查看: 3542|回復: 2
光敏電壓值測量AD1627+LCD1602的單片機仿真+源程序
環境keil5 、proteus8.6
如果版本過高無法打開 聯系作者q1562335917
主要是8951運用AD1674和LCD1602來測量電壓與數顯電壓值
LCD1602+AD1674仿真原理圖如下(proteus仿真工程文件可到本帖附件中下載):
  1. #include<reg52.h> //包含頭文件,一般情況不需要改動,頭文件包含特殊功能寄存器的定義
  2. #include<intrins.h>
  3. sbit RS = P3^4;   //定義端口
  4. sbit RW = P3^5;
  5. sbit EN = P3^6;
  6. sbit STS=P3^3;
  7. sbit CE = P3^2;
  8. sbit CS =P3^1;
  9. sbit RC =P3^0;
  10. #define RS_CLR RS=0
  11. #define RS_SET RS=1
  12. #define RW_CLR RW=0
  13. #define RW_SET RW=1
  14. #define EN_CLR EN=0
  15. #define EN_SET EN=1
  16. #define uchar   unsigned char
  17. #define uint    unsigned int
  18. #define DataPort P1
  19. void DelayUs2x(unsigned char t)
  20. {
  21. while(--t);
  22. }
  23. void DelayMs(unsigned char t)
  24. {
  25.
  26. while(t--)
  27. {
  28.      //大致延時1mS
  29.      DelayUs2x(245);
  30.          DelayUs2x(245);
  31. }
  32. }
  33. /*------------------------------------------------
  34.               判忙函數
  35. ------------------------------------------------*/
  36. bit LCD_Check_Busy(void)
  37. {
  38. DataPort= 0xFF;
  39. RS_CLR;
  40. RW_SET;
  41. EN_CLR;
  42. _nop_();
  43. EN_SET;
  44. return (bit)(DataPort & 0x80);
  45. }
  46. /*------------------------------------------------
  47.               寫入命令函數
  48. ------------------------------------------------*/
  49. void LCD_Write_Com(unsigned char com)
  50. {
  51. // while(LCD_Check_Busy()); //忙則等待
  52. DelayMs(5);
  53. RS_CLR;
  54. RW_CLR;
  55. EN_SET;
  56. DataPort= com;
  57. _nop_();
  58. EN_CLR;
  59. }
  60. /*------------------------------------------------
  61.               寫入數據函數
  62. ------------------------------------------------*/
  63. void LCD_Write_Data(unsigned char Data)
  64. {
  65. //while(LCD_Check_Busy()); //忙則等待
  66. DelayMs(5);
  67. RS_SET;
  68. RW_CLR;
  69. EN_SET;
  70. DataPort= Data;
  71. _nop_();
  72. EN_CLR;
  73. }
  74. /*------------------------------------------------
  75.                 清屏函數
  76. ------------------------------------------------*/
  77. void LCD_Clear(void)
  78. {
  79. LCD_Write_Com(0x01);
  80. DelayMs(5);
  81. }
  82. /*------------------------------------------------
  83.               寫入字符串函數
  84. ------------------------------------------------*/
  85. void LCD_Write_String(unsigned char x,unsigned char y,unsigned char *s)
  86. {
  87. if (y == 0)
  88.         {
  89.          LCD_Write_Com(0x80 + x);     //表示第一行
  90.         }
  91. else
  92.         {
  93.         LCD_Write_Com(0xC0 + x);      //表示第二行
  94.         }
  95. while (*s)
  96.         {
  97. LCD_Write_Data( *s);
  98. s ++;
  99.         }
  100. }
  101. /*------------------------------------------------
  102.               寫入字符函數
  103. ------------------------------------------------*/
  104. void LCD_Write_Char(unsigned char x,unsigned char y,unsigned char Data)
  105. {
  106. if (y == 0)
  107.         {
  108.         LCD_Write_Com(0x80 + x);
  109.         }
  110. else
  111.         {
  112.         LCD_Write_Com(0xC0 + x);
  113.         }
  114. LCD_Write_Data( Data);
  115. }
  116. /*------------------------------------------------
  117.               初始化函數
  118. ------------------------------------------------*/
  119. void LCD_Init(void)
  120. {
  121.    LCD_Write_Com(0x38);    /*顯示模式設置*/
  122.    DelayMs(5);
  123.    LCD_Write_Com(0x38);
  124.    DelayMs(5);
  125.    LCD_Write_Com(0x38);
  126.    DelayMs(5);
  127.    LCD_Write_Com(0x38);
  128.    LCD_Write_Com(0x08);    /*顯示關閉*/
  129.    LCD_Write_Com(0x01);    /*顯示清屏*/
  130.    LCD_Write_Com(0x06);    /*顯示光標移動設置*/
  131.    DelayMs(5);
  132.    LCD_Write_Com(0x0C);    /*顯示開及光標設置*/
  133.    }
  134. /*------------------------------------------------
  135.                 AD轉換函數
  136. ------------------------------------------------*/
  137. double AD()
  138. {
  139.     double i,j,k;
  140.    CE=1;
  141.     CS=0;
  142.     RC=0;
  143.     _nop_();
  144.     while(STS==1);    //等待數據采集結束
  145.     CE=0;
  146.     CE=1;
  147.     CS=0;
  148.     RC=1;
  149.     _nop_();
  150.     i=P0;
  151.     j=P2;
  152.     i=i*16;
  153.     j=j/16;
  154.     k=i+j;
  155.     k=k*10;
  156.     k=k/4096;//12位ad
  157.     return k;
  158. }
  159. /*------------------------------------------------
  160.                     數據處理
  161. ------------------------------------------------*/
  162. void data_process(double dat,uchar s[10])
  163. {
  164.   int  a,b,c,d;
  165.   dat=dat*100;
  166.   a=(int)(dat);
  167.   b=a/100;
  168.   s[0]=b+48;
  169.   s[1]='.';
  170.   d=a%10;
  171.   s[3]=d+48;
  172.   a=a/10;
  173.   c=a%10;
  174.   s[2]=c+48;
  175.   s[4]='v';
  176. }
  177. ……………………
  178. …………限于本文篇幅 余下代碼請從51黑下載附件…………
光敏測量電壓.zip (83.49 KB, 下載次數: 37)
ID:494023 發表于 2019-3-20 16:57 | 只看該作者
keil打不開啊
ID:494023 發表于 2019-3-20 16:58 | 只看該作者
keil 打不開啊
