查看: 2674|回復: 1
1602液晶中的時間程序,秒表怎么通過按鍵加
ID:244748 發表于 2017-11-17 21:45 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
# include <reg52.h>
# define uchar unsigned char
# define uint unsigned int
sbit        P_HC595_SER   = P2^7;        //pin 14        SER                data input
sbit        P_HC595_RCLK  = P2^5;        //pin 12        RCLk        store (latch) clock
sbit        P_HC595_SRCLK = P2^6;        //pin 11        SRCLK        Shift data clock
sbit lcden = P3^4;
sbit rs = P3^5;
sbit wr = P3^6;
sbit s5 = P3^0;
sbit s10 = P3^1;
sbit s15 = P3^2;
sbit s20 = P3^3;
uchar code dage[] = "2017-11-17   FRI";
uchar code dage1[] = "   23: 59: 39";
void init();
void delay(uint);
void write_com(uchar);
void write_date(uchar);
void Send_595(uchar);
void sfm(uchar, uchar);
void keyscan();
uchar i, miao, fen, shi, count, snum;
        init();
        for(i=0; i<16; i++)
                write_date(dage[i]);
                delay(5);
        write_com(0x80+0x40);
        for(i=0; i<13; i++)
                write_date(dage1[i]);
                delay(5);
                keyscan();
                if(count == 20)
                        count = 0;
                  miao++;
                  if(miao == 60)
                                miao = 0;
                          fen++;
                          if(fen == 60)
                                        fen = 0;
                                        shi++;
                                   if(shi == 24)
                                                 shi = 0;
                                         sfm(3, shi);
                                 sfm(7, fen);
                         sfm(11, miao);
void init()
        Send_595(0xff);
        Send_595(0x00);
        P_HC595_RCLK = 0;
        P_HC595_RCLK = 1;
        wr = 0;
        lcden = 0;
        shi = 23;
        fen = 59;
        miao = 39;
        TMOD = 0x01;
        TH0 = (65536-50000)/256;
        TL0 = (65536-50000)%256;
        EA = 1;
        ET0 = 1;
        TR0 = 1;
        write_com(0x38);
        write_com(0x0c);
        write_com(0x06);
        write_com(0x01);
void delay(uint z)
        uint x, y;
        for(x=z; x>0; x--)
           for(y=110; y>0; y--);
void write_com(uchar com)
        rs = 0;
        P0 = com;
        delay(5);
        lcden = 1;
        delay(5);
        lcden = 0;
void write_date(uchar date)
        rs = 1;
        P0 = date;
        delay(5);
        lcden = 1;
        delay(5);
        lcden = 0;
void Send_595(uchar dat)
        uint         i;
        for(i=0; i<8; i++)
                if(dat & 0x80)        P_HC595_SER = 1;
                else                        P_HC595_SER = 0;
                P_HC595_SRCLK = 0;
                P_HC595_SRCLK = 1;
                dat = dat << 1;
void timer() interrupt 1
        count++;
void sfm(uchar add, uchar date)
        uchar shi, ge;
        shi = date/10;
        ge = date%10;
        write_com(0x80+0x40+add);
        write_date(0x30+shi);
        write_date(0x30+ge);
void keyscan()
        if(s5 == 0)
                delay(5);
                if(s5 == 0)
                        snum++;
                        while(!s5);
                        if(snum == 1)
                        TR0 = 0;
                        write_com(0x80+0x40+12);
                        write_com(0x0f);
                        if(snum == 2)
                        TR0 = 0;
                        write_com(0x80+0x40+8);
                        write_com(0x0f);
                  if(snum == 3)
                        TR0 = 0;
                        write_com(0x80+0x40+4);
                        write_com(0x0f);
                        if(snum == 4)
                        snum = 0;
                        write_com(0x0c);
                        TR0 = 1;
                if(snum != 0)
                 if(s10 == 0)
                        delay(5);
                        if(s10 == 10)
                                while(!s10);
                                if(snum == 1)
                                        miao++;
                                        if(miao == 60)
                                                 miao = 0;
                                        write_com(0x80+0x40+11);
                                        sfm(11, miao);
JW-51開發板.pdf
99.63 KB, 下載次數: 5
ID:111634 發表于 2017-11-18 11:20 | 只看該作者
冗長又無注釋的程序,一般不會有人看的。
