查看: 13099|回復: 32
16*64點陣屏,單片機仿真+程序+電路圖 動態掃描喲
程序是用51單片機寫的
下面是16*64點陣滾動的效果
  1. #include<reg52.h>
  2. sbit SH_CP=P2^0;
  3. sbit DS=P2^1;
  4. sbit ST_CP=P2^2;
  5. unsigned char code display[]={
  6. 0x00,0x00,0x10,0x20,0x10,0x20,0xF8,0x3F,0x00,0x20,0x00,0x20,0x00,0x00,0x00,0x00,/*"1",0*/
  7. 0x00,0x00,0xE0,0x0F,0x10,0x11,0x88,0x20,0x88,0x20,0x18,0x11,0x00,0x0E,0x00,0x00,/*"6",1*/
  8. 0x40,0x02,0x40,0x02,0x80,0x01,0xF0,0x0F,0x80,0x01,0x40,0x02,0x40,0x02,0x00,0x00,/*"*",2*/
  9. 0x00,0x00,0xE0,0x0F,0x10,0x11,0x88,0x20,0x88,0x20,0x18,0x11,0x00,0x0E,0x00,0x00,/*"6",3*/
  10. 0x00,0x00,0x00,0x07,0xC0,0x04,0x20,0x24,0x10,0x24,0xF8,0x3F,0x00,0x24,0x00,0x00,/*"4",4*/
  11. 0x00,0x80,0x00,0x40,0xC0,0x37,0x40,0x04,0x40,0x04,0x40,0x14,0x7F,0x64,0x48,0x04,
  12. 0x48,0x14,0x48,0x64,0x48,0x04,0xC8,0x07,0x08,0x10,0x08,0xE0,0x00,0x00,0x00,0x00,/*"點",5*/
  13. 0x00,0x00,0xFE,0xFF,0x02,0x08,0x22,0x10,0xDA,0x08,0x06,0x07,0x08,0x08,0xC8,0x08,
  14. 0xB8,0x08,0x8F,0x08,0xE8,0xFF,0x88,0x08,0x88,0x08,0x88,0x08,0x08,0x08,0x00,0x00,/*"陣",6*/
  15. 0x00,0x01,0x80,0x00,0x60,0x00,0xF8,0xFF,0x07,0x80,0x08,0x40,0x08,0x30,0xF8,0x0F,
  16. 0x89,0x00,0x8E,0x40,0x88,0x80,0x88,0x40,0x88,0x3F,0x08,0x00,0x08,0x00,0x00,0x00,/*"仿",7*/
  17. 0x00,0x10,0x04,0x10,0x04,0x90,0xF4,0x5F,0x54,0x35,0x54,0x15,0x54,0x15,0x5F,0x15,
  18. 0x54,0x15,0x54,0x15,0x54,0x35,0xF4,0x5F,0x04,0x90,0x04,0x10,0x00,0x10,0x00,0x00,/*"真",8*/
  19. 0x00,0x80,0x00,0x60,0xF8,0x1F,0x88,0x00,0x88,0x10,0x88,0x20,0x88,0x1F,0x08,0x80,
  20. 0x08,0x40,0xFF,0x21,0x08,0x16,0x09,0x18,0x0A,0x26,0xC8,0x41,0x08,0xF8,0x00,0x00,/*"成",9*/
  21. 0x08,0x10,0x08,0x30,0x08,0x10,0xF8,0x1F,0x08,0x08,0x08,0x88,0x08,0x48,0x10,0x30,
  22. 0x10,0x0E,0xFF,0x01,0x10,0x40,0x10,0x80,0x10,0x40,0xF0,0x3F,0x00,0x00,0x00,0x00,/*"功",10*/
  23. 0x00,0x00,0x00,0x00,0x00,0x00,0xFE,0x33,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,
  24. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*"!",11*/
  25. 0x00,0x00,0x00,0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x00,0x01,/*"-",12*/
  26. 0x00,0x00,0x00,0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x00,0x01,0x00,0x01,/*"-",13*/
  27. 0x00,0x01,0x80,0x00,0x60,0x00,0xF8,0xFF,0x07,0x00,0x00,0x40,0xFC,0x4F,0x44,0x44,
  28. 0x44,0x44,0x44,0x44,0x44,0x44,0x44,0x44,0x44,0x44,0xFC,0x4F,0x00,0x40,0x00,0x00,/*"但",14*/
  29. 0x00,0x40,0x00,0x30,0xFC,0x0F,0x44,0x00,0x54,0xFD,0x54,0x45,0x54,0x45,0x55,0x45,
  30. 0xFE,0x47,0x54,0x45,0x54,0x45,0x54,0x45,0xF4,0xFD,0x44,0x00,0x44,0x00,0x00,0x00,/*"唐",15*/
  31. 0x00,0x04,0x00,0x84,0x00,0x44,0xFC,0x27,0x24,0x14,0x24,0x04,0x24,0x04,0x24,0x04,
  32. 0xE2,0x07,0x22,0x14,0x23,0x24,0x22,0x44,0x20,0x84,0x00,0x04,0x00,0x04,0x00,0x00,/*"兵",16*/
  33. 0x40,0x00,0x50,0x00,0x4E,0x3E,0x48,0x02,0x48,0x02,0xFF,0xFF,0x48,0x12,0x48,0x22,
  34. 0x48,0x1E,0x40,0x00,0xF8,0x0F,0x00,0x40,0x00,0x80,0xFF,0x7F,0x00,0x00,0x00,0x00,/*"制",17*/
  35. 0x00,0x01,0x80,0x00,0x60,0x00,0xF8,0xFF,0x07,0x00,0x40,0x00,0x30,0x00,0x0F,0x00,
  36. 0xF8,0xFF,0x88,0x08,0x88,0x08,0x88,0x08,0x88,0x08,0x08,0x08,0x08,0x00,0x00,0x00,/*"作",18*/
  37. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*" ",19*/
  38. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*" ",20*/
  39. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*" ",21*/
