#include<reg51.h>
sbit D0=P1^1;//土壤濕度數字信號輸出口
sbit E=P2^7;
sbit RW=P2^5;
sbit RS=P2^6;
unsigned char x[2]={0x3F, 0x06};
void delayms(uint c)
uchar a,b;
for (; c>0; c--)
for (b=199;b>0;b--)
for(a=1;a>0;a--);
void Write_com(uchar order)
E=0;
RS=0;
RW=0;
P0=order;
delayms(10);
E=1;
delayms(10);
E=0;
void Write_Data(uchar data1)
RS=1;
E=0;
RW=0;
P0=data1;
delayms(10);
E=1;
delayms(10);
E=0;
void Lcd_Init()
Write_com(0x38);
Write_com(0x0f);
Write_com(0x06);
Write_com(0x80);
void main() =7=h
int i;
uchar LCD[9]="Humidity:";
uchar lcd1[16]="Humidity is low:";
uchar lcd2[16]="Humidity is high";v
Lcd_Init();
for(i=0;i<11;i++)
Write_Data(LCD[i]);
delayms(1);
Write_com(0x80+0X40);
delayms(10);
if(D0==1)
for(i=0;i<16;i++)
Write_Data(lcd1[i]);
delayms(1);
for(i=0;i<16;i++)
Write_Data(lcd2[i]);
delayms(1);
