查看: 2442|回復: 0
光立方程序
ID:241454 發表于 2017-10-20 23:14 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include<reg52.h>
#ifndef __SOUNDPLAY_H_REVISION_FIRST__
#define __SOUNDPLAY_H_REVISION_FIRST__
#define SYSTEM_OSC                 12000000        //定義晶振頻率12000000HZ
#define SOUND_SPACE         4/5                 //定義普通音符演奏的長度分率,//每4分音符間隔
uint  code FreTab[12]  = { 262,277,294,311,330,349,369,392,415,440,466,494 }; //原始頻率表
uchar code SignTab[7]  = { 0,2,4,5,7,9,11 };        //1~7在頻率表中的位置
uchar code LengthTab[7]= { 1,2,4,8,16,32,64 };
uchar Sound_Temp_TH0,Sound_Temp_TL0;        //音符定時器初值暫存
uchar Sound_Temp_TH1,Sound_Temp_TL1;        //音長定時器初值暫存
uchar shang,slie,slie1,aa,a,kk,n,m;
uint x,y,z;
void key();                        //    按鍵檢測
void delay(uint z);           //*****************************延時
void init();                   //******************************初始化
void hangl();//**************************************************行外圍逐列個亮
void ceng();//***************************************1234層循環亮
void houqian();//******************************************從后向前
void zuoyou();//****************************************從左向右亮
void shanshuo();  //*****************************全部以200ms的速度閃爍50次,關閉
void rao(); //*************************************環繞
void InitialSound(void);//*************音樂初始化
void Play(uchar *Sound,uchar Signature,unsigned Octachord,uint Speed);
void Delay1ms(uint count)
        unsigned int i,j;
        for(i=0;i<count;i++)
        for(j=0;j<120;j++);
uchar code Music_Same[]={ 0x0F,0x01, 0x15,0x02, 0x16,0x02, 0x17,0x66, 0x18,0x03,
                                  0x17,0x02, 0x15,0x02, 0x16,0x01, 0x15,0x02, 0x10,0x02,
                                  0x15,0x00, 0x0F,0x01, 0x15,0x02, 0x16,0x02, 0x17,0x02,
                                  0x17,0x03, 0x18,0x03, 0x19,0x02, 0x15,0x02, 0x18,0x66,
                                  0x17,0x03, 0x19,0x02, 0x16,0x03, 0x17,0x03, 0x16,0x00,
                                  0x17,0x01, 0x19,0x02, 0x1B,0x02, 0x1B,0x70, 0x1A,0x03,
                                  0x1A,0x01, 0x19,0x02, 0x19,0x03, 0x1A,0x03, 0x1B,0x02,
                                  0x1A,0x0D, 0x19,0x03, 0x17,0x00, 0x18,0x66, 0x18,0x03,
                                  0x19,0x02, 0x1A,0x02, 0x19,0x0C, 0x18,0x0D, 0x17,0x03,
                                  0x16,0x01, 0x11,0x02, 0x11,0x03, 0x10,0x03, 0x0F,0x0C,
                                  0x10,0x02, 0x15,0x00, 0x1F,0x01, 0x1A,0x01, 0x18,0x66,
                                  0x19,0x03, 0x1A,0x01, 0x1B,0x02, 0x1B,0x03, 0x1B,0x03,
                                  0x1B,0x0C, 0x1A,0x0D, 0x19,0x03, 0x17,0x00, 0x1F,0x01,
                                  0x1A,0x01, 0x18,0x66, 0x19,0x03, 0x1A,0x01, 0x10,0x02,
                                  0x10,0x03, 0x10,0x03, 0x1A,0x0C, 0x18,0x0D, 0x17,0x03,
                                  0x16,0x00, 0x0F,0x01, 0x15,0x02, 0x16,0x02, 0x17,0x70,
                                  0x18,0x03, 0x17,0x02, 0x15,0x03, 0x15,0x03, 0x16,0x66,
                                  0x16,0x03, 0x16,0x02, 0x16,0x03, 0x15,0x03, 0x10,0x02,
                                  0x10,0x01, 0x11,0x01, 0x11,0x66, 0x10,0x03, 0x0F,0x0C,
                                  0x1A,0x02, 0x19,0x02, 0x16,0x03, 0x16,0x03, 0x18,0x66,
                                  0x18,0x03, 0x18,0x02, 0x17,0x03, 0x16,0x03, 0x19,0x00,
                                  0x00,0x00 };
sbit cai=P3^3;                //高電平點亮
sbit yy=P3^4;                //蜂鳴器
sbit k1=P3^5;                // 按鍵        左
sbit k2=P3^6;                //按鍵        中
sbit k3=P3^7;                //按鍵        右
//*******************************************行選
uchar code hang[]={
        0x00, //全開
        0xff,//全關
        0x7f,//開底層
        0xbf,//開底二
        0xdf,//開底三層
        0xef,//開最高層
//***************************************列選P0
uchar code lie[]={
        0xff,//全開
        0x00,//全關
//****************************************列選P1
uchar code lie1[]={
        0xff,//全開
        0x00,//全關
//--------------------------------------------------------------主程序
        init();                         //初始化設置
                          P0=0xff;        P1=0xff;         P2=0x00;        //全亮
                key();
//====================================各種模塊=================================================
void delay(uint z)        //***************************延時
        for(x=z;x>0;x--)
                for(y=110;y>0;y--);
void init()                         //******************************初始化
        kk=0;
        P2=0xff;          //關閉行選
        P0=0x00;          //關閉列選
        P1=0x00;          //關閉列選
        cai=0;                 //關閉彩燈
//=====================================================音樂初始化
        yy = 0;
        Sound_Temp_TH1 = (65535-(1/1200)*SYSTEM_OSC)/256;        // 計算TL1應裝入的初值         (10ms的初裝值)
        Sound_Temp_TL1 = (65535-(1/1200)*SYSTEM_OSC)%256;        // 計算TH1應裝入的初值
        TH1 = Sound_Temp_TH1;
        TL1 = Sound_Temp_TL1;
        TMOD  |= 0x11;
        ET0    = 1;
        ET1           = 0;
        TR0           = 0;
        TR1    = 0;
        EA     = 1;
void shanshuo()  //*****************************各種閃爍
