/************漢字點(diǎn)陣*************/
uchar code hanzi[4][32] =
{ //一個(gè)漢字分兩行,所以數(shù)組二維數(shù)為字?jǐn)?shù)的兩倍
{0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x00,0xFF,0xFF,0x01,0x02,0x01,0x84,0x05,0x48,
0x09,0x20,0x11,0x10,0x21,0x08,0x41,0x04,0x01,0x04,0x01,0x02,0x01,0x02,0x00,0x00},/*"長",0*/
{0x08,0x20,0x06,0x20,0x40,0x3E,0x30,0xC0,0x03,0x04,0x20,0x04,0x20,0x04,0x20,0x04,
0x20,0x04,0x3F,0xFC,0x20,0x04,0x20,0x04,0x20,0x04,0x20,0x04,0x00,0x04,0x00,0x00},/*"江",1*/
/*"江",1*/
{0x04,0x01,0x04,0x01,0x04,0x02,0x04,0x04,0x04,0x08,0x04,0x30,0x04,0xC0,0xFF,0x00,
0x04,0xC0,0x04,0x30,0x04,0x08,0x04,0x04,0x04,0x02,0x04,0x01,0x04,0x01,0x00,0x00},/*"大",0*/
{0x02,0x20,0x0C,0x20,0x88,0x20,0x69,0x20,0x09,0x20,0x09,0x22,0x89,0x21,0x69,0x7E,
0x09,0x60,0x09,0xA0,0x19,0x20,0x28,0x20,0xC8,0x20,0x0A,0x20,0x0C,0x20,0x00,0x00},/*"學(xué)",1*/
/************位定義**************/
sbit STTP = P2^7;
/************變量聲明***********/
uint n,i,j; //delay()延時(shí)函數(shù)計(jì)數(shù)變量
uint x,y,z; //out_hanzi()
/************函數(shù)聲明***********/
void delay(uint n); //延時(shí)函數(shù)
void out_rxd(uchar *d); //漢字輸出
/************主函數(shù)**************/
SCON = 0x00;
P1 = 0;
for( x = 0; x < 32; x+=2)
STTP = 0;
out_rxd(&hanzi[3][x+1]);
out_rxd(&hanzi[3][x]);
out_rxd(&hanzi[2][x+1]);
out_rxd(&hanzi[2][x]);
out_rxd(&hanzi[1][x+1]);
out_rxd(&hanzi[1][x]);
out_rxd(&hanzi[0][x+1]);
out_rxd(&hanzi[0][x]);
STTP = 1;
P1 = x/2;
/************子函數(shù)定義?********/
void delay(uint n)
for( ; n > 0 ; n--)
for( j = 0; j < 10; j++)
SBUF = *d; //啟動(dòng)串行口傳送
while(TI == 0); //等待串口傳送結(jié)束
TI = 0; //將串口中斷標(biāo)志位置0
