只需一步,快速開(kāi)始
查看: 3195|回復(fù): 7
單片機(jī)數(shù)據(jù)存儲(chǔ)出問(wèn)題
ID:208105 發(fā)表于 2017-10-16 20:40 | 顯示全部樓層 |閱讀模式
我做的是密碼鎖,刪除數(shù)據(jù)不能全部刪除,會(huì)有一位亂的數(shù)據(jù)遺留,這是怎么回事啊
以下是我的程序
  1. #include<reg52.h>
  2. #include"1602.h"
  3. #include"delay.h"
  4. #include"keyboard.h"
  5. sbit LED1=P2^0;
  6. sbit LED2=P2^1;
  7. sbit beep=P1^5;
  8. unsigned char data password[]={1,2,3,4,5,6};
  9. void sound()
  10. {
  11. int t=2000;
  12. while(t--)
  13. {
  14.     beep=~beep;
  15.     delay(50);
  16. }
  17. }
  18. /*------------------------------------------------
  19.                     Ö÷³ÌÐò
  20. ------------------------------------------------*/
  21. main()
  22. {
  23. unsigned char num,i,j;
  24. unsigned char passwordtemp[6],inputtimes;
  25. unsigned char passwordlength,PLEN;
  26. bit Flag;
  27. PLEN=sizeof(password)/sizeof(password[0]);
  28. LCD_Init();
  29. DelayMs(10);
  30. LCD_Clear();
  31. LCD_Write_String(0,0,"  Welcome! ");
  32. LCD_Write_String(0,1,"Input password!");
  33.   while (1)
  34.   {
  35.     num=KeyPro();
  36.     if(num!=0xff)
  37.    {
  38.     if(i==0)
  39.    LCD_Write_String(0,1,"                ");
  40.    if(i<6)
  41.    {
  42.        passwordtemp[i]=num;
  43.        LCD_Write_Char(i,1,num+'0');
  44.    }
  45.   if(num=='A')
  46.   {
  47.     i=0;
  48.     LCD_Clear();
  49.     LCD_Init();
  50.         LCD_Write_Char(i,1,num+'0');
  51.      passwordtemp[i]=0;
  52.      }
  53.    i++;
  54.   if(i==7)
  55.    {
  56.       passwordlength=i-1;
  57.    i=0;
  58.    if(passwordlength==PLEN)
  59.      {
  60.       Flag=1;
  61.       for(j=0;j<PLEN;j++)
  62.          Flag=Flag&&(passwordtemp[j]==password[j]);
  63.          }
  64.       if(Flag)
  65.     {
  66.        LCD_Write_String(0,1,"          ");
  67.         LCD_Write_String(0,1,"   Lock open!");
  68.      LED1=0;
  69.      LED2=0;
  70.         inputtimes=0;
  71.         Flag=0;
  72.   }
  73.    else
  74.      {
  75.     LCD_Write_String(0,1,"          ");
  76.     LCD_Write_String(0,1,"  try again!!!");
  77.     sound();
  78.     inputtimes++;
  79.     if(inputtimes==3)
  80.     {
  81.        LCD_Write_String(0,1,"                ");
  82.        LCD_Write_String(0,1,"Wrong 3 times!");
  83.        while(1);
  84.     }
  85.   }
  86.    }
  87.     }
  88.   }
  89. }
ID:123289 發(fā)表于 2017-10-17 19:44 | 顯示全部樓層
刪除與顯示構(gòu)思不好!
刪除只需在記錄區(qū)做個(gè)標(biāo)記,顯示時(shí)看到這個(gè)標(biāo)記就不顯示(或顯示一個(gè)提示信息)。你看這個(gè)建議如何?
ID:208105 發(fā)表于 2017-10-17 21:10 | 顯示全部樓層
if(num=='B')                 {                         i=-2;                         LCD_Clear();                         LCD_Init();                                   i++;                         if(i==0)                 LCD_Write_String(0,1,"                ");                         if(i<6)                         {                            LCD_Write_Data(password[i]);                                  password[i]=num;                                  LCD_Write_Char(i,1,num+'0');                         }                         if(i==7)                         {                                                  LCD_Write_String(0,0," new password         ");         LCD_Write_String(0,1," ");                                   LCD_Write_Char(i,1,num+'0');                                   Flag=1;       }
ID:208105 發(fā)表于 2017-10-17 21:11 | 顯示全部樓層
刪除的程序可以用嗎,我之前的問(wèn)題已經(jīng)解決了
if(num=='B')
                        i=-2;
                        LCD_Clear();
                        LCD_Init();
                        i++;
                        if(i==0)
                        if(i<6)
                                 password[i]=num;
                        if(i==7)
                                  Flag=1;
ID:111634 發(fā)表于 2017-10-17 21:14 | 顯示全部樓層
你要?jiǎng)h除什么數(shù)據(jù)?是密碼鎖EPROM中的密碼數(shù)據(jù)嗎?
ID:208105 發(fā)表于 2017-10-17 21:28 | 顯示全部樓層
修改這里面的數(shù)據(jù)password[]={1,2,3,4,5,6},一直修改不了,程序好像沒(méi)有進(jìn)去執(zhí)行
ID:166645 發(fā)表于 2017-10-17 22:26 | 顯示全部樓層
一般請(qǐng)教別人找問(wèn)題的程序問(wèn)題,,你首先要做到一個(gè)好的注釋?zhuān)奖銊e人快速的找到你的問(wèn)題,你這樣發(fā)程序,比人還要重頭研究一遍
評(píng)分
參與人數(shù) 1黑幣 +20 收起 理由
admin + 20 回帖助人的獎(jiǎng)勵(lì)!
查看全部評(píng)分
ID:111634 發(fā)表于 2017-10-18 21:08 | 顯示全部樓層
rrrlll 發(fā)表于 2017-10-17 21:28
在定義password[]時(shí)不要賦值,在程序運(yùn)行后在賦值和修改。
