查看: 17501|回復(fù): 35
GP2D12傳感器,來(lái)進(jìn)行激光,紅外線測(cè)距仿真 含單片機(jī)數(shù)模轉(zhuǎn)換程序
ID:262 發(fā)表于 2016-8-15 13:53 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
本帖最后由 heicad 于 2016-8-15 13:55 編輯
用GP2D12傳感器,來(lái)進(jìn)行激光,紅外線測(cè)距,用51單片機(jī),ADC0809進(jìn)行數(shù)模轉(zhuǎn)換
自己親手做的,親測(cè)可用.
附:PROTEUS仿真電路文件,KEIL C 語(yǔ)言源代碼,
  1. #include <reg52.h>
  2. #include <intrins.h> //包含NOP空指令函數(shù)_nop_
  3. #include<stdio.h>
  4. typedef unsigned char BYTE;
  5. typedef unsigned int WORD;
  6. typedef bit BOOL;
  7. #define uchar unsigned char
  8. #define uint  unsigned int
  9. sbit eoc=P3^0;
  10. sbit oe =P3^1;
  11. sbit st =P3^2;
  12. sbit clk=P3^6;
  13. sbit rs=P0^7;
  14. sbit rw=P0^6;
  15. sbit ep=P0^5;
  16. uchar code table[]="0123456789";
  17. uchar code tab[]={0x3F,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07,0x7F,0x6F,0x0,0x0};//數(shù)碼管共陰級(jí)顯示0~9
  18. uint ad_0809,a1,a2,a3;
  19. uchar out;
  20. void delaynms(uint x);
  21. void display();
  22. void ad0809();
  23. void delayms(uint x)
  24. {
  25.         uint i,j;
  26.         for(i=x;i>0;i--)
  27.                 for(j=110;j>0;j--);
  28. }
  29. void delay (int m)
  30. {
  31. unsigned char i,j;
  32. for (i=0;i<m;i++)
  33. for (j=0;j<253;j++);
  34. }
  35. BOOL lcd_bz()
  36. {
  37.   BOOL result;
  38.   rs=0;           // 讀忙信號(hào)
  39.   rw=1;
  40.   ep=1;
  41.   _nop_();
  42.   _nop_();
  43.   _nop_();
  44.   _nop_();
  45.   result = (BOOL)(P2&0x80);
  46.   ep=0;
  47.   result ;
  48. }
  49. lcd_wcmd (BYTE cmd)
  50. {
  51.   while (lcd_bz());
  52.   rs=0;
  53.   rw=0;
  54.   ep=0;
  55.   _nop_();
  56.   _nop_();
  57.   P2=cmd ;
  58.   _nop_();
  59.   _nop_();
  60.   _nop_();
  61.   _nop_();
  62.   ep=1;
  63.   _nop_();
  64.   _nop_();
  65.   _nop_();
  66.   _nop_();
  67.   ep=0;
  68. }
  69. lcd_pos (BYTE pos)
  70. {
  71.   lcd_wcmd (pos|0x80);
  72. }
  73. lcd_wdat (BYTE dat)
  74. {
  75.    while (lcd_bz());
  76.   rs=1;
  77.   rw=0;
  78.   ep=0;
  79.   _nop_();
  80.   _nop_();
  81.   P2=dat ;
  82.   _nop_();
  83.   _nop_();
  84.   _nop_();
  85.   _nop_();
  86.   ep=1;
  87.   _nop_();
  88.   _nop_();
  89.   _nop_();
  90.   _nop_();
  91.   ep=0;
  92. }
  93. lcd_init ()
  94. {
  95.   lcd_wcmd (0x38);
  96.   delay (1);
  97.   lcd_wcmd (0x0c);
  98.   delay (1);
  99.   lcd_wcmd (0x06);
  100.   delay (1);
  101.   lcd_wcmd (0x01);
  102.   delay (1);
  103. }
  104. void main()
  105. {
  106.   lcd_init ();
  107.   delay (10);
  108.
  109. TMOD=0X01;
  110. TH0=(65536-2)/256;
  111. TL0=(65536-2)%256;
  112. EA=1;
  113. ET0=1;
  114. TR0=1;
  115. while(1)
  116. {
  117.   ad0809();
  118.   ad_0809=out;
  119.   display();
  120.     lcd_pos (7);
  121.   lcd_wdat(table[a1]);
  122.    lcd_pos (8);
  123. lcd_wdat(table[a2]);
  124.     lcd_pos (9);
  125. lcd_wdat(table[a3]);
  126.   }
  127. }
  128. void T0_time()interrupt 1
  129. {
  130. TH0=(65536-2)/256;
  131. TL0=(65536-2)%256;
  132. clk=~clk;
  133. }
  134. void delaynms(uint x)
  135. {
  136. while(x-->0)
  137.
