查看: 3306|回復: 1
單片機多路故障報警系統proteus仿真及源程序
用51單片機做的多路故障報警系統的proteus仿真原理圖如下:
所有資料下載:
多路故障報警系統.rar (58.51 KB, 下載次數: 33)
單片機源程序:
  1.         #define SA1 InMap0
  2.         #define SA2 InMap1
  3.         #define SB1 InMap2
  4.         #define SB2 InMap3
  5.         #define Q0  OutMap0
  6.         #define Q1  OutMap1
  7.         #define Q2  OutMap2
  8.         #define T0  timer[0].DT
  9.         #define T1  timer[1].DT
  10.         void initi_timer()
  11.         {
  12.                 timer[0].K=2/0.05;
  13.                 timer[1].K=1/0.05;
  14.         }
  15.         void process()
  16.         {
  17.                   bit M0,M1;
  18.                  time(0,(SA1|SA2)&(~T1));
  19.                  time(1,T0);
  20.                  Q0=((T0|M0)&SA1)|SB2;
  21.                  Q1=((T0|M1)&SA2)|SB2;
  22.                  M0=(SB1|M0)&SA1;
  23.                  M1=(SB1|M1)&SA2;
  24.                  Q2=(SA1&(~M0))|(SA2&(~M1))|SB2;
  25.
  26.         }
  27.         M0 BIT 26H.0
  28.                          M1 BIT 26H.1
  29.                          SA1 BIT InMap0
  30.                          SA2 BIT InMap1
  31.                          SB1 BIT InMap2
  32.                          SB2 BIT InMap3
  33.                          Q0 BIT OutMap0
  34.                          Q1 BIT OutMap1
  35.                          Q2 BIT OutMap2
  36.
  37.         Initi_Timer:        MOV        K0_L,        #40
  38.                                  MOV        K0_H,        #0
  39.                                 MOV        K1_L,        #20
  40.                                  MOV        K1_H,        #0
  41.                                 RET
  42.
  43.         Process: MOV C,SA1
  44.                          ORL C,SA2
  45.                          ANL C,/DT1
  46.                          LCALL Tim0
  47.                          MOV C,DT0
  48.                          LCALL Tim1
  49.
  50.                          MOV C,DT0
  51.                          ORL C,M0
  52.                          ANL C,SA1
  53.                          ORL C,SB2
  54.                          MOV Q0,C
  55.
  56.                          MOV C,DT0
  57.                          ORL C,M1
  58.                          ANL C,SA2
  59.                          ORL C,SB2
  60.                          MOV Q1,C
  61.
  62.                          MOV C,SB1
  63.                          ORL C,M0
  64.                          ANL C,SA1
  65.                          MOV M0,C
  66.
  67.                          MOV C,SB1
  68.                          ORL C,M1
  69.                          ANL C,SA2
  70.                          MOV M1,C
  71.
  72.                          MOV C,SA1
  73.                          ANL C,/M0
  74.                          MOV 26H.2,C
  75.                          MOV C,SA2
  76.                          ANL C,/M1
  77.                          ORL C,26H.2
  78.                          ORL C,SB2
  79.                          MOV Q2,C
  80.
  81.                 RET
收藏收藏2 分享淘帖 頂 踩
ID:434044 發表于 2018-11-27 20:01 | 只看該作者
你好,有沒有C語言的源程序?
