新手上傳一個(gè)自用程序
標(biāo)題: 定時(shí)器中斷 24小時(shí)時(shí)鐘程序
效果: 數(shù)碼管顯示24小時(shí)制時(shí)鐘
工作于:LY5A-L2A開發(fā)板
作者: 林洋電子吧
說明: 板使用12M晶振
- //頭文件:
- #include<reg51.h>
- #include<intrins.h>
- #include<math.h>
- #define uchar unsigned char
- #define uint unsigned int
- #define S_RST DS_RST=1
- #define C_RST DS_RST=0
- #define S_CLK DS_CLK=1
- #define C_CLK DS_CLK=0
- //引腳定義:
- sbit SMG_q = P3^4; //定義數(shù)碼管陽級控制腳(千位)
- sbit SMG_b = P3^5; //定義數(shù)碼管陽級控制腳(百位)
- sbit SMG_s = P3^6; //定義數(shù)碼管陽級控制腳(十位)
- sbit SMG_g = P3^7; //定義數(shù)碼管陽級控制腳(個(gè)位)
- sbit IR=P3^3; //紅外接收數(shù)據(jù)引腳,
- sbit DS_RST = P0^0; //DS復(fù)位端
- sbit DS_IO = P0^1; //IO端
- sbit DS_CLK = P0^2; //SCLK端
- sbit SPK = P0^7; //續(xù)電器
- sbit LED = P0^6;
- sbit LED1 = P0^5;
- //變量定義:
- code unsigned char table[]=
- {0xc0,0xf9,0xa4,0xb0,0x99,0x92,0x82,0xf8,0x80,0x90,0xBF};
- //表:共陽數(shù)碼管 0-9
- unsigned char l_posit=0; //顯示位置
- unsigned char ly_tt=0; //作為計(jì)數(shù)時(shí)間量
- unsigned char SET=0; //設(shè)置標(biāo)識
- unsigned char dskg=0;
- unsigned char ddss=0;//掉電標(biāo)識
- unsigned char ss=0; //閃爍標(biāo)識
- unsigned char ss1=0;
- unsigned char ss2=0;
- unsigned char ss3=0;
- unsigned char ts1=0;
- signed char time;
- unsigned char shi;
- unsigned char fen;
- unsigned char miao;
- unsigned char yue;
- unsigned char ri;
- unsigned char nian;
- unsigned char zhou;
- unsigned char qi;
- unsigned char ba;
- unsigned char sh;
- unsigned char ge;
- //函數(shù)聲明:
- void display(unsigned char q,unsigned char b,unsigned char s,unsigned char g);//定義顯示函數(shù),參數(shù)為顯示時(shí)分
- void delay(uint a);
- void init(); //初如化函數(shù)
- void gettime();
- uchar BCD_s(uchar BCDs);
- uchar s_BCD(uchar sBCD);
- void RW_DS1302(uchar reg, uchar byte);
- uchar Read_DS1302(uchar reg);//從DS1302寄存器讀數(shù)據(jù)
- void DS1302_InputByte(uchar byte); //往DS1302寫入1Byte數(shù)據(jù)
- uchar DS1302_OutputByte(void); //從DS1302讀取1Byte數(shù)據(jù)
- void ts();
- /**************************紅外接收處理***********************************
- unsigned char irtime;//紅外用全局變量
- bit irpro_ok=0,irok=0;
- unsigned char IRcord[4];
- unsigned char irdata[33];
- unsigned char xs=0;
- unsigned char xstt=2;
- unsigned char xs_tt=0;
- signed char ds_time;
- unsigned char k_fen;
- unsigned char k_shi;
- unsigned char g_fen;
- unsigned char g_shi;
- signed char date;
