查看: 1177|回復: 4
Proteus仿真液晶顯示花屏?
12864(1).zip (42.83 KB, 下載次數: 3)
液晶顯示不理想,但編譯是通過了的。也不知道哪里出錯了。附源代碼
#include<reg52.h>
#include<intrins.h>
#include <math.h> //Keil library
#include <stdio.h> //Keil library
#define LCD_databus P0 //LCD12864的8位數據口
uint heat=000,spurs=000;
uint c;
sbit EN=P2^2; //低電平寫入高電平讀取
sbit RS=P2^0; //高電平數據輸入命令輸入
sbit RW=P2^1; //高電平讀取低電平寫入
sbit CS2=P2^3; //
sbit CS1=P2^4;
sbit key1=P1^0;
sbit key2=P1^1;
sbit key3=P1^2;
sbit key4=P1^3;
sbit key5=P1^4;
sbit key6=P1^5;
sbit key7=P1^6;
sbit key8=P1^7;
sbit BEEP=P3^0;
char chang=48;
char xiaoshu=0;
char xiaoshu2=0;
uchar f2;
uchar m2;
uchar x2;
uchar count;
char fen=12;
char miao=0;
char flag=24;
unsigned char code time[][16]={
0x00,0xE0,0x10,0x08,0x08,0x10,0xE0,0x00,0x00,0x0F,0x10,0x20,0x20,0x10,0x0F,0x00,//"0",
0x00,0x10,0x10,0xF8,0x00,0x00,0x00,0x00,0x00,0x20,0x20,0x3F,0x20,0x20,0x00,0x00,//"1",
0x00,0x70,0x08,0x08,0x08,0x88,0x70,0x00,0x00,0x30,0x28,0x24,0x22,0x21,0x30,0x00,//"2",
0x00,0x30,0x08,0x88,0x88,0x48,0x30,0x00,0x00,0x18,0x20,0x20,0x20,0x11,0x0E,0x00,//"3",
0x00,0x00,0xC0,0x20,0x10,0xF8,0x00,0x00,0x00,0x07,0x04,0x24,0x24,0x3F,0x24,0x00,//"4",
0x00,0xF8,0x08,0x88,0x88,0x08,0x08,0x00,0x00,0x19,0x21,0x20,0x20,0x11,0x0E,0x00,//"5",
0x00,0xE0,0x10,0x88,0x88,0x18,0x00,0x00,0x00,0x0F,0x11,0x20,0x20,0x11,0x0E,0x00,//"6",
0x00,0x38,0x08,0x08,0xC8,0x38,0x08,0x00,0x00,0x00,0x00,0x3F,0x00,0x00,0x00,0x00,//"7",
0x00,0x70,0x88,0x08,0x08,0x88,0x70,0x00,0x00,0x1C,0x22,0x21,0x21,0x22,0x1C,0x00,//"8",
0x00,0xE0,0x10,0x08,0x08,0x10,0xE0,0x00,0x00,0x00,0x31,0x22,0x22,0x11,0x0F,0x00,//"9",
0x08,0x78,0x88,0x00,0x00,0xC8,0x38,0x08,0x00,0x00,0x07,0x38,0x0E,0x01,0x00,0x00,//"V",10
0x00,0x70,0x88,0x08,0x08,0x08,0x38,0x00,0x00,0x38,0x20,0x21,0x21,0x22,0x1C,0x00,//"S",11
0x00,0x00,0x00,0xC0,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x30,0x30,0x00,0x00,0x00,//":",12
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x30,0x30,0x00,0x00,0x00,0x00,0x00,//".",13
0x18,0x08,0x08,0xF8,0x08,0x08,0x18,0x00,0x00,0x00,0x20,0x3F,0x20,0x00,0x00,0x00,//"T"14
0x08,0xF8,0x30,0xC0,0x00,0x08,0xF8,0x08,0x20,0x3F,0x20,0x00,0x07,0x18,0x3F,0x00,//"N"15
0x08,0xF8,0x08,0x08,0x08,0x10,0xE0,0x00,0x20,0x3F,0x20,0x20,0x20,0x10,0x0F,0x00,//"D"16
0x08,0xF8,0x88,0x88,0x88,0x88,0x70,0x00,0x20,0x3F,0x20,0x00,0x03,0x0C,0x30,0x20,//"R"17
0x08,0xF8,0x08,0x00,0x00,0x08,0xF8,0x08,0x20,0x3F,0x21,0x01,0x01,0x21,0x3F,0x20,//"H"18
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//"空格"19
uchar code HZ[][32]={
0x00,0x08,0x08,0x08,0x08,0x08,0x09,0xFE,
0x08,0x08,0x08,0x08,0x08,0x08,0x00,0x00,
0x40,0x40,0x41,0x41,0x41,0x41,0x41,0x7F,
0x41,0x41,0x41,0x41,0x41,0x40,0x40,0x00,//"主"
0x00,0xFE,0x02,0x22,0xDA,0x06,0x00,0x00,
0x00,0xFF,0x00,0x00,0x00,0x00,0x00,0x00,
0x00,0xFF,0x08,0x10,0x88,0x47,0x20,0x18,
0x07,0x00,0x07,0x18,0x20,0x40,0x80,0x00,// "隊",
0x10,0x0C,0x84,0x44,0x3C,0x54,0x95,0x96,
0x94,0x54,0x34,0x14,0x04,0x14,0x0C,0x00,
0x04,0x04,0x02,0x02,0xFD,0x45,0x44,0x44,
0x44,0x45,0xFD,0x02,0x02,0x06,0x02,0x00,//“客”
0x80,0x80,0x80,0x80,0x80,0x80,0x80,0x80,
0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x00,//"一",
void delay_10us(uint n) //延時n個10us@12M晶振
         uint i;
        for(i=n;i>0;i--)