                 for(a=0;a<10;a++)
                         P2=hang[0];                          //開所有行選
                        for(slie=0;slie<2;slie++)
                         P0=lie[slie];
                         P1=lie1[slie];
                         delay(60);
                        P2=0xff;        P0=P1=0x00;          //全部關閉
                        for(a=0;a<10;a++)
                                P2=0x00;
                                P1=0x99;        P0=0x99;  delay(50);
                                        P2=0xff;        P0=0X00;P1=0x00;          //全部關閉
                                        delay(50);
                        for(a=0;a<10;a++)
                                P2=0x00;
                                P1=0x66;        P0=0x66;  delay(50);
                                        delay(50);
                        for(a=0;a<10;a++)
                                P2=0x00;
                                P1=0x55;        P0=0x55;  delay(50);
                                        P2=0xff;        P0=0x00;        P1=0x00;          //全部關閉
                                        delay(50);
                        for(a=0;a<10;a++)
                                P2=0x00;
                                P1=0xaa;        P0=0xaa;   delay(50);
                                        delay(50);
                        delay(1000);
                        P2=0x3f;
                        P0=0x60;        P1=0x06;        delay(1000);
                        P2=0x00;        P0=0xff;        P1=0xff;        delay(1000);
void zuoyou()//****************************************從左向右亮
        for(a=0;a<8;a++)
                         P2=0x00;
                         P1=0x11;        P0=0x11;         delay(50);
                        P1=0x22;        P0=0x22;         delay(50);
                        P1=0x44;        P0=0x44;         delay(50);
                        P1=0x88;        P0=0x88;         delay(50);
                                delay(50);
void houqian()//******************************************從后向前
for(a=0;a<8;a++)
                P2=0x00;
                        P0=0x0f;        delay(50);
                        P0=0xf0;        delay(50);         P0=0x00;
                        P1=0x0f;        delay(50);
                        P1=0xf0;        delay(50);
                 delay(400);
void ceng()//***************************************1234層循環亮
for(a=0;a<15;a++)
        P0=0xff;P1=0xff;
           P2=0x7f;                delay(50);
           P2=0xbf;                delay(50);
           P2=0xdf;                delay(50);
           P2=0xef;                delay(150);
           P2=0xdf;                delay(50);
           P2=0xbf;                delay(50);
void hangl()//**************************************************行外圍逐個亮
for(a=0;a<8;a++)
                 P0=0x88;        P1=0x88;
         P2=0xef;                                           delay(50);
         P2=0xdf;                                        delay(50);
         P2=0xbf;                                        delay(50);
            P2=0x7f;                                        delay(50);
                 P0=0x44;        P1=0x44;        delay(50);
                 P0=0x22;        P1=0x22;        delay(50);
                 P0=0x11;        P1=0x11;        delay(50);
        P2=0xbf;                                        delay(50);
    P2=0xdf;                                        delay(50);
        P2=0xef;
}           P2=0xff;        P0=P1=0x00;          //全部關閉
void rao()
{          P2=0xff;        P0=P1=0x00;          //全部關閉
                                 P2=0x7f;                P1=0xf0;  delay(200);
                                 P2=0x3f;                                           delay(200);
                                 P2=0x1f;                                           delay(200);
                                 P2=0x0f;                                           delay(800);
        P1=0x70;  delay(200);
        P1=0xb0;  delay(200);
        P1=0xd0;  delay(200);
        P1=0xe0;  delay(200);          P1=0X00;
                                 for(a=0;a<4;a++)
                                P1=0x71;                                           delay(100);
                                P1=0x31;                P0=0x10;  delay(100);
                                P1=0x11;                P0=0x11;        delay(100);
                                P1=0x01;                P0=0x13;  delay(100);
                                P1=0X00;                    P0=0x17;  delay(100);
        P0=0x0f;        delay(100);
        P0=0x8e;  delay(100);
                            P1=0x08;                P0=0x46;  delay(100);
                                P1=0x88;                P0=0x88; delay(100);
                                P1=0xc8;                P0=0x80; delay(100);
                                P1=0xe8;                P0=0X00;          delay(100);
                                P1=0xf0;                                          delay(100);
                                P1=0x30;                delay(200);
                                for(a=0;a<4;a++)
