查看: 1263|回復: 1
stm32 俯仰角
ID:239419 發表于 2017-11-20 18:55 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
  • #include "stm32f10x_lib.h"
  • #include  <math.h>    //Keil library
  • GPIO_InitTypeDef GPIO_InitStructure;
  • ErrorStatus HSEStartUpStatus;
  • #define   uchar unsigned char
  • #define   uint unsigned int
  • // 定義MPU6050內部地址
  • #define        SMPLRT_DIV                0x19        //陀螺儀采樣率,典型值:0x07(125Hz)
  • #define        CONFIG                        0x1A        //低通濾波頻率,典型值:0x06(5Hz)
  • #define        GYRO_CONFIG                0x1B        //陀螺儀自檢及測量范圍,典型值:0x18(不自檢,2000deg/s)
  • #define        ACCEL_CONFIG        0x1C        //加速計自檢、測量范圍及高通濾波頻率,典型值:0x01(不自檢,2G,5Hz)
  • #define        ACCEL_XOUT_H        0x3B
  • #define        ACCEL_XOUT_L        0x3C
  • #define        ACCEL_YOUT_H        0x3D
  • #define        ACCEL_YOUT_L        0x3E
  • #define        ACCEL_ZOUT_H        0x3F
  • #define        ACCEL_ZOUT_L        0x40
  • #define        TEMP_OUT_H                0x41
  • #define        TEMP_OUT_L                0x42
  • #define        GYRO_XOUT_H                0x43
  • #define        GYRO_XOUT_L                0x44
  • #define        GYRO_YOUT_H                0x45
  • #define        GYRO_YOUT_L                0x46
  • #define        GYRO_ZOUT_H                0x47
  • #define        GYRO_ZOUT_L                0x48
  • #define        PWR_MGMT_1                0x6B        //電源管理,典型值:0x00(正常啟用)
  • #define        WHO_AM_I                0x75        //IIC地址寄存器(默認數值0x68,只讀)
  • #define        MPU6050_Addr   0xD0          //定義器件在IIC總線中的從地址,根據ALT  ADDRESS地址引腳不同修改
  • unsigned char TX_DATA[4];           //顯示據緩存區
  • unsigned char BUF[10];       //接收數據緩存區
  • char  test=0;                                  //IIC用到
  • short T_X,T_Y,T_Z,T_T;                 //X,Y,Z軸,溫度
  • /*模擬IIC端口輸出輸入定義*/
  • #define SCL_H         GPIOB->BSRR = GPIO_Pin_6
  • #define SCL_L         GPIOB->BRR  = GPIO_Pin_6
  • #define SDA_H         GPIOB->BSRR = GPIO_Pin_7
  • #define SDA_L         GPIOB->BRR  = GPIO_Pin_7
  • #define SCL_read      GPIOB->IDR  & GPIO_Pin_6
  • #define SDA_read      GPIOB->IDR  & GPIO_Pin_7
  • /* 函數申明 -----------------------------------------------*/
  • void RCC_Configuration(void);
  • void GPIO_Configuration(void);
  • void NVIC_Configuration(void);
  • void USART1_Configuration(void);
  • void WWDG_Configuration(void);
  • void Delay(u32 nTime);
  • void Delayms(vu32 m);
  • /* 變量定義 ----------------------------------------------*/
  • void DATA_printf(uchar *s,short temp_data)
  •         if(temp_data<0){
  •         temp_data=-temp_data;
  •     *s='-';
  •         else *s=' ';
  •     *++s =temp_data/100+0x30;
  •     temp_data=temp_data%100;     //取余運算
  •     *++s =temp_data/10+0x30;
  •     temp_data=temp_data%10;      //取余運算
  •     *++s =temp_data+0x30;
  • * Function Name  : I2C_GPIO_Config
  • * Description    : Configration Simulation IIC GPIO
  • * Input          : None
  • * Output         : None
  • * Return         : None
  • void I2C_GPIO_Config(void)
  •   GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_6;
  •   GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;
  •   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_Out_OD;
  •   GPIO_Init(GPIOB, &GPIO_InitStructure);
  •   GPIO_InitStructure.GPIO_Pin =  GPIO_Pin_7;
  • * Function Name  : I2C_delay
  • * Description    : Simulation IIC Timing series delay
  • * Input          : None
  • * Output         : None
  • * Return         : None
  • void I2C_delay(void)