        _nop_();_nop_();_nop_();_nop_();_nop_();_nop_();
void delay_50us(uint z)
         uint x,y; for(x=z;x>0;x--)
        for(y=19;y>0;y--);
void delay_ms(uint z)
        uint x,y;
        for(x=z;x>0;x--)
        for(y=110;y>0;y--);
void delay(uint i)
while(--i);
} /**?延時函數?**/
void delay_1ms(uint x)
uint i,j;
for(j=0;j<x;j++)
for(i=0;i<110;i++);
void Read_busy()//讀“忙”函數-----數據線的最高位DB71則busy
        P0=0x00;
        RS=0;
        RW=1;
        EN=1;
        while(P0 & 0x80);
        EN=0;
void write_LCD_command(uchar value) //寫命令函數
        Read_busy(); //對LCD的每次讀寫都要讀忙
        RS=0; //選擇命令
        RW=0; //讀操作
        LCD_databus=value;
        EN=1; //EN由1----0鎖存有效數據
        _nop_();
        _nop_();
        EN=0;
void write_LCD_data(uchar value)//寫數據函數
        Read_busy();
        RS=1; //選擇數據
        RW=0;
        LCD_databus=value;
        _nop_();
        _nop_();
        EN=0;
void Set_page(uchar page) //設置“頁”LCD12864共8頁,一頁是8行點陣點
        page=0xb8|page; //頁的首地址為0xB8
        write_LCD_command(page);
void Set_line(uchar startline) //設置顯示的起始行
        startline=0xC0|startline; //起始行地址為0xC0
        write_LCD_command(startline); //設置從哪行開始:共0--63;一般從0 行開始顯示
void Set_column(uchar column) //設置顯示的列
        column=column &0x3f; //列的最大值為64
        column= 0x40|column; //列的首地址為0x40
        write_LCD_command(column); //規定顯示的列的位置
void SetOnOff(uchar onoff) //顯示開關函數:0x3E是關顯示,0x3F是開顯示
        onoff=0x3e|onoff; //onoff:1---開顯示;0---關顯示
        write_LCD_command(onoff);
void SelectScreen(uchar screen) //選擇屏幕
        switch(screen)
                case 0: CS1=0;CS2=0;break; //全屏
                case 1: CS1=0;CS2=1;break;//左半屏
                case 2: CS1=1;CS2=0;break;//右半屏
                default:break;
void ClearScreen(uchar screen) //清屏函數
        uchar i,j;
        SelectScreen(screen); //0--全屏;1---左半屏;2---右半屏
        for(i=0;i<8;i++) //控制頁數0-7,共8頁
                Set_page(i);
                Set_column(0);
                for(j=0;j<64;j++) //控制列數0-63,共64列
                        write_LCD_data(0x00); //寫入0,地址指針自加1
void init_LCD() //LCD的初始化
        SetOnOff(1); //開顯示
        SelectScreen(0);//
        ClearScreen(0); //清屏
        Set_line(0); //開始行:0
void Display_ASCII(uchar screen,uchar page,uchar column,uchar a[][16],uchar h)
        uchar i;
        Set_page(page);
        Set_column(column*8);
        for(i=0;i<8;i++) //顯示字符上半部分:8*8
                write_LCD_data(*(a[h]+i));
        Set_page(page+1); //顯示字符下半部分:8*8
        for(i=0;i<8;i++)
        write_LCD_data
        (*(a[h]+i+8));
void Display_HZ(uchar screen,uchar page,uchar column,uchar a[][32],uchar h)
        uchar i;
        Set_page(page); //寫上半頁:16*8
        Set_column(column*16); //控制列
        for(i=0;i<16;i++) //控制16列的數據輸出
                write_LCD_data(*(a[h]+i)); //漢字的上半部分
        Set_page(page+1); //寫下半頁:16*8
        { write_LCD_data(*(a[h]+16+i)); //漢字的下半部分
void disp1()
        Display_HZ(1,0,2,HZ,0);//主
        Display_HZ(1,0,3,HZ,1);//隊
        Display_ASCII(2,0,0,time,10);
        Display_ASCII(2,0,1,time,11);
        Display_HZ(2,0,1,HZ,3);//客
        Display_HZ(2,0,2,HZ,2);//隊
void disp2() //
        Display_HZ(1,0,2,HZ,3);// 客
        Display_HZ(1,0,3,HZ,4);//         隊
        Display_HZ(2,0,1,HZ,0);//主
