查看: 7878|回復(fù): 7
stc單片機(jī)測NTC10K電阻溫度
ID:241128 發(fā)表于 2017-10-19 23:19 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
手頭正好有個項目要用到測溫,STC404AS單片機(jī),采用10K(好像是3950型號吧)負(fù)溫度熱敏電阻硬件比較簡單,求相應(yīng)代碼,ADC該如何設(shè)置,3位數(shù)碼管顯示溫度...
收藏收藏3 分享淘帖 頂1 踩
ID:126608 發(fā)表于 2017-10-20 06:58 | 只看該作者
搜一下本論壇劉海龍的主題,就有你要的資料。
ID:213173 發(fā)表于 2017-10-20 08:32 | 只看該作者
這個程序不復(fù)雜,就是用溫敏電阻做到誤差0.5°C有點麻煩。
ID:241128 發(fā)表于 2018-4-26 15:02 | 只看該作者
謝謝樓上幾位的回復(fù),已經(jīng)搞定這個程序了,會了就很簡單了,沒弄好的時候頭緒都沒有,下面是150度部分代碼:
uint NTC_R;//定義熱敏電阻阻值變量
uint temperature;//定義溫度存儲變量
unsigned int code temp_oil[151][2]=
0,32485,
1,30871,
2,29346,
3,27937,
4,26584,
5,25303,
6,24092,
7,22945,
8,21859,
9,20830,
10,19856,        //0-10
11,18932,
12,18057,
13,17227,
14,16439,
15,15692,
16,14983,
17,14310,
18,13670,
19,13063,
20,12486,
21,11938,         //11-21
22,11416,
23,10920,
24,10449,
25,10000,
26,9572,
27,9166,
28,8779,
29,8410,
30,8059,
31,7724,
32,7405,
33,7101,
34,6811,
35,6534,
36,6270,
37,6018,
38,5777,
39,5547,
40,5328,
41,5118,
42,4918,
43,4727,
44,4544,
45,4369,
46,4192,
47,4030,
48,3876,
49,3729,
50,3588,
51,3453,
52,3324,
53,3200,
54,3082,
55,2969,
56,2861,
57,2757,
58,2658,
59,2562,
60,2471,
61,2383,
62,2299,
63,2219,
64,2142,
65,2067,
66,1996,
67,1928,
68,1862,
69,1799,
70,1738,
71,1680,
72,1624,
73,1570,
74,1519,
75,1469,
76,1421,
77,1375,
78,1331,
79,1288,
80,1247,
81,1208,
82,1170,
83,1134,
84,1098,
85,1064,
86,1031,
87,999,
88,969,
89,882,
90,855,
91,829,
92,805,
93,781,
94,758,
95,736,
96,714,
97,694,
98,674,
99,694,
100,674,
101,654,
102,636,
103,618,
104,600,
105,583,
106,567,
107,552,
108,536,
109,522,
110,508,
111,494,
112,481,
113,468,
114,455,
115,443,
116,432,
117,420,
118,409,
119,399,
120,388,
121,378,
122,369,
123,359,
124,350,
125,342,
126,333,
127,325,
128,317,
129,309,
130,302,
131,294,
132,288,
133,281,
134,274,
135,268,
136,262,
137,255,
138,249,
139,244,
140,238,
141,244,
142,227,
143,233,
144,217,
145,212,
146,207,
147,202,
148,198,
149,193,
150,189
#include "BandGap.c"//包含讀單片機(jī)內(nèi)部BandGap基準(zhǔn)電壓值
void T_dis(){//溫度處理函數(shù)采集到的阻值與二維數(shù)組的阻值進(jìn)行比較,從而獲得相對應(yīng)的溫度值。
         unsigned char i;
         for(i=150;i<151;i--)  {
                if(NTC_R >= temp_oil[i][1]&& NTC_R < temp_oil[i-1][1]){
                   temperature=(temp_oil[i][0]);
                   if(temperature>=set_temp)IE2=0x04;
                   b=temperature/100;
                   c=temperature%100/10;
                   d=temperature%10;
                   break;
beep_error=0;
                P1M0=0x41;
                P1M1=0x41;
P2M0=0xff;
P2M1=0x00;
beep_error=0;
Ht1621_Init(); //上電初始化LCD
BL=0;
InitADC();
IT0=1;//中斷類型(上下沿中斷         )
EX0=1;        //外中斷0使能
PCON &= ~LVDF;                  //上電后需要清LVD中斷標(biāo)志位
ELVD = 1;                       //使能LVD中斷
