準備材料:
STC15F2K60S2
esp8266
NTC熱敏電阻
10K電阻一個
連接線若干
手機APP:NetAssist
參考貼子:http://www.raoushi.com/bbs/dpj-57255-1.html
接線圖:
ALL
2018-11-25 19:39 上傳
NTC
2018-11-25 19:39 上傳
APP界面:
APP
2018-11-25 19:39 上傳
- #include<ADC.c>
- #define uchar unsigned char
- #define uint unsigned int
- #define RELOAD_COUNT 0xFA //宏定義波特率發(fā)生器的載入值
- #define MAIN_Fosc 22118400L //定義主時鐘
- #define Timer1_Reload (65536UL -(MAIN_Fosc / 4 / BaudRate1)) //Timer 1 重裝值, 對應300KHZ
- #define Timer2_Reload (65536UL -(MAIN_Fosc / 4 / BaudRate1)) //Timer 2 重裝值, 對應300KHZ
- #define BaudRate1 115200UL //選擇波特率
- #define ID_ADDR_ROM 0xeff7 //60K程序空間的MCU
- #define ID_ADDR_RAM 0xef //對于只有256字節(jié)RAM的MCU(大部分系列)存放地址為0EFH
- unsigned int code Ttable[106][2]={//溫度與電阻阻值對應關系表格
- 0,3274,//0度對應阻值32.74k
- 1,3111,//1度對應阻值31.11k
- 2,2957,//2度對應阻值29.57k
- 3,2812,//
- 4,2674,//
- 5,2545,6,2422,7,2306,8,2196,9,2092,10,1993,11,1900,12,1811,
- 13,1728,14,1648,15,1573,16,1501,17,1433,18,1369,19,1308,20,1250,
- 21,1194,22,1142,23,1092,24,1045,
- 25,1000,//25度對應阻值10k
- 26,957,//26度對應阻值9.57k
- 27,916,28,877,29,840,30,805,31,771,32,739,33,709,34,679,35,652,
- 36,625,37,600,38,576,39,553,40,531,41,510,42,490,43,471,44,453,
- 45,435,46,418,47,402,48,387,49,372,50,358,51,345,52,332,53,320,
- 54,308,55,297,56,286,57,276,58,266,59,256,60,247,61,238, 62,230,
- 63,222,64,214,65,207,66,199,67,193,68,186,69,180,70,174,71,168,
- 72,162,73,157,74, 152,75, 147,76, 142,77, 137,78, 133,79, 128,
- 80, 124,81, 120,82, 116,83, 113,84, 109,85, 106,
- 86, 102,//86度對應阻值1.02k
- 87, 99,//87度對應阻值0.99k
- 88, 96,89, 93,90, 90,91, 88,92, 85,93, 82,94, 80,95, 78,
- 96, 75,97, 73,98, 71,99, 69,100,67,101,65,102,63,103,61, 104,59,
- 105,58//105度對應阻值0.58k
- #define receive_max 50 //串口接收緩沖長度
- uchar Recive_table[receive_max]; //用于接收wifi模塊反饋到MCU上的數(shù)據(jù)
- u8 receive_count=0; //接受數(shù)據(jù)的個數(shù)
- u16 NTC_R;//定義熱敏電阻阻值變量
- int temperature;//定義溫度存儲變量
- sbit LED0=P3^7;
- uchar sent_table[receive_max];
- void Uart_Init()//使用定時器1作為波特率發(fā)生器
- SCON |= 0x40; //8位數(shù)據(jù)
- P_SW1 &= ~0xc0; //UART1 使用P30 P31口 默認
- TR1 = 0; //關閉定時器
- TR1 = 0; //波特率使用Timer1產(chǎn)生
- AUXR &= ~0x01; //S1 BRT Use Timer1;
- TMOD &= ~(1<<6); //Timer1 set As Timer
- TMOD &= ~0x30; //Timer1_16bitAutoReload;2
- AUXR |= (1<<6); //Timer1 set as 1T mode
- TH1 = (u8)(Timer1_Reload >> 8);
- TL1 = (u8)Timer1_Reload;
- TR1 = 1;
- PS = 1; //高優(yōu)先級中斷
- REN = 1; //允許接收
- ES = 1; //允許中斷
- EA = 1; //允許全局中斷
- void Delay_ms(u16 n)
- unsigned int i,j;
- for(i=0;i<n;i++)
- for(j=0;j<123;j++);
- void sendByte(uchar b)
- { ES=0;
- SBUF = b;
- while(!TI);
- TI=0;
- ES=1;
- void sendString(uchar *s)
- while(*s != '\0') //字符串默認結尾'\0',以此來判斷字符串的結束
- sendByte(*s++);
- void ESP8266_Set(uchar *puf) // 數(shù)組指針*puf指向字符串數(shù)組
- sendString(puf);
- Delay_ms(10);
- sendString("\r\n");//回車
- void ESP8266_Sent(uchar *puf) // 數(shù)組指針*puf指向字符串數(shù)組
- ESP8266_Set("AT+CIPSEND=0,60");
- sendString(puf);
- Delay_ms(10);
- sendString("\r\n"); //回車
- void ESP8266_Init()
- Delay_ms(2000);
- Delay_ms(1000);
- ESP8266_Set("AT+CIPMUX=1"); //啟動多連接
- Delay_ms(5000);
- LED0=!LED0;
- ESP8266_Set("AT+CIPSERVER=1,333");//建立server,端口為333