        Display_HZ(2,0,2,HZ,1);//隊
void disp3()
        if(chang>36)
                Display_ASCII(1,4,0,time,1);
                Display_ASCII(1,4,1,time,11);
                Display_ASCII(1,4,2,time,14);
        else if(chang>24)
                Display_ASCII(1,4,0,time,2);
                Display_ASCII(1,4,1,time,15);
                Display_ASCII(1,4,2,time,16);
        else if(chang>12)
                        Display_ASCII(1,4,0,time,3);
                        Display_ASCII(1,4,1,time,17);
        else if(chang>0)
        { while(1)
                        Display_ASCII(1,4,0,time,4);
                        Display_ASCII(1,4,1,time,14);
                        Display_ASCII(1,4,2,time,18);
void disp4()
        chang=24;
        fen=12;
        miao=0;
        xiaoshu=0;
        xiaoshu2=0;
        flag=0;
void disp5()
        if(fen==0&&miao==0&&xiaoshu==0)
                BEEP=0;
                delay_1ms(5000);
                fen=12;
                miao=0;
                xiaoshu=0;
                TR0=0;
                BEEP=1;
        if(flag==0&&xiaoshu2==0)
                BEEP=0;
                f2=fen;
                m2=miao;
                x2=xiaoshu;
                delay_1ms(5000);
                TR0=0;
                fen=f2;
                miao=m2;
                xiaoshu=x2;
                flag=24;
                xiaoshu2=0;
                BEEP=1;
void dingshiqi()
        TMOD=0X01; //T1 jishu T0 jishi
        TH0=(65536-50000)/256;
        TL0=(65536-50000)%256;
        EA=1;
        ET0=1;
        TR0=0;
void Key1()
        if(key1==0)
                delay_ms(10);
                if(key1==0)
                        while(!key1)
                                while(!key1)
                                disp2();
                                disp4();
                                c=spurs;
                                spurs=heat;
                                heat=c;
void Key2()
        if(key2==0)
                delay_ms(10);
                if(key2==0)
                        while(!key2)
                        { while(!key2)
                        heat++;
void Key3()
        if(key3==0)
                delay_ms(10);
                if(key3==0)
                        while(!key3)
                                while(!key3)
                                if (heat==0)
                                heat--;
void Key4()
        if(key4==0)
                delay_ms(10);
                if(key4==0)
                        while(!key4)
                                while(!key4)
                                spurs++;
void Key5()
        if(key5==0)
                delay_ms(10);
                if(key5==0)
                        while(!key5)
                                while(!key5){ }
                                if (spurs==0)
                                {spurs--;}
void Key6()
        if(key6==0)
                delay_ms(10);
                if(key6==0)
                        while(!key6)
                                while(!key6)
                                        TR0=0;
void Key7()
        if(key7==0)
        delay_ms(10);
        if(key7==0)
                        while(!key7)
