查看: 6362|回復: 6
51單片機八路搶答器程序和仿真 壓縮包
  1. #include <REGX51.H>
  2. #define  Keytimer_1        10
  3. sbit K0=P3^0;
  4. sbit K1=P1^0;sbit K2=P1^1;sbit K3=P1^2;sbit K4=P1^3;
  5. sbit K5=P1^4;sbit K6=P1^5;sbit K7=P1^6;sbit K8=P1^7;
  6. sbit A575=P2^0;         sbit B575=P2^1; sbit C575=P2^2;
  7. sbit BZ=P2^3;
  8. unsigned int Keytimer=0,t=0,sec=60,OK=0,hh=0,sec1=0;
  9. unsigned char DM[11]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,0x07,0x7f,0x6f,0x40};  //8個數碼管段碼表
  10. unsigned char WE[4]={0x01,0x02,0x04,0x08};  //8個數碼管段碼表
  11. void flang();
  12. /*------------------------------------------------
  13.            公用延遲函數
  14. ------------------------------------------------*/
  15. void delayus(unsigned int y)
  16. {
  17.         while(y--);
  18. }
  19. //*****************定時器初始化**************************
  20. void initialize(void)
  21. {
  22.         TMOD =0x01;
  23.         TH0 = 0x3C;
  24.         TL0 = 0xB0;           //50ms
  25.         ET0 = 1;
  26.         EA = 1;
  27.         TR0 = 1;
  28. }
  29. /*------------------------------------------------
  30.            8位數碼管 指針 顯示函數
  31. ------------------------------------------------*/
  32. void shumaxianshi()
  33. {
  34.         unsigned char i,ii=2,tempP[4];
  35.         if(OK==2)
  36.         {ii=4;flang();
  37.         tempP[0] = sec1/10%10;
  38.         tempP[1]=sec1%10;
  39.         }
  40.         else
  41.         {tempP[0] = sec/10%10;
  42.         tempP[1]=sec%10;}
  43.         tempP[2]=hh/10%10;
  44.         tempP[3] = hh %10;
  45.         for(i=0;i<ii;i++)
  46.         {
  47.                 P0=DM[tempP[i]];        //指針賦值
  48.                 A575=1;A575=0;
  49.                 delayus(4);
  50.                 P0=~WE[i];
  51.                 B575=1;B575=0;
  52.                 delayus(4);        //最低限制
  53.                 P0=0xff;
  54.                 B575=1;B575=0;
  55.         }
  56. }
  57. unsigned char KES()
  58. {
  59.         if(K1==1&&K2==1&&K3==1&&K4==1&&K5==1&&K6==1&&K7==1&&K8==1&&K0==1)        //沒有按的時候  返回    加快 51 跑的速度
  60.         return 0;
  61.         if(K0==0 && !Keytimer)
  62.         {
  63.                 Keytimer=Keytimer_1;
  64.                 return 9;
  65.         }
  66.         if(K1==0 && !Keytimer)
  67.         {
  68.                 Keytimer=Keytimer_1;
  69.                 return 1;
  70.         }
  71.         if(K2==0 && !Keytimer)
  72.         {
  73.                 Keytimer=Keytimer_1;
  74.                 return 2;
  75.         }
  76.         if(K3==0 && !Keytimer)
  77.         {
  78.                 Keytimer=Keytimer_1;
  79.                 return 3;
  80.         }
  81.         if(K4==0 && !Keytimer)
  82.         {
  83.                 Keytimer=Keytimer_1;
  84.                 return 4;
  85.         }
  86.         if(K5==0 && !Keytimer)
  87.         {
  88.                 Keytimer=Keytimer_1;
  89.                 return 5;
  90.         }
  91.         if(K6==0 && !Keytimer)
  92.         {
  93.                 Keytimer=Keytimer_1;
  94.                 return 6;
  95.         }
  96.         if(K7==0 && !Keytimer)
  97.         {
  98.                 Keytimer=Keytimer_1;
  99.                 return 7;
  100.         }
  101.         if(K8==0 && !Keytimer)
  102.         {
  103.                 Keytimer=Keytimer_1;
  104.                 return 8;
  105.         }
  106.                 return 0;
  107. }
  108. void main()
  109. {
  110.         unsigned char yh;
  111.         BZ=1;
  112.         A575=B575=C575=0;
  113.         P0=0x00;
  114.         C575=1;C575=0;
  115.         initialize();
  116.         while(1)
  117.         {
  118.                 yh=KES();
  119.                 if(yh==9)
  120.                 {
  121.                         OK++;
  122.                         if(OK==3){OK=0;sec=60,sec1=t=0;P0=0x00;
  123.                                                 C575=1;C575=0;BZ=1;
  124.                                         }
  125.                 }
  126.                 else if(OK==1 && yh>=1)
  127.                 {
  128.                         OK=2;
  129.                         hh=yh;
  130.                         if(yh==1)
  131.                         {
  132.                                 P0=0x01;
  133.                                 C575=1;C575=0;
  134.                         }
  135.                         else if(yh==2)
  136.                                 {
  137.                                         P0=0x02;
  138.                                         C575=1;C575=0;
  139.                                 }
  140.                         else if(yh==3)
  141.                                 {
  142.                                         P0=0x04;
  143.                                         C575=1;C575=0;
  144.                                 }
  145.                         else if(yh==4)
  146.                                 {
  147.                                         P0=0x08;
  148.                                         C575=1;C575=0;
  149.                                 }
  150.                         else if(yh==5)
  151.                                 {
  152.                                         P0=0x10;
  153.                                         C575=1;C575=0;
  154.                                 }
  155.                         else if(yh==6)
  156.                                 {
  157.                                         P0=0x20;
  158.                                         C575=1;C575=0;
  159.                                 }
  160.                         else if(yh==7)
  161.                                 {
  162.                                         P0=0x40;
  163.                                         C575=1;C575=0;
  164.                                 }
  165.                         else if(yh==8)
  166.                                 {
  167.                                         P0=0x80;
  168.                                         C575=1;C575=0;
  169.                                 }
  170.                 }
  171.           shumaxianshi();
  172.         }
  173. }
  174. void Timer0(void) interrupt 1
  175. ……………………
  176. …………限于本文篇幅 余下代碼請從51黑下載附件…………
八路搶答器.rar (165.37 KB, 下載次數: 80)
收藏收藏2 分享淘帖 頂 踩
ID:447972 發表于 2018-12-17 14:33 | 只看該作者
真棒!
ID:464414 發表于 2019-1-8 10:48 來自觸屏版 | 只看該作者
謝謝!!!!!!!
ID:464590 發表于 2019-1-8 16:31 | 只看該作者
謝謝!
ID:464590 發表于 2019-1-8 16:55 | 只看該作者
謝謝!!!!!!!!!!!!!!!!
ID:99800 發表于 2019-1-23 18:54 | 只看該作者
很棒不過有一個問題,中斷里執行類似加分的程序可以嗎
ID:99800 發表于 2019-1-23 18:55 | 只看該作者
很棒,不過有一個問題,中斷里執行類似加分的程序可以嗎,統計選手積分
