1、完成7人表決電路設(shè)計,LED燈表示通過、否決。 (1)開關(guān)表示贊成與否,1~7編號(1贊成,0不贊成); (2)LED顯示表決的結(jié)果; (3)數(shù)碼管分別顯示贊成、否決的人數(shù); (4)工作時鐘100HZ即可。
2、所有程序設(shè)計代碼包括設(shè)計代碼、仿真代碼和約束文件。
FPGA源程序如下:
- `timescale 1ns / 1ps
- // Company:
- // Engineer:
- // Create Date: 2018/06/20 21:42:40
- // Design Name:
- // Module Name: vote_7
- // Project Name:
- // Target Devices:
- // Tool Versions:
- // Description:
- // Dependencies:
- // Revision:
- // Revision 0.01 - File Created
- // Additional Comments:
- module vote_7(
- input clk,
- input rst,
- input[6:0]vote, //7位按鍵開關(guān)
- output reg led, //小燈表示贊同or否決
- output out1, //數(shù)碼管1輸出
- output out2, //數(shù)碼管2輸出
- output reg [6:0]state1, //數(shù)碼管1顯示贊同人數(shù)的總和
- output reg [6:0]state2 //數(shù)碼管2顯示否決人數(shù)的總和
- reg [2:0]sum; //計算贊同人數(shù)(開關(guān))的總和
- always @(posedge clk)
- begin
- if(!rst)
- begin
- sum<=0; //初始化sum等于0
- end
- else
- sum<=vote[6]+vote[5]+vote[4]+vote[3]+vote[2]+vote[1]+vote[0]; //sum計人數(shù)(撥碼開關(guān))的數(shù)量,求人數(shù)(撥碼開關(guān))的總和
- end
- assign out1 = 1'b1; //給數(shù)碼管的兩個輸出out1、out2使能
- assign out2 = 1'b1;
- //片選一個數(shù)碼管顯示否決人數(shù),將sum顯示的值顯示到數(shù)碼管1上,sum=0數(shù)碼管顯示0,sum=1數(shù)碼管顯示1,sum=2數(shù)碼管顯示2······
- always@(negedge rst,posedge clk)
- begin
- if(!rst)
- state1 <= 7'hff; //數(shù)碼管1初始化
- else
- begin
- case(sum[2:0])
- 3'h0:state1 <= 7'b0111111;
- 3'h1:state1 <= 7'b0000110;
- 3'h2:state1 <= 7'b1011011;
- 3'h3:state1 <= 7'b1001111;
- 3'h4:state1 <= 7'b1100110;
- 3'h5:state1 <= 7'b1101101;
- 3'h6:state1 <= 7'b1111101;
- 3'h7:state1 <= 7'b0000111;
- default :
- state1 <= 7'b0111111;
- endcase
- end
- end
- //片選一個數(shù)碼管顯示否決人數(shù),將sum顯示的值顯示到數(shù)碼管2上,sum=0數(shù)碼管顯示7,sum=1數(shù)碼管顯示6,sum=2數(shù)碼管顯示5······
- begin
- if(!rst)
- state2 <= 7'hff;
- else
- begin
- case(sum)
- 3'h0:state2 <= 7'b0000111;
- 3'h1:state2 <= 7'b1111101;
- 3'h2:state2 <= 7'b1101101;
- 3'h3:state2 <= 7'b1100110;
- 3'h4:state2 <= 7'b1001111;
- 3'h5:state2 <= 7'b1011011;
- 3'h6:state2 <= 7'b0000110;
- 3'h7:state2 <= 7'b0111111;
- default :
- state2 <= 7'h0000111;
- endcase
- end
- end
- //用小燈顯示通過和不通過,小燈亮,則通過;小燈滅則不通過。當(dāng)sum值大于3時led小燈亮,否則小燈滅
- always @(negedge rst,posedge clk)
- begin
- if(!rst)
- begin
- led<=0; //初始化小燈
- end
- else if(sum>=4)
- led<=1;
- else
- led<=0;
- end
- endmodule
2018-7-10 01:43 上傳
vote_7.zip
(2.25 KB, 下載次數(shù): 38)
2018-7-6 09:24 上傳
七人表決器 下載積分: 黑幣 -5
