如題。計算器的運行界面如下:
2017-10-15 23:54 上傳
Calculators.rar
(63.24 KB, 下載次數(shù): 29)
2017-10-15 11:26 上傳
下載積分: 黑幣 -5
Visual studio c#計算器源程序如下:
- using System;
- using System.Collections.Generic;
- using System.ComponentModel;
- using System.Data;
- using System.Drawing;
- using System.Linq;
- using System.Text;
- using System.Windows.Forms;
- using System.Text.RegularExpressions;
- using System.Collections;
- namespace Calculators
- public partial class Form1 : Form
- public Form1()
- InitializeComponent();
- private void ShowAsStandard()//“標準型”模式
- groupT.Location = new Point(6, 78);//groupT中存放標準型模式下的按鈕控件
- txtEnterBox.Size = new Size(250, 23);
- txtExpression.Size = new Size(250, 14);
- groupShowWindow.Size = new Size(260, 49);
- groupS.Location = new Point(-333, 77);//groupT中存放科學型模式下特有的按鈕控件
- this.Size = new Size(290, 349);
- private void ShowAsScience()//“科學型”模式
- groupT.Location = new Point(268, 78);
- txtEnterBox.Size = new Size(511, 23);
- txtExpression.Size = new Size(511, 14);
- groupShowWindow.Size = new Size(517, 49);
- groupS.Location = new Point(3, 77);
- this.Size = new Size(551, 349);
- private void Form1_Load(object sender, EventArgs e)
- //界面初始化為“標準型”的樣子
- ShowAsStandard();
- //================標志================================================
- private Expression leftValue = null;//左操作數(shù)
- bool txtEnterBoxClearFlag = true;//是否清除txtEnterBox的標志,是否可啟用backspace的標志
- bool txtExpressionClearFlag = true;//是否清除txtExpression的標志
- bool txtExpressionInsertFlag = true;//是否在txtExpression中插入新數(shù)據(jù)的標志
- bool btnBackSpaceEnableFlag = true;//是否啟用BackSpace鍵
- string op;//操作符
- Expression expression = null;//表達式對象
- private void btn0_Click(object sender, EventArgs e)//數(shù)字及點號按鈕被按下時觸發(fā)該事件
- Button btn = sender as Button;
- if (txtEnterBoxClearFlag)
- txtEnterBox.Clear();
- if (txtExpressionClearFlag)
- txtExpression.Clear();
- txtEnterBox.Text += btn.Text;
- txtEnterBoxClearFlag = false;
- txtExpressionClearFlag = false;
- btnBackSpaceEnableFlag = true;
- private void buttonClear_Click(object sender, EventArgs e)
- #region 清除數(shù)字顯示框、表達式顯示框及左操作數(shù)
- txtEnterBox.Text = "0";
- txtExpression.Text = "";
- leftValue = null;//左操作數(shù)清空
- #endregion
- private void txtEnterBox_TextChanged(object sender, EventArgs e)
- #region 檢查輸入數(shù)字是否規(guī)范
- if (Regex.IsMatch(txtEnterBox.Text, "^[0]+[1-9]+")) //1.非小數(shù)數(shù)字不能以0開頭。
- txtEnterBox.Text = Regex.Replace(txtEnterBox.Text, "^0+", "");
- if (Regex.IsMatch(txtEnterBox.Text, "^0+"))//2.數(shù)字開頭不能連續(xù)輸入多個0,最多只能輸入一個
- txtEnterBox.Text = Regex.Replace(txtEnterBox.Text, "^0+", "0");
- if (Regex.IsMatch(txtEnterBox.Text, "[.].*[.]"))//3.數(shù)字中小數(shù)點個數(shù)不能超過1
- txtEnterBox.Text = Regex.Replace(txtEnterBox.Text, "[.]{1}$", "");
- #endregion
- private void btnNegative_Click(object sender, EventArgs e)
- #region 將輸入框中的數(shù)字乘以-1
- double dTemp = Convert.ToDouble(txtEnterBox.Text);
- dTemp = dTemp * (-1);
- txtEnterBox.Text = dTemp.ToString();
- #endregion
- private void btnAdd_Click(object sender, EventArgs e)//雙目運算符:加減乘除、取余按鈕按下時觸發(fā)該事件
- if (txtExpressionInsertFlag)
- txtExpression.Text += txtEnterBox.Text + btn.Text;//表達式顯示控件添加數(shù)值輸入控件中的值和操作符的值
- else
- txtExpression.Text += btn.Text;//表達式顯示控件僅添加操作符的值
- if (leftValue == null)
- leftValue = new Constant(Convert.ToDouble(txtEnterBox.Text));//創(chuàng)建左操作數(shù)
- else
- Constant RightVaue = new Constant(Convert.ToDouble(txtEnterBox.Text));//創(chuàng)建右操作數(shù)
- expression = new Operation(leftValue, op, RightVaue);//創(chuàng)建表達式
- leftValue = expression;//將表達式賦值給左操作數(shù)
- txtEnterBox.Text = expression.Evaluate().ToString();//數(shù)值輸入控件顯示當前計算值
- op = btn.Text;//更新操作符
- txtEnterBoxClearFlag = true;
- txtExpressionInsertFlag = true;
- btnBackSpaceEnableFlag = false;
- private void btnEvaluate_Click(object sender, EventArgs e)//按下等于號按鈕
- if (leftValue != null)
- leftValue = null;//清空左操作數(shù)
- else
- private void btnSqrt_Click(object sender, EventArgs e)//單目運算符:計算平方根,求倒數(shù)按鈕按下時觸發(fā)該事件
- txtExpression.Text +=(string)btn.Tag+ "(" + txtEnterBox.Text + ")";//表達式顯示控件顯示當前表達式
- expression = new Operation(leftValue, btn.Text, null);//創(chuàng)建表達式
- leftValue = null;
- txtExpressionClearFlag = true;
- txtExpressionInsertFlag = false;
- private void btnBackSpace_Click(object sender, EventArgs e)
- if (btnBackSpaceEnableFlag)
- int strLength = txtEnterBox.Text.Length;
- if (strLength==1)
- txtEnterBox.Text = "0";//只剩一個字符時,將該字符修改為0
