只需一步,快速開(kāi)始
查看: 9999|回復(fù): 16
利用ov7670識(shí)別紅綠藍(lán)物體與定位
ID:239323 發(fā)表于 2017-10-14 10:25 | 只看該作者 回帖獎(jiǎng)勵(lì) |倒序?yàn)g覽 |閱讀模式
利用ov7670實(shí)現(xiàn)物體的簡(jiǎn)單識(shí)別及定位
單片機(jī)源程序如下:
  1. #include "led.h"
  2. #include "delay.h"
  3. #include "key.h"
  4. #include "sys.h"
  5. #include "lcd.h"
  6. #include "usart.h"
  7. #include "string.h"
  8. #include "ov7670.h"
  9. #include "tpad.h"
  10. #include "timer.h"
  11. #include "exti.h"
  12. #include "usmart.h"
  13. #include "EasyTracered.h"
  14. /************************************************
  15. ALIENTEK精英STM32開(kāi)發(fā)板實(shí)驗(yàn)33
  16. 攝像頭OV7670 實(shí)驗(yàn)
  17. 作者:正點(diǎn)原子 @ALIENTEK
  18. ************************************************/
  19. const u8*LMODE_TBL[5]={"Auto","Sunny","Cloudy","Office","Home"};                                                        //5種光照模式
  20. const u8*EFFECTS_TBL[7]={"Normal","Negative","B&W","Redish","Greenish","Bluish","Antique"};        //7種特效
  21. extern u8 ov_sta;        //在exit.c里 面定義
  22. extern u8 ov_frame;        //在timer.c里面定義
  23. u16 r0,r1;
  24. u16 g0,g1;
  25. u16 b0,b1;
  26. //更新LCD顯示
  27. void camera_refresh(void)
  28. {
  29.
  30.         RESULT Resured;//判定為的目標(biāo)條件
  31.         RESULT Resugreen;
  32.         RESULT Resublue;
  33.
  34.   TARGET_CONDI Conditionred={215,240,20,240,30,160,30,30,320,240};        //紅色1   API參數(shù)  hsl的閾值,識(shí)別時(shí)用的
  35.   TARGET_CONDI Conditiongreen={70,110,20,240,50,100,30,30,320,240};        //綠色1  API參數(shù)  hls的閾值,識(shí)別時(shí)用的
  36.   TARGET_CONDI Conditionblue={120,160,20,240,30,90,30,30,150,150};        //藍(lán)色1   API參數(shù)  hsl的閾值,識(shí)別時(shí)用的
  37.         u32 j;
  38.          u16 color;
  39.         if(ov_sta)//有幀中斷更新?
  40.         {
  41.                 LCD_Scan_Dir(U2D_L2R);                //從上到下,從左到右
  42.                 if(lcddev.id==0X1963)LCD_Set_Window((lcddev.width-240)/2,(lcddev.height-320)/2,240,320);//將顯示區(qū)域設(shè)置到屏幕中央
  43.                 else if(lcddev.id==0X5510||lcddev.id==0X5310)LCD_Set_Window((lcddev.width-320)/2,(lcddev.height-240)/2,320,240);//將顯示區(qū)域設(shè)置到屏幕中央
  44.                 LCD_WriteRAM_Prepare();     //開(kāi)始寫(xiě)入GRAM
  45.                 OV7670_RRST=0;                                //開(kāi)始復(fù)位讀指針
  46.                 OV7670_RCK_L;
  47.                 OV7670_RCK_H;
  48.                 OV7670_RCK_L;
  49.                 OV7670_RRST=1;                                //復(fù)位讀指針結(jié)束
  50.                 OV7670_RCK_H;
  51.                 for(j=0;j<76800;j++)
  52.                 {
  53.                         OV7670_RCK_L;
  54.                         color=GPIOC->IDR&0XFF;        //讀數(shù)據(jù)
  55.                         OV7670_RCK_H;
  56.                         color<<=8;
  57.                         OV7670_RCK_L;
  58.                         color|=GPIOC->IDR&0XFF;        //讀數(shù)據(jù)
  59.                         OV7670_RCK_H;
  60.                         LCD->LCD_RAM=color;
  61.                 }
  62.      if(Trace(&Conditionred,&Resured) )                      //API
  63.                         {
  64.                                 LCD_Fillred(Resured.x-Resured.w/2,Resured.y-Resured.h/2,Resured.x+Resured.w/2,Resured.y-Resured.h/2+1,0xf800);//u16 x,u16 y,u16 width,u16 hight,u16 Color
