查看: 4766|回復: 3
單片機數字時鐘制作,原理圖,PCB圖,實物圖,源代碼
ID:252889 發表于 2017-11-23 23:20 | 顯示全部樓層 |閱讀模式
這是我做的基于單片機的數字時鐘課程設計用AD10畫的原理圖 PCB圖
實物,代碼都是原創
在附件中,請大家多多指教。
制作出來的實物圖:
  1. #include <reg52.h>
  2. sbit k0=P1^0;
  3. sbit k1=P1^1;
  4. sbit k2=P1^2;
  5. unsigned char second,minute,hour,i,k,l,j,x,y;
  6. unsigned int n;
  7. unsigned char code mod[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,
  8. 0x7f,0x6f};
  9. timer0(void) interrupt 1
  10. {
  11. n++;
  12. TH0=0x3c;
  13. TL0=0xb0;
  14. }
  15. void delay()
  16. { unsigned int time,p;
  17.   for(time=30;time>0;time--)
  18.   for(p=0;p<10;p++);
  19. }
  20. void xianshi()
  21. {
  22. if(n==20)
  23. {
  24.   n=0;
  25.   second++;
  26.   while(second==60)
  27.   { second=0;
  28.     minute++;
  29.               if(minute==60)
  30.               {minute=0;
  31.               hour++;
  32.               if(hour==24)
  33.               {
  34.                 hour=0;
  35.                 }}}}
  36. x=hour%10;
  37. y=hour/10;
  38. l=minute%10;
  39. j=minute/10;
  40. i=second%10;
  41. k=second/10;P0=0x00;
  42. P2=0x01;
  43. P0=mod[i];
  44. delay();P0=0x00;
  45. P2=0x02;
  46. P0=mod[k];
  47. delay();P0=0x00;
  48. P2=0x04;
  49. P0=0x40;
  50. delay();P0=0x00;
  51. P2=0x08;
  52. P0=mod[l];
  53. delay();P0=0x00;
  54. P2=0x10;
  55. P0=mod[j];
  56. delay();P0=0x00;
  57. P2=0x20;
  58. P0=0x40;
  59. delay();P0=0x00;
  60. P2=0x40;
  61. P0=mod[x];
  62. delay();P0=0x00;
  63. P2=0x80;
  64. P0=mod[y];
  65. delay();P0=0x00;
  66. }
  67. void kongzhi()
  68. {if(k0==0)
  69. {TR0=0;
  70.   while(k0==0) xianshi();
  71.   delay();
  72.   while(k0==1)
  73.   {if(k1==0)
  74.    {minute++;
  75.     while(minute==60)
  76.               {minute=0;
  77.               }}
  78.    while(k1==0) xianshi();
  79.    if(k2==0)
  80.    {minute--;
  81.     while(minute==-1)
  82.               {minute=59;
  83.               }}
  84.               while(k2==0) xianshi();
  85.               xianshi();
  86.               }
  87.     if(k0==0)
  88.               {TR0=0;
  89.               while(k0==0) xianshi();
  90.               delay();
  91.               while(k0==1)
  92.               {if(k1==0)
  93.                 {hour++;
  94.                  while(hour==24)
  95.                  {hour=0;
  96.                  }}
  97.                 while(k1==0) xianshi();
  98.                 if(k2==0)
  99.                 {hour--;
  100.                  while(hour==-1)
  101.                  {hour=23;
  102.                  }}
  103.                  while(k2==0) xianshi();
  104.                  xianshi();
  105.                  }
  106.                             if(k0==0)
  107.                             {while(k0==0) xianshi();
  108.                             TR0=1;
  109. ……………………
  110. …………限于本文篇幅 余下代碼請從51黑下載附件…………
基于STC89C52的數字時鐘設計.docx (846.16 KB, 下載次數: 25)
ID:74992 發表于 2017-11-24 12:46 | 顯示全部樓層
沒有用時鐘芯片吧,這個走時準不準?
ID:253065 發表于 2017-11-24 15:02 | 顯示全部樓層
學習一下
ID:420652 發表于 2018-11-20 00:47 | 顯示全部樓層
怎么就這樣文檔啊,沒有原理圖和PCB的文件嗎