  •    u8 i=30; //這里可以優化速度        ,經測試最低到5還能寫入
  •    while(i)
  •      i--;
  • void delay5ms(void)
  •    int i=5000;
  •    while(i)
  •      i--;
  • * Function Name  : I2C_Start
  • * Description    : Master Start Simulation IIC Communication
  • * Input          : None
  • * Output         : None
  • * Return         : Wheather         Start
  • bool I2C_Start(void)
  •         SDA_H;
  •         SCL_H;
  •         I2C_delay();
  •         if(!SDA_read)return FALSE;        //SDA線為低電平則總線忙,退出
  •         SDA_L;
  •         I2C_delay();
  •         if(SDA_read) return FALSE;        //SDA線為高電平則總線出錯,退出
  •         SDA_L;
  •         I2C_delay();
  •         return TRUE;
  • * Function Name  : I2C_Stop
  • * Description    : Master Stop Simulation IIC Communication
  • * Input          : None
  • * Output         : None
  • * Return         : None
  • void I2C_Stop(void)
  •         SCL_L;
  •         I2C_delay();
  •         SDA_L;
  •         I2C_delay();
  •         SCL_H;
  •         I2C_delay();
  •         SDA_H;
  •         I2C_delay();
  • * Function Name  : I2C_Ack
  • * Description    : Master Send Acknowledge Single
  • * Input          : None
  • * Output         : None
  • * Return         : None
  • void I2C_Ack(void)
  •         SCL_L;
  •         I2C_delay();
  •         SDA_L;
  •         I2C_delay();
  •         SCL_H;
  •         I2C_delay();
  •         SCL_L;
  •         I2C_delay();
  • * Function Name  : I2C_NoAck
  • * Description    : Master Send No Acknowledge Single
  • * Input          : None
  • * Output         : None
  • * Return         : None
  • void I2C_NoAck(void)
  •         SCL_L;
  •         I2C_delay();
  •         SDA_H;
  •         I2C_delay();
  •         SCL_H;
  •         I2C_delay();
  •         SCL_L;
  •         I2C_delay();
  • * Function Name  : I2C_WaitAck
  • * Description    : Master Reserive Slave Acknowledge Single
  • * Input          : None
  • * Output         : None
  • * Return         : Wheather         Reserive Slave Acknowledge Single
  • bool I2C_WaitAck(void)          //返回為:=1有ACK,=0無ACK
  •         SCL_L;
  •         I2C_delay();
  •         SDA_H;
  •         I2C_delay();
  •         SCL_H;
  •         I2C_delay();
  •         if(SDA_read)
  •       SCL_L;
  •           I2C_delay();
  •       return FALSE;
  •         SCL_L;
  •         I2C_delay();
  •         return TRUE;
  • * Function Name  : I2C_SendByte
  • * Description    : Master Send a Byte to Slave
  • * Input          : Will Send Date
  • * Output         : None
  • * Return         : None
  • void I2C_SendByte(u8 SendByte) //數據從高位到低位//
  •     u8 i=8;
  •     while(i--)
  •         SCL_L;
  •         I2C_delay();
  •       if(SendByte&0x80)
  •         SDA_H;
  •       else
  •         SDA_L;
  •         SendByte<<=1;
  •         I2C_delay();
  •                 SCL_H;
  •         I2C_delay();
  •     SCL_L;
  • * Function Name  : I2C_RadeByte
  • * Description    : Master Reserive a Byte From Slave
  • * Input          : None
  • * Output         : None
  • * Return         : Date From Slave
  • unsigned char I2C_RadeByte(void)  //數據從高位到低位//
  •     u8 i=8;
  •     u8 ReceiveByte=0;
  •     SDA_H;
  •     while(i--)
  •       ReceiveByte<<=1;
  •       SCL_L;
  •       I2C_delay();
  •           SCL_H;
  •       I2C_delay();
  •       if(SDA_read)
  •         ReceiveByte|=0x01;
  •     SCL_L;
  •     return ReceiveByte;
  • //ZRX
  • //單字節寫入*******************************************
