查看: 3252|回復: 1
串口調(diào)試工具vb源碼
ID:142312 發(fā)表于 2016-10-11 13:40 | 顯示全部樓層 |閱讀模式
Private Sub ComMS_Click()
If ComMS.Caption = "打開串口" Then
ComMS.Caption = "關(guān)閉串口"
MSComm1.CommPort = Mid(Combo1.Text, 4)
    If MSComm1.PortOpen = False Then
        MSComm1.PortOpen = True
    Else
        MsgBox "串口已經(jīng)打開!"
        Exit Sub
    End If
Else
    If MSComm1.PortOpen = True Then
    End If
End If
'If MSComm1.PortOpen = True Then
'    Me.Caption = "串口已經(jīng)打開!"
'End If
End Sub
Private Sub ComTXA_Click()
'發(fā)送文本文件類
串口調(diào)試
串口調(diào)試
    '清空接收緩沖區(qū)
    MSComm1.InBufferCount = 0
    '發(fā)送數(shù)據(jù)幀
    MSComm1.Output = TextTXA.Text
End Sub
Private Sub ComTXN_Click()
'''''''''''''''''''''''''''發(fā)送多字節(jié)類
'定義變量
    Dim i As Byte
    Dim TXSum As Integer
    Dim TXBuff(0 To 8) As Byte
    Dim StrTX_Temp As String
    Dim StrData As String
TXSum = 0
For i = 0 To 7
    TXBuff(i) = Val("&H" & UCase(TextN(i))
     TXSum = TXSum + TXBuff(i)
Next i
    TXBuff(8) = TXSum Mod 256
'清空接收緩沖區(qū)
'發(fā)送數(shù)據(jù)幀
MSComm1.Output = TXBuff
End Sub
ID:298008 發(fā)表于 2020-5-4 07:47 | 顯示全部樓層
謝謝樓主分享!!
