  263.         Display_Str_at_xy(37,117,dat_str,1);
  264.         dat_str[1] = Bullet_Count / 10+ '0';
  265.         dat_str[2] = Bullet_Count % 10+ '0';
  266.    Display_Str_at_xy(134,117,dat_str,1);
  267. }
  268. void main()
  269. {
  270.     RESET=0;
  271.         RESET=1;
  272.         LCD_Initialise();
  273.         cls();
  274.         Set_LCD_POS(0,0);
  275. //顯示游戲封面//
  276.         Draw_Image(Game_Surface,6,0);
  277.         delay(5000);
  278.         cls();
  279.         Display_Str_at_xy(12,1,"★★ 射擊訓練游戲 ★★",1);
  280.         Display_Str_at_xy(2,117,"得分",0);
  281.         Display_Str_at_xy(75,117,"剩余彈藥:",0);
  282.         Show_Score_and_Bullet();
  283.         Line (0,18,159,18,1);
  284.         Line (159,18,159,112,1);
  285.         Line (159,112,0,112,1);
  286.         Line (0,112,0,18,1);
  287.         Draw_Image(Gun_Image,gun_y,16);
  288.         IE = 0x8B;
  289.         IP = 0x01;
  290.         IT0 = 0x01;
  291.         TMOD = 0x11;
  292.         TH0 = -50000/256;
  293.         TL0 = -50000%256;
  294.         TH1 = HCount = -420/256;
  295.         TL1 = LCount = -420%256;
  296.         TR0 = 1;
  297.         while (1);
  298. }
單片機模擬射擊游戲所有資料打包下載:
SM160128液晶設計游戲仿真.zip (123.56 KB, 下載次數: 115)
參與人數 1黑幣 +100 收起 理由
admin + 100 共享資料的黑幣獎勵!
收藏收藏3 分享淘帖 頂1 踩
ID:304785 發表于 2023-4-19 20:27 | 只看該作者
請問實物的液晶選哪一款呢,160128不帶字庫就可以嗎