  • bool Single_Write(unsigned char SlaveAddress,unsigned char REG_Address,unsigned char REG_data)                     //void
  •           if(!I2C_Start())return FALSE;
  •     I2C_SendByte(SlaveAddress);   //發送設備地址+寫信號//I2C_SendByte(((REG_Address & 0x0700) >>7) | SlaveAddress & 0xFFFE);//設置高起始地址+器件地址
  •     if(!I2C_WaitAck()){I2C_Stop(); return FALSE;}
  •     I2C_SendByte(REG_Address );   //設置低起始地址
  •     I2C_WaitAck();
  •     I2C_SendByte(REG_data);
  •     I2C_WaitAck();
  •     I2C_Stop();
  •     delay5ms();
  •     return TRUE;
  • //單字節讀取*****************************************
  • unsigned char Single_Read(unsigned char SlaveAddress,unsigned char REG_Address)
  • {   unsigned char REG_data;
  •     I2C_SendByte(SlaveAddress); //I2C_SendByte(((REG_Address & 0x0700) >>7) | REG_Address & 0xFFFE);//設置高起始地址+器件地址
  •     if(!I2C_WaitAck()){I2C_Stop();test=1; return FALSE;}
  •     I2C_SendByte((u8) REG_Address);   //設置低起始地址
  •     I2C_WaitAck();
  •     I2C_Start();
  •     I2C_SendByte(SlaveAddress+1);
  •     I2C_WaitAck();
  •         REG_data= I2C_RadeByte();
  •     I2C_NoAck();
  •     I2C_Stop();
  •     //return TRUE;
  •         return REG_data;
  • ** 函數名稱 : RCC_Configuration(void)
  • ** 函數功能 : 時鐘初始化
  • ** 輸    入        : 無
  • ** 輸    出        : 無
  • ** 返    回        : 無
  •   /* RCC system reset(for debug purpose) */
  •   RCC_DeInit();
  •   /* Enable HSE */
  •   RCC_HSEConfig(RCC_HSE_ON);
  •   /* Wait till HSE is ready */
  •   HSEStartUpStatus = RCC_WaitForHSEStartUp();
  •   if(HSEStartUpStatus == SUCCESS)
  •     /* HCLK = SYSCLK */
  •     RCC_HCLKConfig(RCC_SYSCLK_Div1);
  •     /* PCLK2 = HCLK */
  •     RCC_PCLK2Config(RCC_HCLK_Div1);
  •     /* PCLK1 = HCLK/2 */
  •     RCC_PCLK1Config(RCC_HCLK_Div2);
  •     /* Flash 2 wait state */
  •     FLASH_SetLatency(FLASH_Latency_2);
  •     /* Enable Prefetch Buffer */
  •     FLASH_PrefetchBufferCmd(FLASH_PrefetchBuffer_Enable);
  •     /* PLLCLK = 8MHz * 9 = 72 MHz */
  •     RCC_PLLConfig(RCC_PLLSource_HSE_Div1, RCC_PLLMul_9);
  •     /* Enable PLL */
  •     RCC_PLLCmd(ENABLE);
  •     /* Wait till PLL is ready */
  •     while(RCC_GetFlagStatus(RCC_FLAG_PLLRDY) == RESET)
  •     /* Select PLL as system clock source */
  •     RCC_SYSCLKConfig(RCC_SYSCLKSource_PLLCLK);
  •     /* Wait till PLL is used as system clock source */
  •     while(RCC_GetSYSCLKSource() != 0x08)
  •    /* Enable GPIOA, GPIOB, GPIOC, GPIOD, GPIOE, GPIOF, GPIOG and AFIO clocks */
  •     RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOB , ENABLE);
  •         RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOC | RCC_APB2Periph_GPIOD , ENABLE);
  •         RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOE | RCC_APB2Periph_GPIOF , ENABLE);
  •         RCC_APB2PeriphClockCmd(RCC_APB2Periph_GPIOG | RCC_APB2Periph_AFIO  , ENABLE);
  • ** 函數名稱 : GPIO_Configuration(void)
  • ** 函數功能 : 端口初始化
  • ** 輸    入        : 無
  • ** 輸    出        : 無
  • ** 返    回        : 無
  •   RCC_APB2PeriphClockCmd( RCC_APB2Periph_GPIOA | RCC_APB2Periph_GPIOB | RCC_APB2Periph_GPIOC | RCC_APB2Periph_GPIOD, ENABLE  );
  •    /* Configure USART1 Tx (PA.09) as alternate function push-pull */
  •   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_9;                                 //        選中管腳9
  •   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_AF_PP;                 // 復用推挽輸出
  •   GPIO_InitStructure.GPIO_Speed = GPIO_Speed_50MHz;                 // 最高輸出速率50MHz
  •   GPIO_Init(GPIOA, &GPIO_InitStructure);                                 // 選擇A端口
