查看: 2611|回復: 0
80c52驅動LCD1602程序(proteus仿真驗證通過)
ID:814673 發表于 2020-8-17 15:09 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
本帖最后由 yangwanxue99 于 2020-8-17 15:12 編輯
#include<reg52.h>
#include <stdio.h>
    int init();    //聲明初始化函數
    int write_com(unsigned char);//聲明寫命令函數
    int write_date(unsigned char);//聲明寫數據函數
    int delay(unsigned char);//聲明延遲函數
    unsigned char x;
    sbit RS = P1^0;
    sbit RW = P1^1;
    sbit EN = P1^2;
    unsigned char code table[]="Welcome to the";
    unsigned char code table1[]="MCU learning!";
        void LcdWaitReady()         //判忙子程序
        unsigned char sta;
    P0 = 0xFF;
        RS = 0;
        RW = 1;
           EN = 0;
        EN = 0;
        EN = 1;
        delay(5) ;
//while((P2&0x80));//proteus仿真時將該行注釋掉,實際板上運行時去掉注釋即可
  EN = 0;
int main(void)//主函數
{  char a,b;
    init();
    write_com(0x80);//第一行
         a =sizeof(table); //計算字符串的長度
    for(x=0;x<a;x++)
         write_date(table[x]);
        delay(150);
    write_com(0x80+0x40);//第二行
        b =sizeof(table1); //計算字符串的長度
    for(x=0;x<b;x++)
         write_date(table1[x]);
        delay(150);
    while(1);
    return 0;
int init()//初始化函數體
    EN = 0;
    write_com(0X38);//設置16*2顯示,5*7點陣,8位數據接口
    write_com(0X0C);//設置開顯示,不顯示光標
    write_com(0X06);//寫一個字符時,整屏右移
    write_com(0X01);//顯示清零
    return 0;
int write_com(unsigned char com)//寫命令的函數體
   //EN=0;
           LcdWaitReady();
    RS = 0;
    RW = 0;
    P2 = com;
    delay(5);
    EN = 1;
    delay(5);
    EN = 0;
    return 0;
int write_date(unsigned char date)//寫數據的函數體
    LcdWaitReady();
        RS = 1;
    RW = 0;
    P2 = date;
    delay(5);
    EN = 1;
    delay(5);
    EN = 0;
    return 0;
int delay(unsigned char xms)
    unsigned char x,y;
    for(x=xms;x>0;x--)
        for(y=110;y>0;y--);
    return 0;