  65.                                 LCD_Fillred(Resured.x-Resured.w/2,Resured.y-Resured.h/2,Resured.x-Resured.w/2+1,Resured.y+Resured.h/2,0xf800);
  66.                                 LCD_Fillred(Resured.x-Resured.w/2,Resured.y+Resured.h/2,Resured.x+Resured.w/2,Resured.y+Resured.h/2+1,0xf800);
  67.                                 LCD_Fillred(Resured.x+Resured.w/2,Resured.y-Resured.h/2,Resured.x+Resured.w/2+1,Resured.y+Resured.h/2,0xf800);
  68.                                 LCD_Fillred(Resured.x-2,Resured.y-2,Resured.x+2,Resured.y+2,0xf800);
  69.                                   //LED1=!LED1;
  70.                                   r0=Resured.x;
  71.                                   r1=Resured.y;
  72.                         }
  73.                         if(Trace1(&Conditiongreen,&Resugreen) )                      //API
  74.                         {
  75.                                 LCD_Fillgreen(Resugreen.x-Resugreen.w/2,Resugreen.y-Resugreen.h/2,Resugreen.x+Resugreen.w/2,Resugreen.y-Resugreen.h/2+1,0xf800);//u16 x,u16 y,u16 width,u16 hight,u16 Color
  76.                                 LCD_Fillgreen(Resugreen.x-Resugreen.w/2,Resugreen.y-Resugreen.h/2,Resugreen.x-Resugreen.w/2+1,Resugreen.y+Resugreen.h/2,0xf800);
  77.                                 LCD_Fillgreen(Resugreen.x-Resugreen.w/2,Resugreen.y+Resugreen.h/2,Resugreen.x+Resugreen.w/2,Resugreen.y+Resugreen.h/2+1,0xf800);
  78.                                 LCD_Fillgreen(Resugreen.x+Resugreen.w/2,Resugreen.y-Resugreen.h/2,Resugreen.x+Resugreen.w/2+1,Resugreen.y+Resugreen.h/2,0xf800);
  79.                                 LCD_Fillgreen(Resugreen.x-2,Resugreen.y-2,Resugreen.x+2,Resugreen.y+2,0xf800);
  80.                                  // LED1=!LED1;
  81.                                   g0=Resugreen.x;
  82.                                   g1=Resugreen.y;
  83.                         }
  84.      if(Trace2(&Conditionblue,&Resublue) )                      //API
  85.                         {
  86.                                 LCD_Fillblue(Resublue.x-Resublue.w/2,Resublue.y-Resublue.h/2,Resublue.x+Resublue.w/2,Resublue.y-Resublue.h/2+1,0xf800);//u16 x,u16 y,u16 width,u16 hight,u16 Color
  87.                                 LCD_Fillblue(Resublue.x-Resublue.w/2,Resublue.y-Resublue.h/2,Resublue.x-Resublue.w/2+1,Resublue.y+Resublue.h/2,0xf800);
  88.                                 LCD_Fillblue(Resublue.x-Resublue.w/2,Resublue.y+Resublue.h/2,Resublue.x+Resublue.w/2,Resublue.y+Resublue.h/2+1,0xf800);
  89.                                 LCD_Fillblue(Resublue.x+Resublue.w/2,Resublue.y-Resublue.h/2,Resublue.x+Resublue.w/2+1,Resublue.y+Resublue.h/2,0xf800);
  90.                                 LCD_Fillblue(Resublue.x-2,Resublue.y-2,Resublue.x+2,Resublue.y+2,0xf800);
  91.                                  // LED1=!LED1;
  92.                                   b0=Resublue.x;
  93.                                   b1=Resublue.y;
  94.                         }
  95.                  ov_sta=0;                                        //清零幀中斷標(biāo)記
  96.                 ov_frame++;
  97.                 LCD_Scan_Dir(DFT_SCAN_DIR);        //恢復(fù)默認(rèn)掃描方向
  98.         }
  99. }
