2016-6-7 15:50 上傳
該ISP編程器采用ATMEGA8_DIP28作為主控制芯片,預留MOSI,MISO,RET,SCK,VCC,GND。6PIN接口,方便使用者根據需要連接目標板。
同時預留PROGRAMMING編程接口,用戶可自行升級下載器固件。
ISP下載器電路原理圖截圖:
2016-6-7 15:50 上傳
ISP下載器源碼:
- USBasp - USB in-circuit programmer for Atmel AVR controllers
- Thomas Fischl <tfischl@gmx.de>
- License:
- The project is built with AVR USB driver by Objective Development, which is
- published under an own licence based on the GNU General Public License (GPL).
- USBasp is also distributed under this enhanced licence. See Documentation.
- Target.........: ATMega8 at 12 MHz
- Creation Date..: 2005-02-20
- Last change....: 2006-12-29
- PC2 SCK speed option. GND -> slow (8khz SCK),
- open -> fast (375kHz SCK)
- #include <avr/io.h>
- #include <avr/interrupt.h>
- #include <avr/pgmspace.h>
- #include <avr/wdt.h>
- #include "usbdrv.h"
- #include "isp.h"
- #include "clock.h"
- #define USBASP_FUNC_CONNECT 1
- #define USBASP_FUNC_DISCONNECT 2
- #define USBASP_FUNC_TRANSMIT 3
- #define USBASP_FUNC_READFLASH 4
- #define USBASP_FUNC_ENABLEPROG 5
- #define USBASP_FUNC_WRITEFLASH 6
- #define USBASP_FUNC_READEEPROM 7
- #define USBASP_FUNC_WRITEEEPROM 8
- #define PROG_STATE_IDLE 0
- #define PROG_STATE_WRITEFLASH 1
- #define PROG_STATE_READFLASH 2
- #define PROG_STATE_READEEPROM 3
- #define PROG_STATE_WRITEEEPROM 4
- #define PROG_BLOCKFLAG_FIRST 1
- #define PROG_BLOCKFLAG_LAST 2
- #define ledRedOn() PORTC &= ~(1 << PC1)
- #define ledRedOff() PORTC |= (1 << PC1)
- #define ledGreenOn() PORTC &= ~(1 << PC0)
- #define ledGreenOff() PORTC |= (1 << PC0)
- static uchar replyBuffer[8];
- static uchar prog_state = PROG_STATE_IDLE;
- static unsigned int prog_address;
- static unsigned int prog_nbytes = 0;
- static unsigned int prog_pagesize; //TP: Mega128 fix
- static uchar prog_blockflags;
- static uchar prog_pagecounter;
- uchar usbFunctionSetup(uchar data[8]) {
- uchar len = 0;
- if(data[1] == USBASP_FUNC_CONNECT){
- /* set SCK speed */
- if ((PINC & (1 << PC2)) == 0) {
- ispSetSCKOption(ISP_SCK_SLOW);
- } else {
- ispSetSCKOption(ISP_SCK_FAST);
- ispConnect();
- ledRedOn();
- } else if (data[1] == USBASP_FUNC_DISCONNECT) {
- ispDisconnect();
- ledRedOff();
- } else if (data[1] == USBASP_FUNC_TRANSMIT) {
- if(chip==ATM){
- replyBuffer[0] = ispTransmit(data[2]);
- replyBuffer[1] = ispTransmit(data[3]);
- replyBuffer[2] = ispTransmit(data[4]);
- replyBuffer[3] = ispTransmit(data[5]);
- }else{
- if(data[2]==0x24){
- switch(ispTransmit(data[5])&0x1C){
- case(0x00):replyBuffer[3]=0xE0;break;
- case(0x04):replyBuffer[3]=0xE5;break;
- case(0x0C):replyBuffer[3]=0xEE;break;
- case(0x1C):replyBuffer[3]=0xFF;break;
- else if(data[2]==0x30){
- replyBuffer[0] = ispTransmit(0x28);
- else{
- len = 4;
- } else if (data[1] == USBASP_FUNC_READFLASH) {
- prog_address = (data[3] << 8) | data[2];
- prog_nbytes = (data[7] << 8) | data[6];
- prog_state = PROG_STATE_READFLASH;
- len = 0xff; /* multiple in */
