查看: 3168|回復: 0
MCP73871引腳圖電路圖與pdf數據手冊下載
Description
The MCP73871 device is a fully integrated linearsolution for system load sharing and Li-Ion / Li-Polymerbattery charge management  with ac-dc wall adapter
and USB port power sources selection. It’s alsocapable of autonomous power source selection
between input or battery. Along with its small physicalsize, the low number of required external components makes the device ideally suited for portable
applications.
The MCP73871 device automatically obtains power for the system load from a single-cell Li-Ion battery or an input power source (ac-dc wall adapter or USB port).
The MCP73871 device specifically adheres to the current drawn limits governed by the USB specification. With an ac-dc wall adapter providing power to the system, an external resistor sets the magnitude of 1A maximum charge current while supports up to 1.8A total current for system load and battery charge current.
MCP73871引腳圖與管腳定義
MCP73871應用電路圖如下:
完整的pdf格式芯片數據手冊文檔51黑下載地址:
MCP73871.pdf (638.37 KB, 下載次數: 30)
