程序里面都有注釋很詳細自己加入閃爍警燈 已經(jīng)做成功 !
- 2017.11.14修改
- 刪除額外數(shù)碼管功能
- 加入閃爍警燈程序
- #include <AT89x52.H>
- #include <intrins.h>
- #define led1 {P2_0=1,P2_1=0;}
- #define led2 {P2_0=0,P2_1=1;}
- /**********如果io口不夠用可以去掉2^4~2^7口將298使能接口接高電平即可***********/
- #define Right_moto_go {P0_0=1,P0_1=0,P0_2=1,P0_3=0,P2_7=1,P2_6=1,P2_5=1,P2_4=1;} //右邊電機向前走
- #define Right_moto_back {P0_0=0,P0_1=1,P0_2=0,P0_3=1,P2_7=1,P2_6=1,P2_5=1,P2_4=1;} //右邊電機向后走
- #define Right_moto_Stop {P0_0=1,P0_1=1,P0_2=1,P0_3=1,P2_7=1,P2_6=1,P2_5=1,P2_4=1;} //右邊電機停轉(zhuǎn)
- #define Left_moto_go {P0_4=0,P0_5=1,P0_6=0,P0_7=1,P2_7=1,P2_6=1,P2_5=1,P2_4=1;} //左邊電機向前走
- #define Left_moto_back {P0_4=1,P0_5=0,P0_6=1,P0_7=0,P2_7=1,P2_6=1,P2_5=1,P2_4=1;} //左邊電機向后轉(zhuǎn)
- #define Left_moto_Stop {P0_4=1,P0_5=1,P0_6=1,P0_7=1,P2_7=1,P2_6=1,P2_5=1,P2_4=1;} //左邊電機停轉(zhuǎn)
- #define Sevro_moto_pwm P1_2 //接舵機信號端輸入PWM信號調(diào)節(jié)速度
- #define ECHO P1_1 //超聲波接口定義
- #define TRIG P1_0 //超聲波接口定義
- unsigned char const discode[] ={ 0xC0,0xF9,0xA4,0xB0,0x99,0x92,0x82,0xF8,0x80,0x90,0xBF,0xff/*-*/};
- unsigned char const positon[3]={ 0xfe,0xfd,0xfb};
- unsigned char disbuff[4]={ 0,0,0,0,};
- unsigned char posit=0;
- unsigned char pwm_val_left = 0;//變量定義
- unsigned char push_val_left =14;//舵機歸中,產(chǎn)生約,1.5MS 信號
- unsigned long S=0;
- unsigned long S1=0;
- unsigned long S2=0;
- unsigned long S3=0;
- unsigned long S4=0;
- unsigned int time=0; //時間變量
- unsigned int timer=0; //延時基準變量
- unsigned char timer1=0; //掃描時間變量
- //延時函數(shù)
- void delay(unsigned int k)
- unsigned int x,y;
- for(x=0;x<k;x++)
- for(y=0;y<2000;y++);
- //前速前進
- void run(void)
- Left_moto_go; //左電機往前走
- Right_moto_go ; //右電機往前走
- //前速后退
- void backrun(void)
- Left_moto_back ; //左電機往前走
- Right_moto_back ; //右電機往前走
- //左轉(zhuǎn)
- void leftrun(void)
- Right_moto_go ; //右電機往前走 ;
- Left_moto_Stop ; //左電機停止
- //右轉(zhuǎn)
- void rightrun(void)
- Left_moto_go ; //左電機往前走
- Right_moto_Stop ; //右電機停止
- //停
- void stoprun(void)
- Left_moto_Stop ; //左電機往前走
- Right_moto_Stop ; //右電機往前走
- //****************************去除額外功能********************************/
- // void Display(void) //掃描數(shù)碼管
- // if(posit==0)
- // {P3=(discode[disbuff[posit]])&0x7f;}//產(chǎn)生點
- // else
- // {P3=discode[disbuff[posit]];}
- // if(posit==0)
