查看: 2077|回復: 1
單片機8位數據翻轉函數
ID:252527 發表于 2017-11-23 00:44 | 只看該作者 回帖獎勵 |正序瀏覽 |閱讀模式
unsigned char swap(unsigned char data)
        unsigned char buffer;
        unsigned char a;
        buffer = 0;
        for(a=0;a<8;a++)
                if(data&0x01)
                        buffer = buffer | 0x01;
                        if(a<7)buffer = buffer << 1;
                        data = data >> 1;
                        buffer = buffer & 0xfe;
                        data = data >> 1;
        return buffer;
例如數據
0101 0100   (0x54)
翻轉
0010 1010    (0x2a)
ID:248503 發表于 2017-11-23 11:49 | 只看該作者
        unsigned char a, buffer=0;
        for(a=0;a<8;a++)
                if(data&0x01)
                        buffer = buffer | 0x01<<(7-a);
                        data = data >> 1;
        return buffer;
