- #include <reg52.h> //調(diào)用單片機(jī)頭文件
- #define uchar unsigned char //無符號字符型 宏定義 變量范圍0~255
- #define uint unsigned int //無符號整型 宏定義 變量范圍0~65535
- #include "eeprom52.h"
- //數(shù)碼管段選定義 0 1 2 3 4 5 6 7 8 9
- uchar code smg_du[]={0x28,0xee,0x32,0xa2,0xe4,0xa1,0x21,0xea,0x20,0xa0,
- 0x60,0x25,0x39,0x26,0x31,0x71,0xff}; //斷碼
- //數(shù)碼管位選定義
- uchar code smg_we[]={0xef,0xdf,0xbf,0x7f};
- uchar dis_smg[8] = {0x28,0xee,0x32,0xa2,0xe4,0x92,0x82,0xf8};
- uchar smg_i = 3; //顯示數(shù)碼管的個位數(shù)
- sbit dq = P2^4; //18b20 IO口的定義
- bit flag_lj_en; //按鍵連加使能
- bit flag_lj_3_en; //按鍵連3次連加后使能 加的數(shù)就越大了
- uchar key_time,key_value; //用做連加的中間變量
- bit key_500ms ;
- sbit pwm = P2^3;
- uchar f_pwm_l ; //越小越暗
- uint temperature ; //
- bit flag_300ms ;
- uchar menu_1; //菜單設(shè)計(jì)的變量
- uint t_high = 300,t_low = 100; //溫度上下限報(bào)警值
- uint number;
- /***********************1ms延時函數(shù)*****************************/
- void delay_1ms(uint q)
- uint i,j;
- for(i=0;i<q;i++)
- for(j=0;j<120;j++);
- /***********************小延時函數(shù)*****************************/
- void delay_uint(uint q)
- while(q--);
- /***********************數(shù)碼顯示函數(shù)*****************************/
- void display()
- static uchar i;
- i++;
- if(i >= smg_i)
- i = 0;
- P1 = 0xff; //消隱
- P3 = smg_we[i]; //位選
- P1 = dis_smg[i]; //段選
- /******************把數(shù)據(jù)保存到單片機(jī)內(nèi)部eepom中******************/
- void write_eeprom()
- SectorErase(0x2000);
- byte_write(0x2000, t_high % 256);
- byte_write(0x2001, t_high / 256);
- byte_write(0x2002, t_low % 256);
- byte_write(0x2003, t_low / 256);
- byte_write(0x2055, a_a);
- /******************把數(shù)據(jù)從單片機(jī)內(nèi)部eepom中讀出來*****************/
- void read_eeprom()
- t_high = byte_read(0x2001);
- t_high <<= 8;
- t_high |= byte_read(0x2000);
- t_low = byte_read(0x2003);
- t_low <<= 8;
- t_low |= byte_read(0x2002);
- a_a = byte_read(0x2055);
- /**************開機(jī)初始化保存的數(shù)據(jù)*****************/
- void init_eeprom()
- read_eeprom(); //先讀
- if(a_a != 22) //新的單片機(jī)初始單片機(jī)內(nèi)問eeprom
- t_high = 250;
- t_low = 200;
- a_a = 22;
- write_eeprom(); //保存數(shù)據(jù)
- /***********************18b20初始化函數(shù)*****************************/
- void init_18b20()
- bit q;
- dq = 1; //把總線拿高
- delay_uint(1); //15us
- dq = 0; //給復(fù)位脈沖
- delay_uint(80); //750us
- dq = 1; //把總線拿高 等待
- delay_uint(10); //110us
- q = dq; //讀取18b20初始化信號
- delay_uint(20); //200us
- dq = 1; //把總線拿高 釋放總線
- /*************寫18b20內(nèi)的數(shù)據(jù)***************/
