//請根據自己馬達的控制 來改變程序
#include<reg52.h>
#include<math.h>
#include<intrins.h>
uchar Buffer =0; //從串口接收的數據
uint URTAReceivedCount=0,n=1;
uchar data Tempdatatable[5],CommandDatatable[5];//數據包
uchar serVal[2];
//uint pwm[]={1120,1190,1382,1382,1382,1382,1382,1382}; //初始90度,(實際是1382.4,取整得1382)
//uchar pwm_flag=0;
uint code ms0_5Con=461; //0.5ms計數 (實際是460.8,取整得461)
uint code ms2_5Con=2304; //2.5ms計數
bit key_stime_ok;
void Delay_1ms(uint i)//1ms延時
uchar x,j;
for(j=0;j
for(x=0;x<=148;x++);
void Send_Data(uchar type,uchar cmd,uchar dat)
uchar data Buffer[5];//構建數據包
uchar *p;
uint Send_Count=0;
p = Buffer;
Buffer[0]=0XFF;
Buffer[1]=type;
Buffer[2]=cmd;
Buffer[3]=dat;
Buffer[4]=0XFF;
if(*p==0XFF)
Send_Count++; //0XFF標志統計位
SBUF = *p; //發送
while(!TI) //如果發送完畢,硬件會置位TI,等待發送完畢
_nop_();
p++;
TI = 0;
if(Send_Count == 2) //當統計到兩次出現0XFF,則認為一個數據包發送完畢,跳出循環
TI = 0;
break;
void Com_Int(void) interrupt 4
uchar temp;
ES=0; //關串口中斷
RI=0; //軟件清除接收中斷
temp=SBUF;
if(temp==0XFF && URTAReceivedCount<3)
Tempdatatable[0]==0XFF; //包頭
URTAReceivedCount++;
Tempdatatable[n]=temp;
n++;
if(URTAReceivedCount==0&&n==2)
n=1;
if(URTAReceivedCount==2)//包尾
Tempdatatable[0]=0XFF;
Tempdatatable[4]=0XFF;
n=1;
URTAReceivedCount=0; //組包完畢
temp=" ";
// Send_Data(Tempdatatable[1],Tempdatatable[2],Tempdatatable[3]); //發送組成的數據包回去
CommandDatatable[0]=Tempdatatable[0];
CommandDatatable[1]=Tempdatatable[1];
CommandDatatable[2]=Tempdatatable[2];
CommandDatatable[3]=Tempdatatable[3];
CommandDatatable[4]=Tempdatatable[4];
ES=1;//開串口中斷
void Com_Init(void)
TMOD = 0x21;
PCON = 0x00;
SCON = 0x50;
TH1 = 0xFd; //設置波特率 9600
TL1 = 0xFd;
TR1 = 1; //啟動定時器1
ES = 1; //開串口中斷
EA = 1; //開總中斷
IT0=0;
EX0=1;
Delay_1ms(200);
Com_Init();//串口初始化
Timer0Init();//舵機PWM中斷初始化
if(CommandDatatable[0]==0XFF && CommandDatatable[4]==0XFF)
switch (CommandDatatable[1]) //根據鍵值不同,執行不同的內容
case 0X00: //類型位0X00,表明是控制數據包,進入控制數據case
switch(CommandDatatable[2]) //根據數據位的值來進行選擇執行不同的動作
case 0X00:Moto_Stop();break;
case 0X01:Moto_Forward();break;
case 0X02:Moto_Backward();break;
case 0X03:Moto_TurnLeft();break;
case 0X04:Moto_TurnRight();break;
case 0X05:Moto_ForLeft();break;
case 0X06:Moto_ForRight();break;
case 0X07:Moto_BackLeft();break;
case 0X08:Moto_BackRight();break;
default : break;
break;
default : break;
