查看: 1744|回復: 1
PWM調(diào)速單片機源碼
ID:249919 發(fā)表于 2017-11-16 21:11 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include<reg51.h>
#include<stdio.h>
sbit DJA=P1^0;
sbit DJB=P1^1;
sbit S1=P3^2;
sbit S2=P3^3;
bit flag;
unsigned char number;
void delay (unsigned int i)
        unsigned int k;
        for(k=0;k<i;k++);
void pwm1()
        DJB=0;
        DJA=1;
        delay(720);
        DJA=0;
        delay(1680);
void pwm2()
        DJB=0;
        DJA=1;
        delay(1250);
        DJA=0;
        delay(1250);
void pwm3()
        DJB=0;
        DJA=1;
        delay(1680);
        DJA=0;
        delay(1680);
void pwm4()
        DJA=0;
        DJB=1;
        delay(720);
        DJB=0;
        delay(1680);
void pwm5()
        DJA=0;
        DJB=1;
        delay(1250);
        DJB=0;
        delay(1250);
void pwm6()
        DJA=0;
        DJB=1;
        delay(1680);
        DJB=0;
        delay(720);
        flag=0;
        number=0x00;
        DJA=0;
        DJB=0;
                if(S1==0)
                        delay(1200);
                        if(S1==0)
                                while(!S1);
                                flag=~flag;
                        if(S2==0)
                        delay(1200);
                        if(S2==0)
                                        while(!S2);
                                        if(number<=3)
                                        number++;
                                        else number=0x01;
                        if(!flag)
                                switch(number)
                                        case 0x01:pwm1();break;
                                        case 0x02:pwm2();break;
                                        case 0x03:pwm3();break;
                                        default:;
                                switch(number)
                                        default:;
新手  多多關注!
