查看: 3725|回復: 2
Arduino二輪藍牙小車
藍牙小車
  1. #define IN1 11
  2. #define IN2 10     //定義In1接arduino的4引腳,In2接5引腳
  3. #define IN3 9
  4. #define IN4 8    //定義IN3接arduino的6引腳,IN4接7引腳
  5. #define ENA 3
  6. #define ENB 5
  7. int PWM1=150;
  8. int PWM2=100;
  9. void forward( );
  10. void back( );
  11. void turnLeft( );
  12. void turnRight( );
  13. void _stop( );
  14. void setup( )
  15. {
  16.   pinMode(IN1,OUTPUT);
  17.   pinMode(IN2,OUTPUT);
  18.   pinMode(IN3,OUTPUT);
  19.   pinMode(IN4,OUTPUT);
  20.   Serial.begin(9600);
  21. }
  22. int i;
  23. void loop( )
  24. {
  25.     if(Serial.available())
  26.     {
  27.       i=Serial.read();
  28.
  29.       switch(i)
  30.       {
  31.         case'A':forward( );
  32.                 break;
  33.
  34.         case'B':back( );
  35.                 break;
  36.
  37.         case'C':turnLeft( );
  38.                 break;
  39.
  40.         case'D':turnRight( );
  41.                 break;
  42.         case'F':_stop();
  43.                 break;
  44.       }
  45.     }
  46. }
  47. /**************************************************
  48. forward子函數——前進子函數
  49. 函數功能:控制車前進
  50. **************************************************/
  51. void forward( )
  52. {
  53.   digitalWrite(IN1,HIGH);
  54.   digitalWrite(IN2,LOW);         //左輪前進
  55.   digitalWrite(IN3,HIGH);
  56.   digitalWrite(IN4,LOW);         //右輪前進
  57.   analogWrite(ENA,PWM1);
  58.   analogWrite(ENB,PWM1);
  59. }
  60. /**************************************************
  61. back子函數——后退子函數
  62. 函數功能:控制車后退
  63. **************************************************/
  64. void back( )
  65. {
  66.   digitalWrite(IN1,LOW);
  67.   digitalWrite(IN2,HIGH);        //左輪后退
  68.   digitalWrite(IN3,LOW);
  69.   digitalWrite(IN4,HIGH);        //右輪后退
  70.   analogWrite(ENA,PWM2);
  71.   analogWrite(ENB,PWM2);
  72. }
  73. /**************************************************
  74. turnLeft子函數——左轉子函數
  75. 函數功能:控制車左轉
  76. **************************************************/
  77. void turnLeft( )
  78. {
  79.   digitalWrite(IN1,LOW);
  80.   digitalWrite(IN2,LOW);         //左輪靜止不動
  81.   digitalWrite(IN3,HIGH);
  82.   digitalWrite(IN4,LOW);         //右輪前進
  83.   analogWrite(ENB,PWM2);
  84.   analogWrite(ENA,0);
  85. }
  86. void turnRight( )
  87. {
  88.   digitalWrite(IN1,HIGH);
  89.   digitalWrite(IN2,LOW);         //左輪前進
  90.   digitalWrite(IN3,LOW);
  91.   digitalWrite(IN4,LOW);         //右輪靜止不動
  92.   analogWrite(ENA,PWM2);
  93.   analogWrite(ENB,0);
  94. }
  95. void _stop()
  96. {
  97.   digitalWrite(IN1,LOW);
  98.   digitalWrite(IN2,LOW);         //左輪靜止不動
  99.   digitalWrite(IN3,LOW);
  100.   digitalWrite(IN4,LOW);         //右輪靜止不動
  101. }
二輪藍牙車.zip (1.06 KB, 下載次數: 29)
參與人數 2黑幣 +55 收起 理由
木木123 + 5 很給力!
收藏收藏3 分享淘帖 頂 踩
ID:148947 發表于 2017-10-30 17:34 | 只看該作者
很好 優秀啊 我用51做過這個 你可以看我之前發的帖子 我最近在玩一個arduino藍牙控制機械手的想法  有興趣可以相互交流下,之前我一直玩兒51的,才玩arduino,有問題想問大腿叻
qq:995521157
ID:273904 發表于 2019-11-16 23:46 來自觸屏版 | 只看該作者
您好,有APP嗎?