                                while(!key7)
                                TR0=1;
void Key8()
        if(key8==0)
                delay_ms(10);
                if(key8==0)
                        while(!key8)
                                while(!key8)
                                flag=24;
                                xiaoshu2=0;
void main(void)
        uchar A,B,C,D,E,F;
        uchar G,H,I,J,K,L;
        init_LCD();
        dingshiqi();
        disp1();
        disp3();
                disp5();
                Key1();
                Key2();
                Key3();
                Key4();
                Key5();
                Key6();
                Key7();
                Key8();
                A=heat/100;
                B=heat/10%10;
                C=heat%10;
                D=spurs/100;
                E=spurs/10%10;
                F=spurs%10;
                G=fen/10;
                H=fen%10;
                I=miao/10;
                J=miao%10;
                K=flag/10;
                L=flag%10;
                Display_ASCII(1,2,5,time,A);
                Display_ASCII(1,2,6,time,B);
                Display_ASCII(1,2,7,time,C);//bifen
                Display_ASCII(2,2,1,time,12);
                Display_ASCII(2,2,3,time,D);
                Display_ASCII(2,2,4,time,E);
                Display_ASCII(2,2,5,time,F);
                Display_ASCII(1,4,4,time,G);
                Display_ASCII(1,4,5,time,H);
                Display_ASCII(1,4,6,time,12);
                Display_ASCII(1,4,7,time,I);
                Display_ASCII(2,4,0,time,J);
                Display_ASCII(2,4,1,time,13);
                Display_ASCII(2,4,2,time,xiaoshu);
                Display_ASCII(2,4,4,time,K);
                Display_ASCII(2,4,5,time,L);
                Display_ASCII(2,4,6,time,13);
                Display_ASCII(2,4,7,time,xiaoshu2);
void timer0() interrupt 1 //3定時器1的中斷號1定時器0的中斷號0外部中斷1 2外部中 斷2 4串口中斷
        count++;
        if(count==2)
                count=0;
                xiaoshu--;
                if(xiaoshu==-1)
                { xiaoshu=9; miao--; } //計時時間小數
                if(miao==-1)
                                miao=59;
                                fen--;
                                chang--;
                                if(fen==-1)
                                        fen=12;
                        } //分鐘跳動1st 2nd 3rd 4th
                                xiaoshu2--;
                        if(xiaoshu2==-1)
                                xiaoshu2=9;
                                flag--;
                        } //24秒時間小數
                        if(flag==-1)
                                flag=24;
                                xiaoshu2=0;
                        } //24秒重置
不排除proteus設置出錯,但我也不清楚是哪里出錯了
一般這種情況應該怎么處理?
ID:102963 發表于 2024-3-20 22:00 | 只看該作者
液晶控制口D1網絡和數據口的D1網絡重了,改下它試試。
ID:1107719 發表于 2024-3-20 22:20 | 只看該作者
按樓上所說弄了,但依然不理想。我再看看 可能是我哪里設置錯了
ID:1107719 發表于 2024-3-21 09:59 | 只看該作者
現在是只顯示場次和比賽雙方,不顯示比分了(比賽雙方是我調用錯了數組導致字不對)
ID:1107719 發表于 2024-3-21 13:06 | 只看該作者
        uchar i;
        Set_page(page);
        for(i=0;i<8;i++)
        write_LCD_data
        (*(a[h]+i+8));
下面的比分顯示不出來。是哪里有問題???