  138.         {
  139.           unsigned char k;
  140.           for(k=10;k>0;k--);
  141.         }
  142. }
  143. void display()
  144. {
  145.   a1=(ad_0809*49/25)/100;  //the highest bit
  146.   a2=(ad_0809*49/25)/10%10;
  147.   a3=(ad_0809*49/25)%100%10;
  148. }
  149. void ad0809()
  150. {
  151.   P1=0xff;//input
  152.   oe=0;
  153.   st=0;
  154.   st=1;//清0
  155.   st=0;//啟動(dòng)
  156.   delaynms(1);
  157.   while(!eoc);           //eoc等于零的話,在這里等待直到eoc=1,結(jié)束循環(huán),向下執(zhí)行
  158.   oe=1;
  159.   out=P1;
  160.   oe=0;
  161. }
adc0809 1602YL可用版01.zip
99.36 KB, 下載次數(shù): 368, 下載積分: 黑幣 -5
收藏收藏5 分享淘帖 頂3 踩
相關(guān)帖子
ID:154583 發(fā)表于 2016-12-14 08:54 | 只看該作者
很想要呀
ID:154736 發(fā)表于 2016-12-14 16:28 | 只看該作者
非常實(shí)用哦,謝謝
無(wú)效樓層,該帖已經(jīng)被刪除
5#
6#
ID:130231 發(fā)表于 2017-3-29 23:05 | 只看該作者
實(shí)用,感謝你的分享
8#
ID:184636 發(fā)表于 2017-3-30 11:48 | 只看該作者
大神,有問(wèn)題啊
10#
11#
ID:216338 發(fā)表于 2017-7-1 17:16 | 只看該作者
用紅外測(cè)會(huì)動(dòng)的小球怎么破?
ID:82765 發(fā)表于 2017-7-1 17:38 | 只看該作者
提示: 作者被禁止或刪除 內(nèi)容自動(dòng)屏蔽
ID:223290 發(fā)表于 2017-7-29 21:26 | 只看該作者
正好學(xué)習(xí)要用
ID:232569 發(fā)表于 2017-9-12 10:10 | 只看該作者
66666666666利害了
ID:232569 發(fā)表于 2017-9-12 10:11 | 只看該作者
厲害了我的歌 給個(gè)通過(guò)
ID:233124 發(fā)表于 2017-9-27 14:55 來(lái)自觸屏版 | 只看該作者
本帖最后由 duanxin 于 2017-9-27 19:24 編輯
可以加入報(bào)警模塊嗎?而且有警告,怎么修改呀,說(shuō)的什么邏輯沖突
18#
ID:197994 發(fā)表于 2018-4-22 20:35 | 只看該作者
可以加入報(bào)警模塊嗎?
20#
ID:334678 發(fā)表于 2018-5-23 16:58 | 只看該作者
Philoming 發(fā)表于 2018-4-22 20:35
你也是做激光防撞報(bào)警系統(tǒng)的畢設(shè)嘛,感覺(jué)和我想問(wèn)的一樣耶
ID:342159 發(fā)表于 2018-6-2 20:23 | 只看該作者
為什么資料里的adc0809和proteus里的不一樣
23#
ID:348688 發(fā)表于 2018-6-10 19:45 | 只看該作者
學(xué)校正在學(xué)習(xí)單片機(jī) 正好用的到 謝謝樓主分享
ID:388262 發(fā)表于 2018-8-20 19:17 | 只看該作者
謝謝 樓主 分享 樓主NB
ID:399840 發(fā)表于 2018-9-19 09:46 | 只看該作者
正需要,借鑒一下
27#
28#
ID:312858 發(fā)表于 2018-10-20 16:08 | 只看該作者
zqy181818 發(fā)表于 2017-3-29 23:05
實(shí)用,感謝你的分享
有32單片機(jī)的嗎
30#
ID:491840 發(fā)表于 2019-3-16 09:51 | 只看該作者
小白來(lái)學(xué)習(xí)學(xué)習(xí)了
32#
ID:427609 發(fā)表于 2019-4-10 00:49 | 只看該作者
謝謝分享謝謝分享
ID:503064 發(fā)表于 2019-4-11 14:22 來(lái)自觸屏版 | 只看該作者
謝謝樓主分享,樓主辛苦了
ID:525590 發(fā)表于 2019-5-1 15:22 | 只看該作者
非常感謝
ID:525729 發(fā)表于 2019-5-1 20:44 來(lái)自觸屏版 | 只看該作者
樓主,我怎么仿真不出數(shù)據(jù)啊?
37#
38#
ID:541448 發(fā)表于 2019-5-18 15:48 | 只看該作者
很實(shí)用呀
ID:578827 發(fā)表于 2019-7-7 11:03 | 只看該作者
三個(gè)測(cè)距的話是不是就可以直接三遍重復(fù)一下
ID:235332 發(fā)表于 2019-11-26 10:40 | 只看該作者
液晶顯示的數(shù)據(jù)和GP2D12的數(shù)據(jù)不一樣啊
