51單片機自動打鈴器仿真電路原理圖(工程文件清晰版請下載本帖最后的附件),采用實時日歷時鐘芯片pcf8563提供準確的時鐘.
下面是51單片機自動打鈴器pcf8563芯片的驅動程序:- #include <AT89X52.h>
- #include <stdio.h>
- bit bclassFlg = 0;
- sbit FMQ = P3 ^ 7;
- unsigned char stringtemp[10]="";
- struct time
- unsigned char second;
- unsigned char minute;
- unsigned char hour;
- unsigned char day;
- unsigned char weekday;
- unsigned char month;
- unsigned int year;
- } time;
- sbit tim_sda=P2^6;
- sbit tim_scl=P2^7;
- sbit lcd16rs = P2^0;
- sbit lcd16rw = P2^1;
- sbit lcd16en = P2^2;
- unsigned char lcd16_1[16];
- unsigned char lcd16_2[16] = {"welcome"};
- bit tim_ack; // i2c slave ack.
- bit tim_err;
- unsigned char tim_rd_buffer[16];
- unsigned char tim_wr_buffer[16];
- /*****************11us延時函數*************************/
- void delay11us(unsigned char t)
- for (;t>0;t--);
- void delay(unsigned int x)
- unsigned int a,b;
- for(a=x;a>5;a--);
- for(b=10;b>0;b--);
- //寫指令
- void write_com(unsigned char com)
- P1=com;// 將指令值寫到數據線上
- lcd16rs=0;//寫指令
- lcd16en=0;//給一個LCD 使能脈沖
- delay(10);
- lcd16en=1;
- delay(10);
- lcd16en=0;
- //寫數據
- void write_date(unsigned char date)
- P1=date; //將數據寫到數據線上
- lcd16rs=1; //寫數據
- lcd16en=0; //給一個LCD 使能脈沖
- delay(10);
- lcd16en=1;
- delay(10);
- lcd16en=0;
- //初始化LCD
- void lcd_init()
- lcd16rw = 0;
- write_com(0x38);//顯示模式設置
- delay(20);
- write_com(0x0f);//開顯示,顯示光標、光標閃爍
- delay(20);
- write_com(0x06);//光標和顯示指針加一,屏幕不移動
- delay(20);
- write_com(0x01);//清顯示屏
- delay(20);
- //在第N行顯示第M個字
- void lcd16_n_line_n_byte(unsigned char n_line,unsigned char n_byte)
- unsigned char j;
- unsigned char com;
- unsigned char *dat1;
- unsigned char *dat2;
- dat1 = lcd16_1;
- dat2 = lcd16_2;
- if(n_line==0) //顯示第一行。
- for(j=0;j<n_byte;j++)
- com = 0x80+j;
- write_com(com);
- write_date(*dat1);
- dat1++;
- if(n_line==1) //顯示第二行。
- com = 0xc0+j;
- write_com(com);
- write_date(*dat2);
- dat2++;
- // i2c start.
- void PCF8563_start() //start flag is when tim_scl 1, tim_sdafrom 1 to 0.
- tim_sda = 1;
- delay11us(1);
- tim_scl = 1;
- delay11us(1);
- tim_sda = 0;
- delay11us(1);
- // i2c stop.
- void PCF8563_stop() //start flag is when tim_scl 1, tim_sdafrom 0 to 1.
- tim_sda = 0;
- delay11us(1);
- tim_scl = 1;
- delay11us(1);
- tim_sda = 0;
- //i2c slave respons.
- void PCF8563_respons()
- unsigned char i;
- tim_scl = 1;
- delay11us(1);
- while((tim_sda)&&(i<250)) i++;
- if(!tim_sda)
- tim_ack = 1;
- else
- tim_ack = 0;
- tim_scl = 0;
- delay11us(1);
- // i2c master respons.
- void PCF8563_master_respons(bit master_ack)
- tim_scl = 0;
- delay11us(1);
- tim_sda = ~master_ack;
- delay11us(1);
- tim_scl = 1;
- delay11us(1);
- tim_scl = 0;
- delay11us(1);
- //i2c init.
- void PCF8563_init()
- tim_sda = 1;
- delay11us(1);
- tim_scl = 1;
- delay11us(1);
- // i2c write n byte.
- void PCF8563_wr_byte(unsigned char dat)
- unsigned char i , temp;
- temp = dat;
- for(i=0;i<8;i++)
- tim_scl = 0;
- delay11us(1);
- if(temp&0x80)
- tim_sda = 1;
- else
- tim_sda = 0;
- temp = temp<<1;
- delay11us(1);
- tim_scl = 1;
- delay11us(1);
- tim_scl = 0;
- delay11us(1);
- tim_sda = 1;
- delay11us(1);
- unsigned char PCF8563_rd_byte()
- unsigned char i,k;
- tim_scl = 0;
- delay11us(1);
- tim_sda = 1;
- delay11us(1);
- for(i=0;i<8;i++)
- tim_scl = 1;
- delay11us(1);
- k = (k<<1)|tim_sda;
- tim_scl = 0;
- delay11us(1);
- return k;
- void PCF8563_write_n_byte(unsigned char add,unsigned char com,unsigned char *dat,unsigned char n_byte) //
- unsigned char i = 0;
- unsigned char temp;
- temp = *dat; // send to begin address to 'temp'.
- add = add<<1;
- add = 0xa0+add+0x00;
- PCF8563_start();
- PCF8563_wr_byte(add); //send EEPROM address, bit 0 = 0 is write.
- PCF8563_respons();
- if(!tim_ack) //if i2c respons.