- 函數(shù)聲明
- void Ir_work(void);
- void Ircordpro(void);
- void EX0init(void);
- void TIM0init(void);//定時(shí)器0初始化
- //初始化函數(shù)
- void init()
- P1=0XFF;
- SMG_q=0;
- SMG_b=0;
- SMG_s=0;
- SMG_g=0;
- SPK=1;
- delay(500);
- // TMOD=0X02; //設(shè)置定時(shí)器1為模式一,即16位計(jì)算模式
- // TH0=0X00;
- // TL0=0X00;
- // EA=1; //開啟總中斷
- // ET0=1; //開啟定時(shí)器0中斷
- // TR0=1; //啟動定時(shí)器
- // EX1=1; //開啟外部中斷1,紅外接收數(shù)據(jù)引腳
- // IT1=1; //設(shè)置成下降沿觸發(fā)方式
- RW_DS1302(0x8e,0x80);delay(10);
- delay(500);
- //顯示函數(shù),參數(shù)為顯示內(nèi)容
- P1=0XFF; //
- switch(l_posit){
- case 0: //選擇千位數(shù)碼管,關(guān)閉其它位
- SMG_q=1;
- SMG_b=0;
- SMG_s=0;
- SMG_g=0;
- P1=table[q/10]; //輸出顯示內(nèi)容
- break;
- case 1: //選擇百位數(shù)碼管,關(guān)閉其它位
- SMG_q=0;
- SMG_b=1;
- SMG_s=0;
- SMG_g=0;
- P1=table[b%10];
- break;
- case 2: //選擇十位數(shù)碼管,關(guān)閉其它位
- SMG_q=0;
- SMG_b=0;
- SMG_s=1;
- SMG_g=0;
- P1=table[s/10];
- break;
- case 3: //選擇個(gè)位數(shù)碼管,關(guān)閉其它位
- SMG_q=0;
- SMG_b=0;
- SMG_s=0;
- SMG_g=1;
- P1=table[g%10];
- break;
- l_posit++; //每調(diào)用一次將輪流顯示一位
- if(l_posit>3)
- l_posit=0;
- //延時(shí)子函數(shù),短暫延時(shí)
- uint k;
- while(a--)
- for(k=0;k<120;k++){;}
- * DS1302時(shí)鐘芯片程序段 *
- void DS1302_InputByte(uchar byte) //往DS1302寫入1Byte數(shù)據(jù)
- uchar i;
- uchar temp;
- temp = byte;
- for(i=8; i>0; i--)
- DS_IO = temp&0x01;
- S_CLK;
- C_CLK;
- temp = temp >> 1;
- uchar DS1302_OutputByte(void) //從DS1302讀取1Byte數(shù)據(jù)
- uchar i;
- uchar temp=0;
- for(i=0; i<8;i++)
- C_CLK;
- if(DS_IO!=0) temp|=(1<<i);
- S_CLK;
- return(temp);
- void RW_DS1302(uchar reg, uchar byte)//向DS1302寄存器寫數(shù)據(jù)
- C_RST;
- C_CLK;
- S_RST;
- DS1302_InputByte(reg);
- DS1302_InputByte(byte);
- S_CLK;
- C_RST;
- uchar Read_DS1302(uchar reg)//從DS1302寄存器讀數(shù)據(jù)
- uchar byte;
- C_RST;
- C_CLK;
- S_RST;
- byte = DS1302_OutputByte();
- S_CLK;
- C_RST;
- return(byte);
- //////////////////////////////////////////////轉(zhuǎn)碼
- uchar BCD_s(uchar BCDs)//十六進(jìn)制轉(zhuǎn)化為10進(jìn)制
- BCDs=(BCDs>>4)*10+(BCDs&0x0f);//將讀出來的十六進(jìn)制轉(zhuǎn)化為10進(jìn)制
- delay(1);
- return(BCDs);
- uchar s_BCD(uchar sBCD)//10進(jìn)制轉(zhuǎn)化為十六進(jìn)制
- sBCD=((sBCD/10)<<4)+(sBCD%10);//將10進(jìn)制轉(zhuǎn)化為十六進(jìn)制
- delay(1);
- return(sBCD);
- void gettime()
- time=Read_DS1302(0x85);//讀小時(shí)
- shi=BCD_s(time);
