查看: 2162|回復: 0
51單片機電子琴程序
ID:252574 發表于 2017-11-23 10:38 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include <reg52.h>
sbit BUZZ=P1^6;//蜂鳴器連續的IO口
unsigned char T1TH=0,T1TL=0;
unsigned char code song1[]={                  //兩只老虎
    0x14,0x14,0x24,0x34,0x14,0x14,0x24,0x34,0x14,
        0x34,0x44,0x58,0x34,0x44,0x58,
        0x53,0x61,0x53,0x41,0x34,0x14,
        0x14,0x54,0x18,
        0x14,0x54,0x18,
        0xFF          //歌曲結束標志
unsigned char code song2[]={                  //送別
    0x54,0x54,0x32,0x52,0x88,0x64,0x84,0x58,
        0x54,0x12,0x22,0x34,0x22,0x12,0x28,0x04,0x04,
        0x54,0x32,0x52,0x86,0x72,0x64,0x84,0x58,
        0x54,0x22,0x32,0x46,0xB2,0x18,0x04,0x04,
        0x64,0x84,0x88,0x74,0x62,0x72,0x88,
        0x62,0x72,0x82,0x62,0x62,0x52,0x32,0x12,0x28,0x04,0x04,
        0xFF
unsigned char code cuzhi[]={
    0xFF,0xFF,                //                          low                mid             high
        0xFC,0x44,                //1      ##  5 6 7  1 2 3 4 5 6 7  1 2 3
        0xFC,0xAC,                //2                 ##         D C B  1 2 3 4 5 6 7  8 9 A
        0xFD,0x09,                //3
        0xFD,0x34,                //4
        0xFD,0x82,                //5
        0xFD,0xC8,                //6
        0xFE,0x06,                //7
        0xFE,0x2A,                //8 --high 1         N = 470;
        0xFE,0x48,                //9 --hign 2         N = 440;
        0xFE,0x66,      //A --hign 3         N = 410;
        0xFC,0x0C                //B---low  7         N = 1012
void delay1ms(unsigned char z);        //延時1MS
void delay125ms(unsigned char z);        //延時165MS,即十六分音符
void sing();
main()
        EA=1;//開總中斷
    TMOD=0x10;//定時器1工作在方式1
        TH1=0;
        TL1=0;
        ET1=1;
                sing();
            delay1ms(1000);
void sing()
    unsigned char temp;
        unsigned char jianpu;
        unsigned int i = 0;
        static unsigned char thesong = 0;
                switch(thesong)
                   case 0:temp = song1[i];break;
                   case 1:temp = song2[i];break;
                   default:break;
                if(temp == 0xFF)
                  break;
                jianpu = (temp>>4); //取數的高4位
                if(jianpu != 0)                //不是休止符
                  T1TH = cuzhi[jianpu*2];
                  T1TL = cuzhi[jianpu*2+1];
                }               //查表找初值
                else                        //jp = 0,休止符
                  { TR1 = 0;BUZZ = 1; }        //關蜂鳴器
                delay125ms( temp & 0x0F ); //取數的低4位
                TR1 = 0;         //唱完一個音停10MS
                BUZZ = 1;
                delay1ms(10);
                TR1 = 1;
                i++;
        TR1 = 0;
        BUZZ = 1;
        thesong++;
        if(thesong >=2)
           thesong = 0;
void delay125ms(unsigned char z)        //延時165MS,即十六分音符
    unsigned int x,y;
        for(x=z;x>0;x--)
                 for(y=15000;y>0;y--);
void delay1ms(unsigned char z)        //延時1MS
    unsigned int x,y;
        for(x=z;x>0;x--)
                 for(y=112;y>0;y--);
void timer1() interrupt 3         //用于產生各種音調
        TH1=T1TH;
        TL1=T1TL;
    BUZZ = ~BUZZ;
