- [文件名] C51音樂程序(八月桂花)
- [功能] 通過單片機(jī)演奏音樂
- #include <REG52.H>
- #include <INTRINS.H>
- //本例采用89C52, 晶振為12MHZ
- //關(guān)于如何編制音樂代碼, 其實(shí)十分簡(jiǎn)單,各位可以看以下代碼.
- //頻率常數(shù)即音樂術(shù)語(yǔ)中的音調(diào),而節(jié)拍常數(shù)即音樂術(shù)語(yǔ)中的多少拍;
- //所以拿出譜子, 試探編吧!
- sbit Beep = P1^5;
- unsigned char n=0; //n為節(jié)拍常數(shù)變量
- unsigned char code music_tab[] ={
- 0x18, 0x30, 0x1C , 0x10, //格式為: 頻率常數(shù), 節(jié)拍常數(shù), 頻率常數(shù), 節(jié)拍常數(shù),
- 0x20, 0x40, 0x1C , 0x10,
- 0x18, 0x10, 0x20 , 0x10,
- 0x1C, 0x10, 0x18 , 0x40,
- 0x1C, 0x20, 0x20 , 0x20,
- 0x1C, 0x20, 0x18 , 0x20,
- 0x20, 0x80, 0xFF , 0x20,
- 0x30, 0x1C, 0x10 , 0x18,
- 0x20, 0x15, 0x20 , 0x1C,
- 0x20, 0x20, 0x20 , 0x26,
- 0x40, 0x20, 0x20 , 0x2B,
- 0x20, 0x26, 0x20 , 0x20,
- 0x20, 0x30, 0x80 , 0xFF,
- 0x20, 0x20, 0x1C , 0x10,
- 0x18, 0x10, 0x20 , 0x20,
- 0x26, 0x20, 0x2B , 0x20,
- 0x30, 0x20, 0x2B , 0x40,
- 0x20, 0x30, 0x1C , 0x10,
- 0x18, 0x20, 0x15 , 0x20,
- 0x26, 0x40, 0x20 , 0x20,
- 0x2B, 0x20, 0x26 , 0x20,
- 0x20, 0x20, 0x30 , 0x80,
- 0x20, 0x10, 0x1C , 0x10,
- 0x20, 0x20, 0x26 , 0x20,
- 0x2B, 0x20, 0x30 , 0x20,
- 0x2B, 0x40, 0x20 , 0x15,
- 0x1F, 0x05, 0x20 , 0x10,
- 0x1C, 0x10, 0x20 , 0x20,
- 0x20, 0x20, 0x30 , 0x30,
- 0x18, 0x40, 0x1C , 0x20,
- 0x20, 0x20, 0x26 , 0x40,
- 0x13, 0x60, 0x18 , 0x20,
- 0x15, 0x40, 0x13 , 0x40,
- 0x18, 0x80, 0x00
- void int0() interrupt 1 //采用中斷0 控制節(jié)拍
- { TH0=0xd8;
- TL0=0xef;
- n--;
- void delay (unsigned char m) //控制頻率延時(shí)
- unsigned i=3*m;
- while(--i);
- void delayms(unsigned char a) //豪秒延時(shí)子程序
- while(--a); //采用while(--a) 不要采用while(a--); 各位可編譯一下看看匯編結(jié)果就知道了!
- void main()
- { unsigned char p,m; //m為頻率常數(shù)變量
- unsigned char i=0;
- TMOD&=0x0f;
- TMOD|=0x01;
- TH0=0xd8;TL0=0xef;
- IE=0x82;
- play:
- while(1)
- a: p=music_tab[i];
- if(p==0x00) { i=0, delayms(1000); goto play;} //如果碰到結(jié)束符,延時(shí)1秒,回到開始再來一遍
- else if(p==0xff) { i=i+1;delayms(100),TR0=0; goto a;} //若碰到休止符,延時(shí)100ms,繼續(xù)取下一音符
- else {m=music_tab[i++], n=music_tab[i++];} //取頻率常數(shù) 和 節(jié)拍常數(shù)
- TR0=1; //開定時(shí)器1
- while(n!=0) Beep=~Beep,delay(m); //等待節(jié)拍完成, 通過P1口輸出音頻(可多聲道哦!)
- TR0=0; //關(guān)定時(shí)器1
