查看: 3246|回復: 0
44鍵盤單片機仿真 數碼管顯示
這是我剛寫的44鍵盤,數碼管顯示0~f我覺得很簡單,適合新手學習。
  1. #include <REG51.H>
  2. unsigned char code KeyImage[]=
  3. {
  4.         0X00,0x3F,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07,
  5.         0x7F,0X6F,0X77,0X7C,0X39,0X5E,0X79,0X71
  6. };
  7. void delayms(unsigned int ms)
  8. {
  9. unsigned char i;
  10.   while(ms--)
  11.     {
  12.       for(i=0;i<125;i++){;}
  13.     }
  14. }
  15. unsigned char KEY_Scan(void)
  16. {
  17.                 unsigned char keyX;
  18.                 unsigned char keyY;
  19.                 unsigned char keyXY;
  20.                 delayms(10);
  21.                 if(P1!=0x0F)
  22.                 {
  23.                         keyY=P1;
  24.                         P1=0xF0;
  25.                         keyX=P1;
  26.                         keyXY=keyX|keyY;
  27.                         P1=0x0F;
  28.                         if(keyXY==0xEE)return 1;
  29.                         else if(keyXY==0xED)return 2;
  30.                         else if(keyXY==0xEB)return 3;
  31.                         else if(keyXY==0xE7)return 4;
  32.                         else if(keyXY==0xDE)return 5;
  33.                         else if(keyXY==0xDD)return 6;
  34.                         else if(keyXY==0xDB)return 7;
  35.                         else if(keyXY==0xD7)return 8;
  36.                         else if(keyXY==0xBE)return 9;
  37.                         else if(keyXY==0xBD)return 10;
  38.                         else if(keyXY==0xBB)return 11;
  39.                         else if(keyXY==0xB7)return 12;
  40.                         else if(keyXY==0x7E)return 13;
  41.                         else if(keyXY==0x7D)return 14;
  42.                         else if(keyXY==0x7B)return 15;
  43.                         else if(keyXY==0x77)return 16;
  44.                 }
  45.         return 0;
  46. }
  47. void main()
  48. {
  49.         unsigned char key=0;
  50.         P0=KeyImage[key];
  51. ……………………
  52. …………限于本文篇幅 余下代碼請從51黑下載附件…………
6.4X4.rar (61.92 KB, 下載次數: 17)