- // { P1_3=0;P1_4=1;P1_5=1;}
- // if(posit==1)
- // {P1_3=1;P1_4=0;P1_5=1;}
- // if(posit==2)
- // {P1_3=1;P1_4=1;P1_5=0;}
- // if(++posit>=3)
- // posit=0;
- void StartModule() //啟動測距信號
- TRIG=1;
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- _nop_();
- TRIG=0;
- void Conut(void) //計算距離
- while(!ECHO); //當RX為零時等待
- TR0=1; //開啟計數(shù)
- while(ECHO); //當RX為1計數(shù)并等待
- TR0=0; //關(guān)閉計數(shù)
- time=TH0*256+TL0; //讀取脈寬長度
- TH0=0;
- TL0=0;
- S=(time*1.7)/100; //算出來是CM
- disbuff[0]=S%1000/100; //更新顯示
- disbuff[1]=S%1000%100/10;
- disbuff[2]=S%1000%10 %10;
- void COMM( void )
- push_val_left=5; //舵機向左轉(zhuǎn)90度
- timer=0;
- while(timer<=4000); //延時400MS讓舵機轉(zhuǎn)到其位置
- StartModule(); //啟動超聲波測距
- Conut(); //計算距離
- S2=S;
- push_val_left=23; //舵機向右轉(zhuǎn)90度
- timer=0;
- Conut(); //計算距離
- S4=S;
- push_val_left=14; //舵機歸中
- timer=0;
- Conut(); //計算距離
- S1=S;
- if((S2<20)||(S4<20)) //只要左右各有距離小于,20CM小車后退
- backrun(); //后退
- timer=0;
- if(S2>S4)
- rightrun(); //車的左邊比車的右邊距離小 右轉(zhuǎn)
- timer=0;
- while(timer<=3500);//原4000
- else
- leftrun(); //車的左邊比車的右邊距離大 左轉(zhuǎn)
- timer=0;
- /*調(diào)節(jié)push_val_left的值改變電機轉(zhuǎn)速,占空比 */
- void pwm_Servomoto(void)
- if(pwm_val_left<=push_val_left)
- Sevro_moto_pwm=1;
- else
- Sevro_moto_pwm=0;
- if(pwm_val_left>=200)
- pwm_val_left=0;
- ///*TIMER1中斷服務(wù)子函數(shù)產(chǎn)生PWM信號*/
- void time1()interrupt 3 using 2
- TH1=(65536-100)/256; //100US定時
- TL1=(65536-100)%256;
- timer++; //定時器100US為準。在這個基礎(chǔ)上延時
- pwm_val_left++;
- pwm_Servomoto();
- // timer1++; //2MS掃一次數(shù)碼管
- // if(timer1>=20)
- // timer1=0;
- // Display();
- /*****************************閃爍燈中斷延時函數(shù)****************************/
- void delay1()
- unsigned char i,j,k;
- for(i=1;i>0;i--)
- for(j=100;j>0;j--)
- for(k=250;k>0;k--);
- void shansuo()
- led1;
- delay1();
- led2;
- delay1();
- /*--主函數(shù)--*/
- void main(void)
- stoprun();
- TMOD=0X11;
- TH0=0;
- TL0=0;
- TR1= 1;
- ET1= 1;
- ET0= 1;
- EA = 1;
- delay(100);
- while(1) /*無限循環(huán)*/
- shansuo(); //閃爍燈函數(shù)
- if(timer>=200) //100MS檢測啟動檢測一次 原來500
- timer=0;
- StartModule(); //啟動檢測
- Conut(); //計算距離
- if(S<35) //距離小于20CM
- stoprun(); //小車停止
- COMM(); //方向函數(shù)
- else
- if(S>40) //距離大于,35CM往前走
- run();
避障加警燈完.rar
(38.36 KB, 下載次數(shù): 15)
2017-11-15 19:23 上傳
程序 下載積分: 黑幣 -5