- tim_err = 1;
- return;
- PCF8563_wr_byte(com); //send EEPROM beginning address.
- tim_err = 1;
- return;
- while(n_byte) //write n byte.
- PCF8563_wr_byte(temp);
- if(!tim_ack)
- tim_err = 1;
- PCF8563_stop();
- return;
- temp++;
- n_byte--;
- PCF8563_stop();
- void PCF8563_read_n_byte(unsigned char add,unsigned char com,unsigned char n_byte)
- unsigned char *temp;
- temp = tim_rd_buffer;
- add = add<<1;
- PCF8563_start();
- PCF8563_wr_byte(add); //send address + wr.
- PCF8563_wr_byte(com); // first byte address.
- add = add+0x01;
- PCF8563_start();
- PCF8563_wr_byte(add); //send address + rd.
- while(n_byte) // rd n byte .
- *temp = PCF8563_rd_byte();
- if(n_byte != 1) //if i2c respons.
- PCF8563_master_respons(1); //if the number is not the last one, master send a ack bit.
- temp++;
- n_byte--;
- PCF8563_stop();
- void PCF8563_wr_time()
- tim_wr_buffer[0] = 0x00; //second
- tim_wr_buffer[1] = 0x11; //minute
- tim_wr_buffer[2] = 0x22; //hour
- tim_wr_buffer[3] = 0x15; //day
- tim_wr_buffer[4] = 0x03; //weekday
- tim_wr_buffer[5] = 0x06; //month
- tim_wr_buffer[6] = 0x10; //year
- PCF8563_write_n_byte(1,2,tim_wr_buffer,8);
- //延時眼熟
- void DelayFM(unsigned int x)
- unsigned char t;
- while(x--)
- for(t=0;t<120;t++);
- //蜂鳴器驅動函數,參數為發聲聲調
- void FM(unsigned char x)
- unsigned char i;
- for(i=0;i<100;i++)
- FMQ = ~FMQ;
- DelayFM(x);
- FMQ = 0;
- void PCF8563_rd_time()
- PCF8563_read_n_byte(1,2,9);
- time.second = ((tim_rd_buffer[1]&0x70)>>4)*10 + (tim_rd_buffer[1]&0x0f); //second
- time.minute = ((tim_rd_buffer[2]&0x70)>>4)*10 + (tim_rd_buffer[2]&0x0f); //minute
- time.hour = ((tim_rd_buffer[3]&0x30)>>4)*10 + (tim_rd_buffer[3]&0x0f); //hour
- time.day = ((tim_rd_buffer[4]&0x30)>>4)*10 + (tim_rd_buffer[4]&0x0f); //day
- time.weekday = tim_rd_buffer[5]&0x07; //weekday
- time.month = ((tim_rd_buffer[6]&0x10)>>4)*10 + (tim_rd_buffer[6]&0x0f); //month
- if(time.second == 0)
- if(bclassFlg == 0 )
- sprintf(stringtemp,"%x%x",time.hour,time.minute);
- // printf("%s\n",stringtemp);
- printf("it's time to have class\n"); //上課
- bclassFlg = 1;
- FM(3);
- else if(time.second == 45) //如果到了45分鐘,開始下課鈴
- if(bclassFlg == 1)
- printf("it's time to finish class\n");
- bclassFlg = 0;
- FM(7);
- else
- temp = (tim_rd_buffer[4]&0x80)>>7;
- time.year = (temp+20)*100+((tim_rd_buffer[7]&0x70)>>4)*10 + (tim_rd_buffer[7]&0x0f); //year
- lcd16_1[0] = time.hour/10+0x30; //hour
- lcd16_1[1] = time.hour%10+0x30;
- lcd16_1[2] = '-';
- lcd16_1[3] = time.minute/10+0x30; //minute
- lcd16_1[4] = time.minute%10+0x30;
- lcd16_1[5] = '-';
- lcd16_1[6] = time.second/10+0x30; //second
- lcd16_1[7] = time.second%10+0x30;
- lcd16_2[0] = time.year/1000+0x30; //year
- lcd16_2[1] = (time.year%1000)/100+0x30;
- lcd16_2[2] = (time.year%100)/10+0x30;
- lcd16_2[3] = time.year%10+0x30;
- lcd16_2[4] = '-';
- lcd16_2[5] = time.month/10+0x30; //mon
- lcd16_2[6] = time.month%10+0x30;
- lcd16_2[7] = '-';
- lcd16_2[8] = time.day/10+0x30; //day
- lcd16_2[9] = time.day%10+0x30;
- lcd16_2[10] = 'w';
- lcd16_2[11] = 'e';
- lcd16_2[12] = 'e';
- lcd16_2[13] = 'k';
- lcd16_2[14] = ':';
- lcd16_2[15] = time.weekday+0x30;
- lcd16_n_line_n_byte(0,16);
- lcd16_n_line_n_byte(1,16);
- void DelayMS(unsigned int ms)
- unsigned char i;
- while(ms--)
- for(i=0;i<120;i++);
- void InitUart(void)
- SCON = 0x50; //工作方式1
- TMOD = 0x21;
- PCON = 0x00;
- TH1 = 0xfd; //使用T1作為波特率發生器
- TL1 = 0xfd;
- TI = 1;
- TR1 = 1; //啟動T1 //啟動T1
- void main()
- PCF8563_init();
- // PCF8563_wr_time();
- lcd_init();
- InitUart();
- while(1)
- PCF8563_rd_time();
- DelayMS(250);
51單片機pcf8563自動打鈴器仿真的所有資料下載:http://www.raoushi.com/bbs/dpj-54940-1.html