- time=Read_DS1302(0x83);//讀分
- fen=BCD_s(time);
- time=Read_DS1302(0x81);//讀秒
- time&=0x7f;//這句代碼的意思是:因?yàn)槊氲淖罡呶坏谄呶环譃閮煞N可能,一:它是0,如果是0的話,時(shí)鐘會自動的計(jì)時(shí),如果是1的話,時(shí)鐘會停止走動,相當(dāng)于中斷
- miao=BCD_s(time);//將分讀出來的十六進(jìn)制轉(zhuǎn)化為10進(jìn)制
- time=Read_DS1302(0x89);//讀月
- yue=BCD_s(time);
- time=Read_DS1302(0x87);//讀日
- ri=BCD_s(time);
- time=Read_DS1302(0x8D);//讀年
- nian=BCD_s(time);
- time=Read_DS1302(0x8b);//讀zhou
- zhou=BCD_s(time);
- ds_time=Read_DS1302(0xc1);
- k_fen=BCD_s(ds_time);
- ds_time=Read_DS1302(0xc9);
- k_shi=BCD_s(ds_time);
- ds_time=Read_DS1302(0xc5);
- g_fen=BCD_s(ds_time);
- ds_time=Read_DS1302(0xc7);
- g_shi=BCD_s(ds_time);
- 定時(shí)器0中斷處理
- void tim0_isr (void) interrupt 1 using 1
- irtime++; //用于計(jì)數(shù)2個(gè)下降沿之間的時(shí)間
- xs_tt++;
- if(xs_tt==xstt){xs_tt=0;} //亮度變量
- if(xs_tt==1)
- { if(ss==1)
- { if(ss2>=10)
- { SMG_q=0;
- SMG_b=0;
- SMG_s=0;
- SMG_g=0;
- P0=0xFF;
- else
- display(qi,ba,sh,ge);
- else
- else
- P1=0xFF;
- ss1++;
- if(ss1==250)
- { ss1=0;
- ss2++;
- if(ss2==16)
- { ss2=0;
- /*void tim1_isr (void) interrupt 3
- xs_tt++;
- if(xs_tt==1)
- {display();}
- else
- P0=0xFF;
- 外部中斷0中斷處理
- void EX0_ISR (void) interrupt 2 //外部中斷0服務(wù)函數(shù)
- static unsigned char i; //接收紅外信號處理
- static bit startflag; //是否開始處理標(biāo)志位
- if(startflag)
- if(irtime<63&&irtime>=33)//引導(dǎo)碼 TC9012的頭碼,9ms+4.5ms
- i=0;
- irdata[i]=irtime;//存儲每個(gè)電平的持續(xù)時(shí)間,用于以后判斷是0還是1
- irtime=0;
- i++;
- if(i==33)
- irok=1;
- i=0;
- else
- irtime=0;
- startflag=1;
- 定時(shí)器0初始化
- void TIM0init(void)//定時(shí)器0初始化
- TMOD=0x02;//定時(shí)器0工作方式2,TH0是重裝值,TL0是初值
- TH0=0x00; //重載值
- TL0=0x00; //初始化值
- ET0=1; //開中斷
- TR0=1;
- // TH1=0x00; //重載值
- // TL1=0x00; //初始化值
- // TR1=1;
- // ET1=1; //開中斷
- 外部中斷0初始化
- IT1 = 1; //指定外部中斷0下降沿觸發(fā),INT0 (P3.2)
- EX1 = 1; //使能外部中斷
- EA = 1; //開總中斷
- 鍵值處理
- void Ir_work(void)//紅外鍵值散轉(zhuǎn)程序
- // uchar date;
- if(SET==0){
- switch(IRcord[2])//判斷第三個(gè)數(shù)碼值
- case 0x16:if(IRcord[3]==0xe9){
- ddss=1;}
- break;//1 顯示相應(yīng)的按鍵值
- case 0x0c:if(IRcord[3]==0xf3){
- xs=0;}
- case 0x18:if(IRcord[3]==0xe7){
- xs=1;}
- case 0x5e:if(IRcord[3]==0xa1){
- xs=2;}
- case 0x0d:if(IRcord[3]==0xf2){
- xstt=2;}
- case 0x19:if(IRcord[3]==0xe6){
- xstt=15;}
- // case 0x0d:if(IRcord[3]==0xf2){
- // xstt=30;}