  •   /* Configure USART1 Rx (PA.10) as input floating */
  •   GPIO_InitStructure.GPIO_Pin = GPIO_Pin_10;                          //選中管腳10
  •   GPIO_InitStructure.GPIO_Mode = GPIO_Mode_IN_FLOATING;          //浮空輸入
  •   GPIO_Init(GPIOA, &GPIO_InitStructure);                                  //選擇A端口
  • ** 函數名稱 : USART1_Configuration(void)
  • ** 函數功能 : 串口1初始化
  • ** 輸    入        : 無
  • ** 輸    出        : 無
  • ** 返    回        : 無
  • USART_InitTypeDef USART_InitStructure;
  • USART_ClockInitTypeDef  USART_ClockInitStructure;
  • RCC_APB2PeriphClockCmd(RCC_APB2Periph_TIM1 |RCC_APB2Periph_USART1, ENABLE  );
  • USART_ClockInitStructure.USART_Clock = USART_Clock_Disable;                        // 時鐘低電平活動
  • USART_ClockInitStructure.USART_CPOL = USART_CPOL_Low;                                // 時鐘低電平
  • USART_ClockInitStructure.USART_CPHA = USART_CPHA_2Edge;                                // 時鐘第二個邊沿進行數據捕獲
  • USART_ClockInitStructure.USART_LastBit = USART_LastBit_Disable;                // 最后一位數據的時鐘脈沖不從SCLK輸出
  • /* Configure the USART1 synchronous paramters */
  • USART_ClockInit(USART1, &USART_ClockInitStructure);                                        // 時鐘參數初始化設置
  • USART_InitStructure.USART_BaudRate = 115200;                                                  // 波特率為:115200
  • USART_InitStructure.USART_WordLength = USART_WordLength_8b;                          // 8位數據
  • USART_InitStructure.USART_StopBits = USART_StopBits_1;                                  // 在幀結尾傳輸1個停止位
  • USART_InitStructure.USART_Parity = USART_Parity_No ;                                  // 奇偶失能
  • USART_InitStructure.USART_HardwareFlowControl = USART_HardwareFlowControl_None;        // 硬件流控制失能
  • USART_InitStructure.USART_Mode = USART_Mode_Rx | USART_Mode_Tx;                  // 發送使能+接收使能
  • /* Configure USART1 basic and asynchronous paramters */
  • USART_Init(USART1, &USART_InitStructure);
  •   /* Enable USART1 */
  • USART_ClearFlag(USART1, USART_IT_RXNE);                         //清中斷,以免一啟用中斷后立即產生中斷
  • USART_ITConfig(USART1,USART_IT_RXNE, ENABLE);                //使能USART1中斷源
  • USART_Cmd(USART1, ENABLE);                                                        //USART1總開關:開啟
  • ** 函數名稱 : NVIC_Configuration(void)
  • ** 函數功能 : 中斷初始化
  • ** 輸    入        : 無
  • ** 輸    出        : 無
  • ** 返    回        : 無
  •   NVIC_InitTypeDef NVIC_InitStructure;
  •   NVIC_PriorityGroupConfig(NVIC_PriorityGroup_0);
  •   NVIC_InitStructure.NVIC_IRQChannel = WWDG_IRQChannel;
  •   NVIC_InitStructure.NVIC_IRQChannelPreemptionPriority = 0;
  •   NVIC_Init(&NVIC_InitStructure);
  • ** 函數名稱 : WWDG_Configuration(void)
  • ** 函數功能 : 看門狗初始化
  • ** 輸    入        : 無
  • ** 輸    出        : 無
  • ** 返    回        : 無
  •   RCC_APB1PeriphClockCmd(RCC_APB1Periph_WWDG, ENABLE);
  •   WWDG_SetPrescaler(WWDG_Prescaler_8);                      //  WWDG clock counter = (PCLK1/4096)/8 = 244 Hz (~4 ms)
  •   WWDG_SetWindowValue(0x41);                                 // Set Window value to 0x41
  •   WWDG_Enable(0x50);                       // Enable WWDG and set counter value to 0x7F, WWDG timeout = ~4 ms * 64 = 262 ms
  •   WWDG_ClearFlag();                               // Clear EWI flag
  •   WWDG_EnableIT();                               // Enable EW interrupt
  • ** 函數名稱 : Delay(vu32 nCount)
  • ** 函數功能 : 延時函數
  • ** 輸    入        : 無
  • ** 輸    出        : 無
  • ** 返    回        : 無
  • void Delay(vu32 nCount)
  •   for(; nCount != 0; nCount--);
  • ** 函數名稱 : void Delayms(vu32 m)
  • ** 函數功能 : 長延時函數         m=1,延時1ms
