查看: 2275|回復: 0
蜂鳴器播放音樂
ID:240013 發表于 2017-11-24 15:15 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include <at89x52.h>
bit flag; //標志音樂輸出腳電平的高低
uchar ptr = 0x00; //取音符
uchar high; //計數器高位
uchar low; //計數器低位
// 本曲譜為 "新年好",前兩個十六進制表示發聲頻率,后一個表示發聲時間,0xFF,0xFF 表示休止符
// 0x00 表示結束
// 1 _ 1_ 1 .5
uchar code music[] = {
0xFC,0x44,0x7F, 0xFC,0x44,0x7F, 0xFC,0x44,0xFF, 0xFA,0x68,0xFF,
// 3 _ 3_ 3 1
0xFD,0x23,0x7F, 0xFD,0x23,0x7F, 0xFD,0x23,0xFF, 0xFC,0x44,0xFF,
// 1_ 3_ 5 5
0xFC,0x44,0x7F, 0xFD,0x23,0x7F, 0xFD,0x82,0xFF, 0xFD,0x82,0xFF,
// 4_ 3_ 2 -
0xFD,0x23,0x7F, 0xFD,0x23,0x7F, 0xFC,0xAC,0xFF, 0xFF,0xFF,0xFF,
// 2_ 3_ 4 4
0xFC,0xAC,0x7F, 0xFD,0x23,0x7F, 0xFD,0x34,0xFF, 0xFD,0x34,0xFF,
// 3_ 2_ 3 1
0xFD,0x23,0x7F, 0xFC,0xAC,0x7F, 0xFD,0x23,0xFF, 0xFC,0x44,0xFF,
// 1_ 3_ 2 .5
0xFC,0x44,0x7F, 0xFD,0x23,0x7F, 0xFC,0xAC,0xFF, 0xFA,0x68,0xFF,
// .7_ 2_ 1 -
0xFC,0x0C,0x7F, 0xFC,0xAC,0x7F, 0xFC,0x44,0xFF, 0xFF,0xFF,0xFF,
0x00//結束
void Init(void); //初始化函數
void DelayMs(unsigned int time); //毫秒級延時函數
        uchar time;
        Init();
        TH0 = high;
        TL0 = low;
        while (1)
                if (music[ptr] != 0xFF && music[ptr] != 0x00)//判斷是否是正常音符
                        TR0 = 0;
                        P2_3 = 1;
                        DelayMs(10); //間歇
                        TR0 = 1;
                        high = music[ptr]; //取設置頻率數值的高8 位
                        low = music[ptr + 1]; //取設置頻率數值的低8 位
                        time = music[ptr + 2]; //取發聲時間
                        DelayMs(time);
                        ptr += 3;
                else if (music[ptr] == 0xFF) //判斷是否是休止符
                        DelayMs(time);
                        ptr += 3;
                else //結束符,停止2 秒后繼續
                        TR0 = 0;
                        P2_3 = 1;
                        DelayMs(2000);
                        ptr = 0;
* 名稱:Count1(void) interrupt 1
* 功能:設置計時器0 溢出中斷,每中斷一次改變P2_3 引腳電平
void Count1(void) interrupt 1
        TH0 = high;
        TL0 = low;
        if (flag == 0) //改變P2_3 引腳電平
                P2_3 = 0;
                flag = 1;
                P2_3 = 1;
                flag = 0;
* 名稱:Init()
* 功能:設置計數器0 工作方式,16 位計數,溢出中斷方式
void Init()
        TMOD = 0x01; //定時器0 處于計時方式,16 位
        EA = 1;
        ET0 = 1; //定時器0 溢出中斷
* 名稱:DelayMs(unsigned int time)
* 功能:延時time * 1ms 時間
        unsigned int i;
        unsigned int j;
        for (j =0; j < time; j++) //每個循環 約 3ms
                for (i =0; i < 363; i++)