  40. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*" ",22*/
  41. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*" ",23*/
  42. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*" ",24*/
  43. 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,/*" ",25*/
  44. };
  45. void  hc595_senddat(unsigned char dat)
  46. {
  47.         unsigned char i;
  48.         for(i=0;i<8;i++)
  49.         {
  50.                 DS=dat&0x80;
  51.                 SH_CP=1;
  52.                 SH_CP=0;
  53.                 dat<<=1;
  54.         }
  55. }
  56. main()
  57. {
  58.         unsigned char i,n;
  59.         unsigned int k,m;
  60.         char j;
  61.         m=sizeof(display);
  62.         SH_CP=0;
  63.         ST_CP=0;
  64.         while(1)
  65.         {
  66.                 for(k=0;k<m;k=k+2)
  67.                 for(n=0;n<2;n++)
  68.                 for(i=0;i<16;i++)
  69.                 {
  70.                         for(j=3;j>=0;j--)
  71.                         {
  72.                                 hc595_senddat(display[(32*j+2*i+1+k)%m]);
  73.                                 hc595_senddat(display[(32*j+2*i+k)%m]);
  74.                         }
  75.                         P3=i;
  76.                         ST_CP=1;
  77.                         ST_CP=0;
  78.                 }
  79.         }
  80. }
16x64 滾動顯示.zip
69.47 KB, 下載次數: 281, 下載積分: 黑幣 -5
參與人數 5黑幣 +70 收起 理由
hacehi + 5 絕世好帖!
happy999 + 5 很給力!
l_v_ + 5 很給力!
自卑的青春 + 5 很給力!
admin + 50 共享資料的積分獎勵!
收藏收藏11 分享淘帖 頂1 踩
ID:121755 發表于 2016-5-18 17:05 | 只看該作者
買了為什么下載不了
ID:121777 發表于 2016-5-18 18:52 | 只看該作者
樓主我學吸一下啊
ID:100312 發表于 2016-6-12 18:41 | 只看該作者
強大的原理圖來襲…………
原理圖
原理圖
ID:101014 發表于 2016-6-20 14:09 來自觸屏版 | 只看該作者
牛人啊,好厲害,收下了
ID:101014 發表于 2016-6-20 14:14 來自觸屏版 | 只看該作者
高手在人間,收下了,謝謝了
ID:101014 發表于 2016-6-20 14:16 來自觸屏版 | 只看該作者
看看是什么東東
ID:139216 發表于 2016-9-13 11:03 | 只看該作者
可以實現手動控制嗎?
ID:100312 發表于 2016-9-13 17:43 | 只看該作者
LeonLee 發表于 2016-9-13 11:03
可以實現手動控制嗎?
沒有加,你可以自己加
ID:148617 發表于 2016-11-18 11:36 | 只看該作者
怎么仿真  有教學嗎?
ID:169258 發表于 2017-3-8 23:02 | 只看該作者
感謝樓主
ID:47760 發表于 2017-3-9 12:53 | 只看該作者
學習一下看看好不好
ID:175849 發表于 2017-3-20 22:11 | 只看該作者
學習學習
ID:187109 發表于 2017-4-7 14:15 | 只看該作者
很給力
ID:201624 發表于 2017-5-17 02:46 | 只看該作者
注冊 發表于 2016-5-18 17:05
**** 作者被禁止或刪除 內容自動屏蔽 ****
我也是這樣,怎么回事??
ID:203619 發表于 2017-5-22 20:27 來自觸屏版 | 只看該作者
好厲害啊
ID:203619 發表于 2017-5-22 21:59 來自觸屏版 | 只看該作者
樓主有沒有什么聯系方式可以加個好友嗎,我是初學者想多請教一下。
ID:203619 發表于 2017-5-23 10:03 | 只看該作者
loyc 發表于 2017-5-22 21:59
樓主為什么扣了3個黑幣之后還是不能下載而且又要5個啊,好著急
ID:203928 發表于 2017-5-23 16:19 | 只看該作者
看不懂 不過應該挺簡單的吧~
ID:149451 發表于 2017-5-23 20:56 | 只看該作者
LZ給的仿真圖貌似不對呀,無法仿真
ID:204258 發表于 2017-5-24 13:15 | 只看該作者
定義變量 賦值 設置開關
ID:232947 發表于 2017-12-12 19:13 | 只看該作者
正在學習,謝謝樓主分享,,好厲害,收下了
ID:260794 發表于 2017-12-12 19:23 | 只看該作者
感謝樓主
ID:260794 發表于 2017-12-12 19:25 | 只看該作者
學習了
樓主有PCB的圖嘛
ID:260794 發表于 2017-12-12 19:38 | 只看該作者
謝謝樓主分享
ID:261637 發表于 2017-12-15 00:46 | 只看該作者
買了為什么下載不了
ID:329670 發表于 2018-5-14 16:15 | 只看該作者
那個led內部是怎么連的
ID:298759 發表于 2018-5-25 09:49 | 只看該作者
很給力!
ID:378737 發表于 2018-7-25 15:58 | 只看該作者
下來看看
ID:403069 發表于 2018-10-9 14:31 | 只看該作者
買了為什么下載不了
ID:676182 發表于 2019-12-29 14:07 | 只看該作者
問一下P1,0,P1.1,P1.2,P1.3如何送行
ID:639705 發表于 2020-3-20 16:55 | 只看該作者
樓主為啥無法打開呀??是版本問題嗎?我用的8.0
