發(fā)布時間: 2024-3-20 18:11
正文摘要:液晶顯示不理想,但編譯是通過了的。也不知道哪里出錯了。附源代碼 #include<reg52.h> #include<intrins.h> #include <math.h> //Keil library #include <stdio.h> //Keil library # ... |
unsigned char code time[][16]={ 0x00,0xE0,0x10,0x08,0x08,0x10,0xE0,0x00,0x00,0x0F,0x10,0x20,0x20,0x10,0x0F,0x00,//"0", 0x00,0x10,0x10,0xF8,0x00,0x00,0x00,0x00,0x00,0x20,0x20,0x3F,0x20,0x20,0x00,0x00,//"1", 0x00,0x70,0x08,0x08,0x08,0x88,0x70,0x00,0x00,0x30,0x28,0x24,0x22,0x21,0x30,0x00,//"2", 0x00,0x30,0x08,0x88,0x88,0x48,0x30,0x00,0x00,0x18,0x20,0x20,0x20,0x11,0x0E,0x00,//"3", 0x00,0x00,0xC0,0x20,0x10,0xF8,0x00,0x00,0x00,0x07,0x04,0x24,0x24,0x3F,0x24,0x00,//"4", 0x00,0xF8,0x08,0x88,0x88,0x08,0x08,0x00,0x00,0x19,0x21,0x20,0x20,0x11,0x0E,0x00,//"5", 0x00,0xE0,0x10,0x88,0x88,0x18,0x00,0x00,0x00,0x0F,0x11,0x20,0x20,0x11,0x0E,0x00,//"6", 0x00,0x38,0x08,0x08,0xC8,0x38,0x08,0x00,0x00,0x00,0x00,0x3F,0x00,0x00,0x00,0x00,//"7", 0x00,0x70,0x88,0x08,0x08,0x88,0x70,0x00,0x00,0x1C,0x22,0x21,0x21,0x22,0x1C,0x00,//"8", 0x00,0xE0,0x10,0x08,0x08,0x10,0xE0,0x00,0x00,0x00,0x31,0x22,0x22,0x11,0x0F,0x00,//"9", 0x08,0x78,0x88,0x00,0x00,0xC8,0x38,0x08,0x00,0x00,0x07,0x38,0x0E,0x01,0x00,0x00,//"V",10 0x00,0x70,0x88,0x08,0x08,0x08,0x38,0x00,0x00,0x38,0x20,0x21,0x21,0x22,0x1C,0x00,//"S",11 0x00,0x00,0x00,0xC0,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x30,0x30,0x00,0x00,0x00,//":",12 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x30,0x30,0x00,0x00,0x00,0x00,0x00,//".",13 0x18,0x08,0x08,0xF8,0x08,0x08,0x18,0x00,0x00,0x00,0x20,0x3F,0x20,0x00,0x00,0x00,//"T"14 0x08,0xF8,0x30,0xC0,0x00,0x08,0xF8,0x08,0x20,0x3F,0x20,0x00,0x07,0x18,0x3F,0x00,//"N"15 0x08,0xF8,0x08,0x08,0x08,0x10,0xE0,0x00,0x20,0x3F,0x20,0x20,0x20,0x10,0x0F,0x00,//"D"16 0x08,0xF8,0x88,0x88,0x88,0x88,0x70,0x00,0x20,0x3F,0x20,0x00,0x03,0x0C,0x30,0x20,//"R"17 0x08,0xF8,0x08,0x00,0x00,0x08,0xF8,0x08,0x20,0x3F,0x21,0x01,0x01,0x21,0x3F,0x20,//"H"18 0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//"空格"19 }; void Display_ASCII(uchar screen,uchar page,uchar column,uchar a[][16],uchar h) { uchar i; SelectScreen(screen); Set_page(page); Set_column(column*8); for(i=0;i<8;i++) //顯示字符上半部分:8*8 { write_LCD_data(*(a[h]+i)); } Set_page(page+1); //顯示字符下半部分:8*8 Set_column(column*8); for(i=0;i<8;i++) { write_LCD_data (*(a[h]+i+8)); } } Display_ASCII(1,2,5,time,A); Display_ASCII(1,2,6,time,B); Display_ASCII(1,2,7,time,C);//bifen Display_ASCII(2,2,1,time,12); Display_ASCII(2,2,3,time,D); Display_ASCII(2,2,4,time,E); Display_ASCII(2,2,5,time,F); 下面的比分顯示不出來。是哪里有問題??? |
| 現(xiàn)在是只顯示場次和比賽雙方,不顯示比分了(比賽雙方是我調用錯了數組導致字不對) |
| 液晶控制口D1網絡和數據口的D1網絡重了,改下它試試。 |