- // break;//1 顯示相應(yīng)的按鍵值
- case 0x09:if(IRcord[3]==0xf6){
- SPK=~SPK;}
- case 0x15:if(IRcord[3]==0xea){
- dskg=1;}
- case 0x07:if(IRcord[3]==0xf8){
- dskg=0;}
- default:break;
- // IRcord[2]=0;
- if(SET==0){
- if(IRcord[2]==0x42){
- if(IRcord[3]==0xbd){
- RW_DS1302(0x8e,0x00);delay(10);//允許寫操作
- date=Read_DS1302(0x81);//先將秒讀出來
- date=0x80|date;//這句就是將秒置為最高位
- RW_DS1302(0x80,date);delay(10);//再將秒寫進(jìn)去
- RW_DS1302(0x8e,0x80);delay(10);//寫完了關(guān)閉
- SET=1;ss=1;}
- IRcord[2]=0;
- irpro_ok=0;}
- if(IRcord[2]==0x08){
- if(IRcord[3]==0xf7){
- SET=4;}
- IRcord[2]=0;
- irpro_ok=0;}}
- if(SET==1){
- SET=2;ss=1;
- IRcord[2]=0;
- irpro_ok=0;}}
- if(IRcord[2]==0x4a){
- if(IRcord[3]==0xb5){
- time=BCD_s(time);//這是修改分的主要代碼,好好研究就成了
- time++;
- if(time>59)
- time=0;
- time=s_BCD(time);
- RW_DS1302(0x82,time);
- IRcord[2]=0;
- irpro_ok=0;}}
- if(IRcord[2]==0x52){
- if(IRcord[3]==0xad){
- time=BCD_s(time);
- time++;
- if(time>23)
- time=0;
- time=s_BCD(time);
- RW_DS1302(0x84,time);
- IRcord[2]=0;
- irpro_ok=0;}}}
- if(SET==2){
- SET=3;ss=1;
- IRcord[2]=0;
- irpro_ok=0;}}
- time++;
- if(time>31)
- time=1;
- time=s_BCD(time);
- RW_DS1302(0x86,time);
- IRcord[2]=0;
- irpro_ok=0;}}
- time=BCD_s(time);
- time++;
- if(time>12)
- time=1;
- time=s_BCD(time);
- RW_DS1302(0x88,time);
- IRcord[2]=0;
- irpro_ok=0;}}
- if(SET==3){
- date&=0x7f;//將秒的最高位置零表示重新開始工作
- SET=0;
- ss=0;}
- IRcord[2]=0;
- irpro_ok=0;}
- time=BCD_s(time);
- time++;
- if(time>99)
- time=0;
- time=s_BCD(time);
- RW_DS1302(0x8C,time);
- IRcord[2]=0;
- irpro_ok=0;}}
- time=Read_DS1302(0x8B);
- time=BCD_s(time);
- time++;
- if(time>7)
- time=1;
- time=s_BCD(time);
- RW_DS1302(0x8A,time);
- IRcord[2]=0;
- irpro_ok=0;}}
- /* if(SET==4){
- SET=0;
- ss=0;}
- IRcord[2]=0;
- irpro_ok=0;}} */
- if(SET==4){
- SET=5;ss=1;
- IRcord[2]=0;
- irpro_ok=0;}}
- if(IRcord[2]==0x5a){
- if(IRcord[3]==0xa5){
- ds_time=BCD_s(ds_time);
- ds_time++;
- if(ds_time>59)
- ds_time=0;
- ds_time=s_BCD(ds_time);
- RW_DS1302(0xc0,ds_time);
- IRcord[2]=0;
- irpro_ok=0;}}
- if(IRcord[2]==0x1c){
- if(IRcord[3]==0xe3){
- ds_time++;
- if(ds_time>23)
- ds_time=0;
- RW_DS1302(0xc8,ds_time);
- IRcord[2]=0;
- irpro_ok=0;}}}
- if(SET==5){
- SET=0;ss=0;}
- IRcord[2]=0;
- irpro_ok=0;}
- ds_time++;
- if(ds_time>59)
- ds_time=0;
- RW_DS1302(0xc4,ds_time);