_Nop();_Nop();_Nop();_Nop();_Nop();_Nop();_Nop();_Nop();
        T2L = 0x20;                //設(shè)置定時初值
        T2H = 0xD1;                //設(shè)置定時初值
        AUXR |= 0x90;                //定時器時鐘1T模式        1001 0000
        TMOD = 0xB0;                //設(shè)置定時器模式1011 0000
        TMOD &= 0xB0;                //設(shè)置定時器模式1011 0000
        TL0 = 0xC0;                //設(shè)置定時初值
        TH0 = 0x63;                //設(shè)置定時初值
        TF0 = 0;                //清除TF0標(biāo)志
        ET0=0;
        IT0=1;
        TR0 = 1;
EA = 1;
DelayMS(2000);
set_temp=IapReadByte(0x0001);
brightness_press();
ljjs++;
if(ljjs==500)
ljjs=0;
ljjs_flag^=1;
T_dis();
ShowResult();
//if(js<254)js++;
if(flash_flag)
s=s+500;
colour_press();
else s=0;
Ht1621WrAllData(0,Ht1621Tab1,10);
if(k==10){k=0;j++;}if(j==10){j=0;h++;}
if(j==6){j=0;g++;}
if(g==10){g=0;f++;}
if(f==10){f=0;e++;}
void ShowResult()//uchar ch)
{         //uchar stc_ch;
    uint adc_res10,//測量設(shè)定通道adc值
    bandgap,       //bandgap預(yù)儲存校準(zhǔn)值,單位毫伏
    adc_9gallery_res; //測量第九通道(bandgap)值
    float power_voltage,        //系統(tǒng)供電電壓,單位毫伏
    R,ADC_voltage;     //設(shè)定通道電壓值,單位毫伏
    uchar  code *cptr; //定義ROM(代碼)區(qū)指針
    cptr = ID_ADDR_ROM;         //從程序區(qū)讀取BandGap電壓值(單位:毫伏mV)
    bandgap=*cptr++;
    bandgap<<=8;
    bandgap+=*cptr;
    ADC_RES = 0;                    //清除結(jié)果寄存器
    P1ASF = 0x41;                   //設(shè)置P1口為AD口 0100 0001
        if(!ljjs_flag){stc_ch=0;a=1;}
        else  {stc_ch=6;a=2;}
    GetADCResult(stc_ch);
    GetADCResult(stc_ch);                 //讀三次獲得穩(wěn)定
    adc_res10= GetADCResult(stc_ch);
    //測量第九通道(bandgap)值
    P1ASF = 0x00;                   //設(shè)置讀第九通道
    GetADCResult(0);                 //測bandgap時,調(diào)用此函數(shù)時通道數(shù)只能填0
    GetADCResult(0);                 //讀三次獲得穩(wěn)定
    adc_9gallery_res=GetADCResult(0);
    //計算系統(tǒng)供電電壓
    power_voltage=(float)bandgap*1024/adc_9gallery_res;
    //計算ADC通道測得電壓值
    ADC_voltage=(float)bandgap*adc_res10/adc_9gallery_res;
        //R=10000*ADC_voltage/(power_voltage-ADC_voltage);
                R=(power_voltage-ADC_voltage)/(ADC_voltage/10500);
                NTC_R=R;//把float浮點數(shù)轉(zhuǎn)化為int型
        //if(ADC_voltage<2000){t_kyjonflag=0;kyjon_delay=0;}
ID:223841 發(fā)表于 2019-2-27 15:33 | 只看該作者
你好,樓主,請問你的電阻 如何計算得來的?    //計算系統(tǒng)供電電壓
    //計算ADC通道測得電壓值
可以說下如何計算的R?然后跟表對比的。
你有QQ嗎?我正在用這個,急需幫助,謝謝!
無效樓層,該帖已經(jīng)被刪除
7#
ID:143694 發(fā)表于 2020-7-12 10:30 | 只看該作者
fzhlpp 發(fā)表于 2018-4-26 15:02
謝謝樓上幾位的回復(fù),已經(jīng)搞定這個程序了,會了就很簡單了,沒弄好的時候頭緒都沒有,下面是150度部分代碼 ...
666謝大神指點!
ID:450849 發(fā)表于 2020-7-13 08:43 | 只看該作者
這個把電阻表 計算好 轉(zhuǎn)換成AD值,它不想嗎?
ID:241128 發(fā)表于 2020-8-15 10:44 | 只看該作者
boboxuexi 發(fā)表于 2020-7-13 08:43
愿聞其香...
無效樓層,該帖已經(jīng)被刪除