- } else if (data[1] == USBASP_FUNC_READEEPROM) {
- prog_state = PROG_STATE_READEEPROM;
- } else if (data[1] == USBASP_FUNC_ENABLEPROG) {
- replyBuffer[0] = ispEnterProgrammingMode();;
- len = 1;
- } else if (data[1] == USBASP_FUNC_WRITEFLASH) {
- prog_pagesize = data[4];
- prog_blockflags = data[5] & 0x0F;
- prog_pagesize += (((unsigned int)data[5] & 0xF0)<<4); //TP: Mega128 fix
- if (prog_blockflags & PROG_BLOCKFLAG_FIRST) {
- prog_pagecounter = prog_pagesize;
- prog_state = PROG_STATE_WRITEFLASH;
- len = 0xff; /* multiple out */
- } else if (data[1] == USBASP_FUNC_WRITEEEPROM) {
- prog_pagesize = 0;
- prog_blockflags = 0;
- prog_state = PROG_STATE_WRITEEEPROM;
- usbMsgPtr = replyBuffer;
- return len;
- uchar usbFunctionRead(uchar *data, uchar len) {
- uchar i;
- /* check if programmer is in correct read state */
- if ((prog_state != PROG_STATE_READFLASH) &&
- (prog_state != PROG_STATE_READEEPROM)) {
- return 0xff;
- /* fill packet */
- for (i = 0; i < len; i++) {
- if (prog_state == PROG_STATE_READFLASH) {
- data[i] = ispReadFlash(prog_address);
- } else {
- data[i] = ispReadEEPROM(prog_address);
- prog_address++;
- /* last packet? */
- if (len < 8) {
- prog_state = PROG_STATE_IDLE;
- return len;
- uchar usbFunctionWrite(uchar *data, uchar len) {
- uchar retVal = 0;
- uchar i;
- /* check if programmer is in correct write state */
- if ((prog_state != PROG_STATE_WRITEFLASH) &&
- (prog_state != PROG_STATE_WRITEEEPROM)) {
- return 0xff;
- if (prog_state == PROG_STATE_WRITEFLASH) {
- /* Flash */
- if (prog_pagesize == 0) {
- /* not paged */
- ispWriteFlash(prog_address, data[i], 1);
- } else {
- /* paged */
- ispWriteFlash(prog_address, data[i], 0);
- prog_pagecounter --;
- if (prog_pagecounter == 0) {
- ispFlushPage(prog_address, data[i]);
- } else {
- /* EEPROM */
- ispWriteEEPROM(prog_address, data[i]);
- prog_nbytes --;
- if (prog_nbytes == 0) {
- if ((prog_blockflags & PROG_BLOCKFLAG_LAST) &&
- (prog_pagecounter != prog_pagesize)) {
- /* last block and page flush pending, so flush it now */
- retVal = 1; // Need to return 1 when no more data is to be received
- prog_address ++;
- return retVal;
- int main(void)
- uchar i, j;
- PORTD = 0;
- PORTB = 0; /* no pullups on USB and ISP pins */
- DDRD = ~(1 << 2); /* all outputs except PD2 = INT0 */
- DDRB = ~0; /* output SE0 for USB reset */
- j = 0;
- while(--j){ /* USB Reset by device only required on Watchdog Reset */
- i = 0;
- while(--i); /* delay >10ms for USB reset */
- DDRB = 0; /* all USB and ISP pins inputs */
- DDRC = 0x03; /* all inputs except PC0, PC1 */
- PORTC = 0xfe;
- chip=ATM;
- clockInit(); /* init timer */
- usbInit();
- sei();
- for(;;){ /* main event loop */
- usbPoll();
- return 0;
復制代碼 全部資料(壓縮包)下載:
windows端驅動.zip
(32.27 KB, 下載次數: 16)
2016-6-7 15:53 上傳
下載積分: 黑幣 -5
固件和AVR單片機源碼.zip
(146.18 KB, 下載次數: 16)
2016-6-7 15:53 上傳
下載積分: 黑幣 -5
原理圖和PCB源文件.zip
(122.32 KB, 下載次數: 13)
2016-6-7 15:53 上傳
下載積分: 黑幣 -5