- void write_18b20(uchar dat)
- uchar i;
- for(i=0;i<8;i++)
- { //寫數(shù)據(jù)是低位開始
- dq = 0; //把總線拿低寫時間隙開始
- dq = dat & 0x01; //向18b20總線寫數(shù)據(jù)了
- delay_uint(5); // 60us
- dq = 1; //釋放總線
- dat >>= 1;
- /*************讀取18b20內(nèi)的數(shù)據(jù)***************/
- uchar read_18b20()
- uchar i,value;
- for(i=0;i<8;i++)
- dq = 0; //把總線拿低讀時間隙開始
- value >>= 1; //讀數(shù)據(jù)是低位開始
- dq = 1; //釋放總線
- if(dq == 1) //開始讀寫數(shù)據(jù)
- value |= 0x80;
- delay_uint(5); //60us 讀一個時間隙最少要保持60us的時間
- return value; //返回?cái)?shù)據(jù)
- /*************讀取溫度的值 讀出來的是小數(shù)***************/
- uint read_temp()
- uint value;
- uchar low; //在讀取溫度的時候如果中斷的太頻繁了,就應(yīng)該把中斷給關(guān)了,否則會影響到18b20的時序
- init_18b20(); //初始化18b20
- EA = 0;
- write_18b20(0xcc); //跳過64位ROM
- write_18b20(0x44); //啟動一次溫度轉(zhuǎn)換命令
- EA = 1;
- delay_uint(50); //500us
- EA = 0;
- write_18b20(0xbe); //發(fā)出讀取暫存器命令
- low = read_18b20(); //讀溫度低字節(jié)
- value = read_18b20(); //讀溫度高字節(jié)
- EA = 1;
- value <<= 8; //把溫度的高位左移8位
- value |= low; //把讀出的溫度低位放到value的低八位中
- value *= 0.625; //轉(zhuǎn)換到溫度值 小數(shù)
- return value; //返回讀出的溫度 帶小數(shù)
- /*************定時器0初始化程序***************/
- void time_init()
- EA = 1; //開總中斷
- TMOD = 0X11; //定時器0、定時器1工作方式1
- ET0 = 1; //開定時器0中斷
- TR0 = 1; //允許定時器0定時
- ET1 = 1; //開定時器0中斷
- TR1 = 0; //允許定時器0定時
- /********************獨(dú)立按鍵程序*****************/
- uchar key_can; //按鍵值
- void key() //獨(dú)立按鍵程序
- static uchar key_new;
- key_can = 20; //按鍵值還原
- P2 |= 0x07;
- if((P2 & 0x07) != 0x07) //按鍵按下
- if(key_500ms == 1) //連加
- key_500ms = 0;
- key_new = 1;
- delay_1ms(1); //按鍵消抖動
- if(((P2 & 0x07) != 0x07) && (key_new == 1))
- { //確認(rèn)是按鍵按下
- key_new = 0;
- switch(P2 & 0x07)
- case 0x06: key_can = 3; break; //得到k2鍵值
- case 0x05: key_can = 2; break; //得到k3鍵值
- case 0x03: key_can = 1; break; //得到k4鍵值
- flag_lj_en = 1; //連加使能
- else
- if(key_new == 0)
- key_new = 1;
- flag_lj_en = 0; //關(guān)閉連加使能
- flag_lj_3_en = 0; //關(guān)閉3秒后使能
- key_value = 0; //清零
- key_time = 0;
- key_500ms = 0;
- /****************按鍵處理數(shù)碼管顯示函數(shù)***************/
- void key_with()
- if(key_can == 1) //設(shè)置鍵
- f_pwm_l = 30;
- menu_1 ++;
- if(menu_1 >= 3)
- menu_1 = 0;
- smg_i = 3; //數(shù)碼管顯示3位
- if(menu_1 == 1) //設(shè)置高溫報(bào)警
- smg_i = 4; //數(shù)碼管顯示4位
- if(key_can == 2)
- if(flag_lj_3_en == 0)
- t_high ++ ; //按鍵按下未松開自動加三次
- else
- t_high += 10; //按鍵按下未松開自動加三次之后每次自動加10
- if(t_high > 990)
- t_high = 990;
- if(key_can == 3)
- t_high -- ; //按鍵按下未松開自動減三次
