查看: 4534|回復: 3
pwm信號讀不出來 求解救
ID:250933 發表于 2017-11-19 11:03 | 顯示全部樓層 |閱讀模式
20黑幣
我再做一個帆板控制系統的設計,做到這里卡住了!這個設計主要功能是:用風扇吹動帆板,并測量帆板的角度;風扇用pwm控速,鍵盤輸入pwm大小,
角速度傳感器子程序運行正常!
12864子程序運行正常
只有pwm控制程序出錯,pwm信號到不了定時器里面!
求各位大神幫幫忙!
20黑幣懸賞!!!
目錄
目錄
問題
問題
51.zip
82.44 KB, 下載次數: 2
程序包
ID:250933 發表于 2017-11-19 11:05 | 顯示全部樓層
使用的stc89c52單片機 c語言編程
ID:250933 發表于 2017-11-19 14:17 | 顯示全部樓層
#include<reg52.h>
#include "control.h"
#include "12864.h"
sbit A1=P2^2;
sbit A2=P2^3;
sbit ENA=P2^4;
signed int count=0;
unsigned char pwm=100;
unsigned char anjian=0;
uchar numshi=0;
uchar numge=0;
void anjian_dis()
        numshi=anjian/10;
        numge=anjian%10;
        write_12864_data(0x30+numshi);
        write_12864_data(0x30+numge);
void delayms(unsigned int xms)
        unsigned int i,j;
        for(i=0;i<xms;i++)
                for(j=0;j<110;j++);
void keyscan_1()
                unsigned char dat=0;
                unsigned char num=0;
                        P1=0xfe;
                        dat=P1;
                        dat=dat&0xf0;
                        while(dat!=0xf0)
                                        delayms(10);
                                        dat=P1;
                                        dat=dat&0xf0;
                                        while(dat!=0xf0)
                                                dat=P1;
                                        switch(dat)
                                                        case 0xee:num=1;
        break;
                                                        case 0xde:num=2;
        break;
                                                        case 0xbe:num=3;
        break;
                                                        case 0x7e:num=4;
        break;
                                        while(dat!=0xf0)
                                                        dat=P1;
                                                        dat=dat&0xf0;
                        P1=0xfd;
                        dat=P1;
                        dat=dat&0xf0;
                        while(dat!=0xf0)
                                        delayms(10);
                                        dat=P1;
                                        dat=dat&0xf0;
                                        while(dat!=0xf0)
                                                dat=P1;
                                        switch(dat)
                                                        case 0xed:num=5;
        break;
                                                        case 0xdd:num=6;
        break;
                                                        case 0xbd:num=7;
        break;
                                                        case 0x7d:num=8;
        break;
                                        while(dat!=0xf0)
                                                        dat=P1;
                                                        dat=dat&0xf0;
                        P1=0xfb;
                        dat=P1;
                        dat=dat&0xf0;
                        while(dat!=0xf0)
                                        delayms(10);
                                        dat=P1;
                                        dat=dat&0xf0;
                                        while(dat!=0xf0)
                                                dat=P1;
                                        switch(dat)
                                                        case 0xeb:num=9;
        break;
                                                        case 0xdb:num=10;
        break;
                                                        case 0xbb:num=11;
        break;
                                                        case 0x7b:num=12;
        break;
                                        while(dat!=0xf0)
                                                        dat=P1;
                                                        dat=dat&0xf0;
                        P1=0xf7;
                        dat=P1;
                        dat=dat&0xf0;
                        while(dat!=0xf0)
                                        delayms(10);
                                        dat=P1;
                                        dat=dat&0xf0;
                                        while(dat!=0xf0)
                                                dat=P1;
                                        switch(dat)
                                                        case 0xe7:num=13;
        break;
                                                        case 0xd7:num=14;
        break;
                                                        case 0xb7:num=15;
        break;
                                                        case 0x77:num=16;
        break;
                                        while(dat!=0xf0)
                                                        dat=P1;
                                                        dat=dat&0xf0;
                switch(num)
                case 1:write_12864_addr(1,3);
                                anjian=0;
                                pwm=0;
                                anjian_dis();
                                break;
                case 2:write_12864_addr(1,3);
                                anjian=10;
                                pwm=100;
                                anjian_dis();
                                break;
                case 3:write_12864_addr(1,3);
                                anjian=20;
                                pwm=20;
                                anjian_dis();
                                break;
                case 4:write_12864_addr(1,3);
                                anjian=30;
                                pwm=30;
                                anjian_dis();
                                break;
                case 5:write_12864_addr(1,3);
                                anjian=40;
                                pwm=40;
                                anjian_dis();
                                break;
                case 6:write_12864_addr(1,3);
                                anjian=50;
                                pwm=50;
                                anjian_dis();
                                break;
                case 7:write_12864_addr(1,3);
                                anjian=60;
                                pwm=60;
                                anjian_dis();
                                break;
                case 13:pwm=pwm+5;
                                break;
                case 14:pwm=pwm-5;
                                break;
                case 15:pwm=pwm+1;
                                break;
                case 16:pwm=pwm-1;
                                break;
                default:break;
void timer0() interrupt 3
        TH1=(65535-1000)/256;
        TL1=(65535-1000)%256;
        count++;
        if(count>=100)
        count=0;
        if(count<=pwm)
                ENA=1;
                A1=0;
                A2=1;
                ENA=0;
                A1=0;
                A2=1;
        TR1=1;
ID:251083 發表于 2017-11-19 15:34 | 顯示全部樓層
把中斷里的判斷拿出來試試