  • ** 輸    入        : 無
  • ** 輸    出        : 無
  • ** 返    回        : 無
  •   u32 i;
  •   for(; m != 0; m--)
  •        for (i=0; i<50000; i++);
  • ** 函數名稱 : WWDG_IRQHandler(void)
  • ** 函數功能 : 窗口提前喚醒中斷
  • ** 輸    入        : 無
  • ** 輸    出        : 無
  • ** 返    回        : 無
  • void WWDG_IRQHandler(void)
  •   /* Update WWDG counter */
  •   WWDG_SetCounter(0x50);
  •   /* Clear EWI flag */
  •   WWDG_ClearFlag();
  • void  USART1_SendData(uchar SendData)
  • USART_SendData(USART1, SendData);
  • Delayms(1);
  • //初始化MPU6050,根據需要請參考pdf進行修改************************
  • void Init_MPU6050(void)
  •    Single_Write(MPU6050_Addr,PWR_M, 0x80);   //
  •    Single_Write(MPU6050_Addr,SMPL, 0x07);    //
  •    Single_Write(MPU6050_Addr,DLPF, 0x1E);    //±2000°
  •    Single_Write(MPU6050_Addr,INT_C, 0x00 );  //
  •    Single_Write(MPU6050_Addr,PWR_M, 0x00);   //
  •            Single_Write(MPU6050_Addr,PWR_MGMT_1, 0x00);        //解除休眠狀態
  •         Single_Write(MPU6050_Addr,SMPLRT_DIV, 0x07);
  •         Single_Write(MPU6050_Addr,CONFIG, 0x06);
  •         Single_Write(MPU6050_Addr,GYRO_CONFIG, 0x18);
  •         Single_Write(MPU6050_Addr,ACCEL_CONFIG, 0x01);
  • //******讀取MPU6050數據****************************************
  • void READ_MPU6050(void)
  •    BUF[0]=Single_Read(MPU6050_Addr,GYRO_XOUT_L);
  •    BUF[1]=Single_Read(MPU6050_Addr,GYRO_XOUT_H);
  •    T_X=        (BUF[1]<<8)|BUF[0];
  •    T_X/=16.4;                                                    //讀取計算X軸數據
  •    BUF[2]=Single_Read(MPU6050_Addr,GYRO_YOUT_L);
  •    BUF[3]=Single_Read(MPU6050_Addr,GYRO_YOUT_H);
  •    T_Y=        (BUF[3]<<8)|BUF[2];
  •    T_Y/=16.4;                                                    //讀取計算Y軸數據
  •    BUF[4]=Single_Read(MPU6050_Addr,GYRO_ZOUT_L);
  •    BUF[5]=Single_Read(MPU6050_Addr,GYRO_ZOUT_H);
  •    T_Z=        (BUF[5]<<8)|BUF[4];
  •    T_Z/=16.4;                                                //讀取計算Z軸數據
  •   // BUF[6]=Single_Read(MPU6050_Addr,TEMP_OUT_L);
  •   // BUF[7]=Single_Read(MPU6050_Addr,TEMP_OUT_H);
  •   // T_T=(BUF[7]<<8)|BUF[6];
  •   // T_T = 35+ ((double) (T_T + 13200)) / 280;// 讀取計算出溫度
  • //********串口發送數據***************************************
  • void Send_data(uchar axis)
  • {uchar i;
  •   USART1_SendData(axis);
  •   USART1_SendData(':');
  •   for(i=0;i<4;i++)USART1_SendData(TX_DATA);
  •   USART1_SendData(' ');
  • ** 函數名稱 : main(void)
  • ** 函數功能 : 主函數
  • ** 輸    入        : 無
  • ** 輸    出        : 無
  • ** 返    回        : 無
  • int main(void)
  •   RCC_Configuration();                 //配置RCC
  •   GPIO_Configuration();                 //配置GPIO
  •   USART1_Configuration();         //配置串口1
  •   I2C_GPIO_Config();                 //配置IIC使用端口
  •   Delayms(10);                                 //延時
  •   Init_MPU6050();                     //初始化MPU6050
  •   while(1)
  •         READ_MPU6050();                 //讀取MPU6050數據
  •     DATA_printf(TX_DATA,T_X);//轉換X軸數據到數組
  •         Send_data('X');                         //發送X軸數
  •         DATA_printf(TX_DATA,T_Y);//轉換Y軸數據到數組
  •         Send_data('Y');                         //發送Y軸數
  •         DATA_printf(TX_DATA,T_Z);//轉換Z軸數據到數組
  •         Send_data('Z');                         //發送Z軸數
  •         DATA_printf(TX_DATA,T_T);//轉換溫度數據到數組
  •         Send_data('T');                         //發送溫度數據
  •         USART1_SendData(0X0D);         //換行
  •         USART1_SendData(0X0A);         //回車
  •         Delayms(5);                                 //延時
  • /*************結束***************/
不錯,有點意思