- else
- t_high -= 10; //按鍵按下未松開自動減三次之后每次自動減10
- if(t_high <= t_low)
- t_high = t_low + 1;
- dis_smg[0] = smg_du[t_high % 10]; //取小數(shù)顯示
- dis_smg[1] = smg_du[t_high / 10 % 10] & 0xdf; //取個位顯示
- dis_smg[2] = smg_du[t_high / 100 % 10] ; //取十位顯示
- dis_smg[3] = 0x64; //H
- if(menu_1 == 2) //設(shè)置低溫報(bào)警
- if(key_can == 2)
- t_low ++ ; //按鍵按下未松開自動加三次
- else
- t_low += 10; //按鍵按下未松開自動加三次之后每次自動加10
- if(t_low >= t_high)
- t_low = t_high - 1;
- if(key_can == 3)
- t_low -- ; //按鍵按下未松開自動減三次
- else
- t_low -= 10; //按鍵按下未松開自動加三次之后每次自動加10
- if(t_low <= 10)
- t_low = 10;
- dis_smg[0] = smg_du[t_low % 10]; //取小數(shù)顯示
- dis_smg[1] = smg_du[t_low / 10 % 10] & 0xdf; //取個位顯示
- dis_smg[2] = smg_du[t_low / 100 % 10] ; //取十位顯示
- dis_smg[3] = 0x3D; //L
- /****************風(fēng)扇控制函數(shù)***************/
- void fengshan_kz()
- if(temperature >= t_high) //風(fēng)扇全開
- TR1 = 1;
- pwm = 0;
- else if((temperature < t_high) && (temperature >= t_low)) //風(fēng)扇緩慢
- f_pwm_l = 60;
- TR1 = 1;
- else if(temperature < t_low) //關(guān)閉風(fēng)扇
- TR1 = 0;
- pwm = 1;
- /****************主函數(shù)***************/
- void main()
- P0 = P1 = P2 = P3 = 0xff;
- time_init(); //初始化定時器
- temperature = read_temp(); //先讀出溫度的值
- init_eeprom(); //開始初始化保存的數(shù)據(jù)
- delay_1ms(650);
- dis_smg[0] = smg_du[temperature % 10]; //取溫度的小數(shù)顯示
- dis_smg[1] = smg_du[temperature / 10 % 10] & 0xdf; //取溫度的個位顯示
- dis_smg[2] = smg_du[temperature / 100 % 10] ; //取溫度的十位顯示
- f_pwm_l = 50;
- while(1)
- key(); //按鍵程序
- if(key_can < 10)
- key_with(); //設(shè)置報(bào)警溫度
- if(flag_300ms == 1) //300ms 處理一次溫度程序
- flag_300ms = 0;
- if(menu_1 == 0)
- smg_i = 3;
- fengshan_kz(); //風(fēng)扇控制函數(shù)
- /*************定時器0中斷服務(wù)程序***************/
- void time0_int() interrupt 1
- static uchar value; //定時2ms中斷一次
- TH0 = 0xf8;
- TL0 = 0x30; //2ms
- display(); //數(shù)碼管顯示函數(shù)
- value++;
- if(value >= 150)
- value = 0;
- flag_300ms = 1;
- if(flag_lj_en == 1) //按下按鍵使能
- key_time ++;
- if(key_time >= 250) //500ms
- key_time = 0;
- key_500ms = 1; //500ms
- key_value ++;
- if(key_value > 3)
- key_value = 10;
- flag_lj_3_en = 1; //3次后1.5秒連加大些
- /*******************定時器1用做單片機(jī)模擬PWM 調(diào)節(jié)***********************/
- void Timer1() interrupt 3 //調(diào)用定時器1
- static uchar value_l;
- TH1=0x0f; // 定時中斷一次
- TL1=0xec; //
- if(pwm==1)
- value_l+=3;
- if(value_l > f_pwm_l) //高電平
- value_l=0;
- pwm=0;
- else
- value_l+=3;
- if(value_l > 100 - f_pwm_l) //低電平
- value_l=0;
- pwm=1;
復(fù)制代碼 |
