查看: 5365|回復: 0
60S倒計時,數碼管顯示
ID:105206 發表于 2017-10-19 13:58 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
給別人弄的60S倒計時,數碼管顯示,需要的看看。
#include<reg51.h>
sbit P2_2 = P2^2;
sbit P2_3 = P2^3;
//sbit dula=P2^6;
//sbit wela=P2^7;
sbit beep=P1^4;
sbit start_key=P3^2;
static unsigned char second=60;
//uchar j,k,a1,a0,s=60;
uint m;
//uchar code table[]={0x3f,0x06,0x5b,0x4f,0x66,0x6d,0x7d,
//                        0x07,0x7f,0x6f,0x77,0x7c,0x39,0x5e,0x79,0x71};
uchar code table[]={0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,//數碼管
                        0xf8,0x80,0x90};
void delay(uint nms)
        uint i,j;
  for(i=nms;i>0;i--)
    for(j=125;j>0;j--);
void display()
         P0=table[second/10];
   P2_2 = 0;
   delay(5);
   P2_2 = 1;
    P0=table[second%10];
   P2_3 = 0;
   delay(5);
   P2_3 = 1;
void Timer0Init(void)                //50毫秒@11.0592MHz
//        AUXR &= 0x7F;                //定時器時鐘12T模式
        TMOD &= 0xF0;                //設置定時器模式
        TMOD |= 0x01;                //設置定時器模式
        TL0 = 0x00;                //設置定時初值
        TH0 = 0x4C;                //設置定時初值
        EA=1;
        ET0=1;
        TR0=1;
        uchar a;
        Timer0Init();
                key_scan();
                for(a=100;a>0;a--)
                        display();
           if(second==0)
                        TR0=0;//時間到,定時器關閉
                        beep=0;//蜂
                        delay(300);
                        beep=1;//蜂
void timer0() interrupt 1
        m++;
        if(m==20)
        {        m=0;
                second--;
