查看: 1503|回復: 0
點亮流水燈
ID:253243 發表于 2017-11-24 21:53 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include<reg51.h>
void delay(uint i){
uint j;
for(;i>0;i--)
for(j=0;j<125;j++);
void main(){
uchar
display[9]={0xff,0xfe,0xfd,0xfb,0xf7,0xef,0xdf,0xbf,0x7f};
for(;;) {
uint a;
EA=1;
EX0=1;
EX1=1;
IT0=1;
IT1=1;
IP=0;
for(a=0;a<9;a++) {
delay(500);
P1=display[a];
void int0(void)interrupt 0{
uchar m;
for(m=0;m<5;m++){
P1=0X0F;
delay(500);
P1=0xf0;
delay(500);
void intl(void)interrupt 2{
uchar n;
for(n=0;n<5;n++){
P1=0xff;
delay(500);
P1=0;
delay(500);
