查看: 1924|回復: 0
鍵盤掃描源程序
ID:113278 發表于 2016-4-10 14:53 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include<reg51.h> //51系列單片機頭文件
sbit dula=p2^6;
sbit wela=p2^7;
uchar i=100;
uchar temp,key;
/***************延時函數**************/
void delay(unsigend char i){
          uint j,k;
                for(j=i;j>0;j--)
                for(k=125;k>0;k--);
uchar code table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,
        0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};
/***************主函數****************/
void main(){
                dula=0;
                wela=0;
    while(1){
                p3=0xfe;
                temp=p3;
                temp=temp&0xf0;
                if(temp!=0xf0){
                        delay(10);  //延時消抖
                        if(temp!=0xf0){
                                temp=p3;
                                switch(temp){
                                        case 0xee:key=0;break;
                                        case 0xde:key=0;break;
                                        case 0xbe:key=0;break;
                                        case 0x7e:key=0;break;
                                        while(temp!=0xf0){    //按鍵釋放確認
                                                 temp=p3;
                                                 temp=temp&0xf0;
                                        display(key);
                        p3=0xfd;
                        temp=p3;
                        temp=temp&0xf0;
                        if(temp!=0xf0){
                                   delay(10);
                        if(temp!=0xf0){
                                        temp=p3;
                                switch(temp){
                                        case 0xed:key=0;break;
                                        case 0xdd:key=0;break;
                                        case 0xbd:key=0;break;
                                        case 0x7d:key=0;break;
                                while(temp!=0xf0){
                                temp=p3;
                                temp=temp&0xf0;
                                display(key);
                p3=0xfb;
                temp=p3;
                temp=temp&0xf0;
                if(temp!=0xf0){
                temp=p3;
                switch(temp){
                                case 0xeb:key=0;break;
                          case 0xdb:key=0;break;
                          case 0xbb:key=0;break;
                          case 0x7b:key=0;break;
                while(temp!=0xf0){
                                temp=p3;
                          temp=temp&0xf0;
                display(key);
                p3=0xf7;
                temp=p3;
                temp=temp&0xf0;
                if(temp!=0xf0){
                          temp=p3;
                          switch(temp){
                                case 0xe7:key=0;break;
                                case 0xd7:key=0;break;
                                case 0xb7:key=0;break;
                                case 0x77:key=0;break;
                        while(temp!=0xf0){
                                temp=p3;
                                temp=temp&0xf0;
                        display(key);