                                 P1=0x10;         delay(200);        P1=0X00;  delay(200);
                                } P1=0x10;
                                P2=0x7f;                delay(500);
                                P2=0Xff;P0=0X00;P1=0X00;
void key()        //***********************************按鍵檢測
                  if(k1==0)                //********************左鍵
                  {         if(kk==6)
                                  {kk=0;}
                  delay(10);
                          if(k1==0)
                                while(!k1);
                                if(kk==1)
                                        {shanshuo();}        //全部以200ms的速度閃爍
                                if(kk==2)
                                        {hangl();}                   //行外圍逐列個亮
                                if(kk==5)
                                        {houqian();}         //          從后向前
                                if(kk==3)
                                        {zuoyou();}                //          從左向右亮
                                if(kk==4)
                                        {ceng();}                //         1234層循環亮
                                if(kk==0)
                                        {rao();}
                          kk++;
                  if(k3==0)        //***************************右鍵
                          delay(10);
                        if(k3==0)
                        {        while(!k3);
                                cai=~cai;
                  if(k2==0)           //***************************中鍵
                          delay(10);
                        if(k2==0)
                                while(!k2);
                                   InitialSound();
                                Play(Music_Same,0,3,360);
                Delay1ms(500);
//        P0=0x00;
void BeepTimer0(void) interrupt 1        //音符發生中斷
        yy = !yy;
        TH0    = Sound_Temp_TH0;
         TL0    = Sound_Temp_TL0;
        uint NewFreTab[12];                //新的頻率表
        uchar i,j;
        uint Point,LDiv,LDiv0,LDiv1,LDiv2,LDiv4,CurrentFre,Temp_T,SoundLength;
        uchar Tone,Length,SL,SH,SM,SLen,XG,FD;
        for(i=0;i<12;i++)                                 // 根據調號及升降八度來生成新的頻率表
                j = i + Signature;
                if(j > 11)
                        j = j-12;
                        NewFreTab[i] = FreTab[j]*2;
                        NewFreTab[i] = FreTab[j];
                if(Octachord == 1)
                        NewFreTab[i]>>=2;
                else if(Octachord == 3)
                        NewFreTab[i]<<=2;
        SoundLength = 0;
        while(Sound[SoundLength] != 0x00)        //計算歌曲長度
                SoundLength+=2;
        Point = 0;
        Tone   = Sound[Point];
        Length = Sound[Point+1];                         // 讀出第一個音符和它時時值
        LDiv0 = 12000/Speed;                                // 算出1分音符的長度(幾個10ms)
        LDiv4 = LDiv0/4;                                         // 算出4分音符的長度
        LDiv4 = LDiv4-LDiv4*SOUND_SPACE;         // 普通音最長間隔標準
        TR0          = 0;
        TR1   = 1;
        while(Point < SoundLength)
                SL=Tone%10;        //計算出音符
                SM=Tone/10%10;        //計算出高低音
                SH=Tone/100;        //計算出是否升半
                CurrentFre = NewFreTab[SignTab[SL-1]+SH];         //查出對應音符的頻率
                if(SL!=0)
                        if (SM==1) CurrentFre >>= 2;                 //低音
                        if (SM==3) CurrentFre <<= 2;                 //高音
                        Temp_T = 65536-(50000/CurrentFre)*10/(12000000/SYSTEM_OSC);//計算計數器初值
                        Sound_Temp_TH0 = Temp_T/256;
                        Sound_Temp_TL0 = Temp_T%256;
                        TL0 = Sound_Temp_TL0 + 12; //加12是對中斷延時的補償
                SLen=LengthTab[Length%10];         //算出是幾分音符
                XG=Length/10%10;                         //算出音符類型(0普通1連音2頓音)
                FD=Length/100;
                LDiv=LDiv0/SLen;                         //算出連音音符演奏的長度(多少個10ms)
                if (FD==1)
                        LDiv=LDiv+LDiv/2;
                if(XG!=1)
                        if(XG==0)                                 //算出普通音符的演奏長度
                                if (SLen<=4)
                                        LDiv1=LDiv-LDiv4;
                                        LDiv1=LDiv*SOUND_SPACE;
                                LDiv1=LDiv/2;                 //算出頓音的演奏長度
                        LDiv1=LDiv;
                if(SL==0) LDiv1=0;
                        LDiv2=LDiv-LDiv1;                 //算出不發音的長度
                  if (SL!=0)
                        TR0=1;
                        for(i=LDiv1;i>0;i--)         //發規定長度的音
                                while(TF1==0);
                                TF1=0;
                if(LDiv2!=0)
                        TR0=0; yy=0;
                        for(i=LDiv2;i>0;i--)         //音符間的間隔
                                while(TF1==0);
                                TF1=0;
                Point+=2;
                Tone=Sound[Point];
                Length=Sound[Point+1];
        yy = 0;