- RW_DS1302(0x8e,0x80);}
- IRcord[2]=0;
- irpro_ok=0;}
- ds_time++;
- if(ds_time>23)
- ds_time=0;
- RW_DS1302(0xc6,ds_time);
- RW_DS1302(0x8e,0x80); }
- IRcord[2]=0;
- irpro_ok=0;}}
- irpro_ok=0;//處理完成標(biāo)志
- 紅外碼值處理
- void Ircordpro(void)//紅外碼值處理函數(shù)
- unsigned char i, j, k;
- unsigned char cord,value;
- k=1;
- for(i=0;i<4;i++) //處理4個(gè)字節(jié)
- for(j=1;j<=8;j++) //處理1個(gè)字節(jié)8位
- cord=irdata[k];
- if(cord>7)//大于某值為1,這個(gè)和晶振有絕對關(guān)系,這里使用12M計(jì)算,此值可以有一定誤差
- value|=0x80;
- if(j<8)
- value>>=1;
- k++;
- IRcord[i]=value;
- value=0;
- irpro_ok=1;//處理完畢標(biāo)志位置1
- //主函數(shù),C語言的入口函數(shù):
- void main()
- init(); //初始化中斷控制寄存器
- EX0init(); //初始化外部中斷
- TIM0init();//初始化定時(shí)器
- while(1)
- if(ss2==2)
- gettime();
- if(irok) //如果接收好了進(jìn)行紅外處理
- Ircordpro();
- irok=0;
- if(irpro_ok) //如果處理好后進(jìn)行工作處理,如按對應(yīng)的按鍵后顯示對應(yīng)的數(shù)字等
- Ir_work();
- if(dskg==1)
- { if(shi==k_shi)
- { if(fen==k_fen)
- { SPK=0; }
- if(shi==g_shi)
- { if(fen==g_fen)
- { SPK=1; }
- /* if(SET==0)
- { qi=shi;
- ba=shi;
- sh=fen;
- ge=fen;
- if(ss2>=8)
- { LED=0;}
- else
- LED=1;
- if(SET==1)
- { qi=shi;
- ba=shi;
- sh=fen;
- ge=fen;
- LED=0;}
- if(SET==2)
- { qi=yue;
- ba=yue;
- sh=ri;
- ge=ri;
- LED=1;}
- if(SET==3)
- { qi=nian;
- ba=nian;
- sh=0;
- ge=zhou;
- LED=1;}
- /* if(SET==4)
- { qi=shi;
- ba=shi;
- sh=fen;
- ge=fen;
- LED=1;}*/
- if(SET==4)
- { ss=1;
- qi=k_shi;
- ba=k_shi;
- sh=k_fen;
- ge=k_fen;
- if(ss2>=8)
- { LED=0;}
- else
- LED=1;
- if(SET==5)
- { ss=1;
- qi=g_shi;
- ba=g_shi;
- sh=g_fen;
- ge=g_fen;
- if(ss2>=8)
- { LED=0;}
- else
- LED=1;
- if(SET==0){
- if(xs==0)
- { qi=shi;
- ba=shi;
- sh=fen;
- ge=fen;
- LED=1;
- if(ss2>=8)
- { LED=0;}
- else
- LED=1;}
- if(xs==1)
- { qi=yue;
- ba=yue;
- sh=ri;
- ge=ri;
- LED=1;}
- if(xs==2)
- { qi=zhou;
- ba=zhou;
- sh=miao;
- ge=miao;
- LED=1;} }
- if(dskg==1)
- { LED1=0;}
- if(dskg==0)
- { LED1=1;}
- if(ddss==0)
- { if(ss2>=8)
- { LED1=0;}
- else
- LED1=1;
- if(shi==7)
- { xstt=2;}
- if(shi==19)
- { xstt=15;}
- if(zhou==6)
- { ts();}
- ////////////////////////////////////////////時(shí)間校準(zhǔn)
- void ts()
- if(shi==0)
- { if(fen==0)
- { if(miao==30)//0x30是30秒
- { ts1=1;
- if(ts1==1)
- { if(shi==1)
- { if(fen==1)
- { if(miao==15)
- { ts1=0;
- RW_DS1302(0x80,0x31);delay(10);//0x80寫秒0x30就是31秒
