查看: 2740|回復: 0
源程序代碼!99999.9秒顯示!
ID:72519 發表于 2015-1-21 18:25 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
  1. #include<reg52.h>//數碼管顯示0123456789共陰
  3. uchar table[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0xff};
  4. void delay1ms(int n)
  5. {
  6.    int i;
  7.    while(n--)
  8.    {
  9.     for(i=0;i<200;i++);
  10.
  11.    }
  12.    }
  13.   void main()
  14.   {
  15.    char i=0;
  16.
  17.     while(1)
  18.     {  if(i<11)
  19.       {
  20.     P2=table[i];
  21.         delay1ms(150);
  22.          i++;
  23.         }
  24.         else  i=0;
  25.
  26.     }
  27.      }
  28. 定時器點亮一個led///
  29. #include<reg52.h>
  30. char count=0;
  31. void timer_0(void)interrupt 1
  32. {
  33.     count++;
  34.    if(count==20)
  35.
  36.    { P2=~P2;
  37. count=0;
  38.     TH0=(65536-50000)/256;
  39.    TL0=(65536-50000)%256;
  40. }
  41.
  42. }
  43. void main()
  44.   {
  45.
  46.
  47.    P2=0x00;
  48.    TMOD=0x01;
  49.       TH0=(65536-50000)/256;
  50.       TL0=(65536-50000)%256;
  51.       EA=1;
  52.       ET0=1;
  53.       TR0=1;
  54.   while(1)
  55.    {
  56.        }
  57.
  58.    }
  59. 定時一百秒計數//
  60. #include<reg52.h>
  61. int second=0,count=0,munite=0;
  62. unsigned char table[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0xff};
  63.   void main()
  64.   {
  65.       TMOD=0x01;
  66.       TH0=(65536-50000)/256;
  67.       TL0=(65536-50000)%256;
  68.       EA=1;
  69.       ET0=1;
  70.       TR0=1;
  71.      while(1)
  72. {
  73.        }
  74.   }
  75.   void timer_0(void)interrupt 1
  76. {
  77.   second++;
  78.   TH0=(65536-50000)/256;
  79.   TL0=(65536-50000)%256;
  80.   if(second==20)
  81.   {
  82.    P1=table[count%10];
  83.    second=0;
  84.     count++;
  85.
  86.    }
  87.    if(count==11)
  88.   {
  89. munite++;
  90.    P2=table[munite%10];
  91.      count=0;
  92. }
  93. }
  94. 99999.9秒的定時程序顯示在6位7段數碼管上(注意小數點的電平),p3口掃描送高電平加上一個上拉電阻增大驅動電流P0口送共陽極代碼//
  95. #include<reg52.h>
  96.   #include<intrins.h>
  97.    sbit dot=P0^7;
  98.    int i,second=0;
  99.    unsigned char table[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0xff};
  100.    unsigned char disp[]={0,0,0,0,0,0};
  101.    void delayms( unsigned char n)
  102.    {
  103.      do
  104.   { _nop_();
  105.     _nop_();
  106.     _nop_();
  107.     _nop_();
  108.     _nop_();
  109.    }
  110.     while(--n);
  111.     }
  112.   void main()
  113.   {
  114.       TMOD=0x01;
  115.       TH0=(65536-50000)/256;
  116.       TL0=(65536-50000)%256;
  117.       EA=1;
  118.       ET0=1;
  119.       TR0=1;
  120.     while(1)
  121. {
  122.    P3=0x80;
  123.    for(i=5;i>=0;i--)
  124.      {
  125.    P3=_crol_(P3,1);
  126.   P0=table[disp[i]];
  127.   if(i==1)
  128.    dot=0;
  129.    delayms(10);
  130.      }
  131.    }
  132.   }
  133.   void timer_0(void)interrupt 1
  134. {
  135.
  136.   second++;
  137.   TH0=(65536-50000)/256;
  138.   TL0=(65536-50000)%256;
  139.   if(second==2)
  140.   { second=0;
  141.     disp[0]=disp[0]+1;
  142.   }
  143.    else
  144.   return;
  145.     for(i=0;i<6;i++)
  146. {
  147.     if(disp[i]==10)
  148.
  149.     {
  150.     disp[i]=0;
  151.     if(i!=5)
  152.     disp[i+1]=disp[i+1]+1;
  153.    }
  154.    else break;
  155. }
  156. }