- void T_dis(){//溫度處理函數(shù)采集到的阻值與二維數(shù)組的阻值進行比較,從而獲得相對應的溫度值。
- unsigned char i;
- temperature = 0;
- for(i=105;i<106;i--) {
- if(NTC_R >= Ttable[i][1] && NTC_R < Ttable[i-1][1]){
- temperature=(Ttable[i][0]+1);
- break;
- void ADC_config(void)
- ADC_InitTypeDef ADC_InitStructure; //結構定義
- ADC_InitStructure.ADC_Px = ADC_P10 | ADC_P11 | ADC_P12; //設置要做ADC的IO, ADC_P10 ~ ADC_P17(或操作),ADC_P1_All
- ADC_InitStructure.ADC_Speed = ADC_360T; //ADC速度 ADC_90T,ADC_180T,ADC_360T,ADC_540T
- ADC_InitStructure.ADC_Power = ENABLE; //ADC功率允許/關閉 ENABLE,DISABLE
- ADC_InitStructure.ADC_AdjResult = ADC_RES_H8L2; //ADC結果調(diào)整, ADC_RES_H2L8,ADC_RES_H8L2
- ADC_InitStructure.ADC_Polity = PolityLow; //優(yōu)先級設置 PolityHigh,PolityLow
- ADC_InitStructure.ADC_Interrupt = DISABLE; //中斷允許 ENABLE,DISABLE
- ADC_Inilize(&ADC_InitStructure); //初始化
- ADC_PowerControl(ENABLE); //單獨的ADC電源操作函數(shù), ENABLE或DISABLE
- // convert to char
- char convert(u8 i) {
- switch(i){
- case 0:
- return '0';
- case 1:
- return '1';
- case 2:
- return '2';
- case 3:
- return '3';
- case 4:
- return '4';
- case 5:
- return '5';
- case 6:
- return '6';
- case 7:
- return '7';
- case 8:
- return '8';
- case 9:
- return '9';
- default:
- return i;
- void ShowResult(uchar ch)
- u16 adc_res10,//測量設定通道adc值
- bandgap, //bandgap預儲存校準值,單位毫伏
- adc_9gallery_res; //測量第九通道(bandgap)值
- float power_voltage, //系統(tǒng)供電電壓,單位毫伏
- R,ADC_voltage; //設定通道電壓值,單位毫伏
- uchar code *cptr; //定義ROM(代碼)區(qū)指針
- // uchar idata *iptr;//定義RAM(內(nèi)存)區(qū)指針
- cptr = ID_ADDR_ROM; //從程序區(qū)讀取BandGap電壓值(單位:毫伏mV)
- bandgap=*cptr++;
- bandgap<<=8;
- bandgap+=*cptr;
- /*iptr = ID_ADDR_RAM; //從內(nèi)存區(qū)讀取BandGap電壓值(單位:毫伏mV)
- bandgap=*iptr++; //兩種方法結果一樣,上面的方法需要在下載式勾選"在ID號前添加重要測試參數(shù)"選項,才可在程序中獲取此參數(shù)
- bandgap<<=8; //下面的方法不需要
- bandgap+=*iptr; */
- //測量設定通道adc值
- ADC_RES = 0; //清除結果寄存器
- P1ASF = 0x80; //設置P1口為AD口
- Get_ADC10bitResult(ch);
- Get_ADC10bitResult(ch); //讀三次獲得穩(wěn)定
- adc_res10= Get_ADC10bitResult(ch);
- //測量第九通道(bandgap)值
- P1ASF = 0x00; //設置讀第九通道
- Get_ADC10bitResult(0); //測bandgap時,調(diào)用此函數(shù)時通道數(shù)只能填0
- Get_ADC10bitResult(0); //讀三次獲得穩(wěn)定
- adc_9gallery_res=Get_ADC10bitResult(0);
- //計算系統(tǒng)供電電壓
- power_voltage= (float)bandgap*1024/adc_9gallery_res;
- //計算ADC通道測得電壓值
- ADC_voltage= (float)bandgap*adc_res10/adc_9gallery_res;
- R=1000*ADC_voltage/(power_voltage-ADC_voltage);
- NTC_R=R;//把float浮點數(shù)轉(zhuǎn)化為int型
- void main()
- Uart_Init();
- ESP8266_Init();
- Delay_ms(20);//待系統(tǒng)穩(wěn)定
- ADC_config();
- while(1){
- ShowResult(7);
- if(receive_count > 0)//如果接受到數(shù)據(jù)
- Delay_ms(500);
- receive_count = 0;//接收計數(shù)清0
- if(Recive_table[9]=='0') {
- sent_table[receive_max]= '\0';
- sent_table[0]='N';
- sent_table[1]='T';
- sent_table[2]='C';
- sent_table[3]='=';
- sent_table[4]=convert(NTC_R/1000);
- sent_table[5]=convert(NTC_R%1000/100);
- sent_table[6]=convert(NTC_R%100/10);
- sent_table[7]=convert(NTC_R%10);
- T_dis();
- sent_table[8]='T';sent_table[9]='=';
- sent_table[10]=convert(temperature%1000/100);
- sent_table[11]=convert(temperature%100/10);
- sent_table[12]=convert(temperature%10);
NTC10K溫度計.zip
(3.21 MB, 下載次數(shù): 117)
2018-11-25 19:42 上傳
下載積分: 黑幣 -5