  100. int main(void)
  101. {
  102.         u8 lightmode=0,saturation=2,contrast=2;
  103.         u8 effect=0;
  104.          u8 i=0;
  105.         u8 msgbuf[15];                                //消息緩存區(qū)
  106.         u8 tm=0;
  107.         delay_init();                     //延時(shí)函數(shù)初始化
  108.   NVIC_PriorityGroupConfig(NVIC_PriorityGroup_2);//設(shè)置中斷優(yōu)先級(jí)分組為組2:2位搶占優(yōu)先級(jí),2位響應(yīng)優(yōu)先級(jí)
  109.         uart_init(115200);                 //串口初始化為 115200
  110.          usmart_dev.init(72);                //初始化USMART
  111.          LED_Init();                                          //初始化與LED連接的硬件接口
  112.         KEY_Init();                                        //初始化按鍵
  113.         LCD_Init();                                           //初始化LCD
  114.         TPAD_Init(6);                                //觸摸按鍵初始化
  115.          POINT_COLOR=RED;                        //設(shè)置字體為紅色
  116.         LCD_ShowString(30,50,200,16,16,"ELITE STM32F103 ^_^");
  117.   LCD_ShowString(30,210,200,16,16,"OV7670 Init...");
  118.         while(OV7670_Init())//初始化OV7670
  119.         {
  120.                 LCD_ShowString(30,210,200,16,16,"OV7670 Error!!");
  121.                 delay_ms(200);
  122.             LCD_Fill(30,210,239,246,WHITE);
  123.                 delay_ms(200);
  124.         }
  125.          LCD_ShowString(30,210,200,16,16,"OV7670 Init OK");
  126.         delay_ms(1500);
  127.         OV7670_Light_Mode(lightmode);
  128.         OV7670_Color_Saturation(saturation);
  129.         OV7670_Contrast(contrast);
  130.          OV7670_Special_Effects(effect);
  131.
  132.         TIM6_Int_Init(10000,7199);                        //10Khz計(jì)數(shù)頻率,1秒鐘中斷
  133.         EXTI8_Init();                                                //使能定時(shí)器捕獲
  134.         OV7670_Window_Set(12,176,240,320);        //設(shè)置窗口
  135.           OV7670_CS=0;
  136.         LCD_Clear(BLACK);
  137.          while(1)
  138.         {
  139.
  140.                 camera_refresh();//更新顯示
  141.                  if(tm)
  142.                 {
  143.                         LCD_ShowString((lcddev.width-240)/2+30,(lcddev.height-320)/2+60,200,16,16,msgbuf);
  144.                         tm--;
  145.                 }
  146.                 i++;
  147.                 if(i==15)//DS0閃爍.
  148.                 {
  149.                         i=0;
  150.                         LED0=!LED0;
  151.                  }
  152.         }
  153. }
識(shí)別紅綠藍(lán)并鎖定.rar (392.16 KB, 下載次數(shù): 156)
收藏收藏8 分享淘帖 頂2 踩
ID:221722 發(fā)表于 2017-10-15 11:15 | 只看該作者
感謝樓主分享
ID:288639 發(fā)表于 2018-3-7 12:42 | 只看該作者
感謝樓主分享
ID:159774 發(fā)表于 2018-5-3 10:53 | 只看該作者
感謝樓主分享
ID:322777 發(fā)表于 2018-5-5 14:31 | 只看該作者
謝謝樓主分享
ID:319344 發(fā)表于 2018-5-6 11:08 | 只看該作者
在正點(diǎn)原子OV7670的基礎(chǔ)上做了一些更改,去掉了按鍵相關(guān)部分,main.c的更新顯示函數(shù),在照片更新后進(jìn)行判斷,追蹤顏色,然后那一塊兒就被紅或綠或藍(lán)圍了一個(gè)框,中間還有一個(gè)點(diǎn)。屏幕你用的是7寸屏吧?圖片是640*480的,真是貧窮限制了我的想象,不過(guò)你設(shè)置的顯示窗口是320*240,我不太理解
內(nèi)部的那些函數(shù)還沒(méi)看很懂,不過(guò)還是學(xué)到了些東西,函數(shù)的參數(shù)&,然后就可以將其值返回,之后可以直接使用,很有用。
可能是我能力還有所欠缺吧,看得很慢,而且因?yàn)閰?shù)多,注釋少,現(xiàn)在還是云里霧里,等我完全看懂后,添加上注釋發(fā)一份吧,方便大家理解
ID:138852 發(fā)表于 2018-5-14 17:23 | 只看該作者
樓主看懂了嗎,有沒(méi)有注釋版,求分享
ID:308469 發(fā)表于 2018-6-7 23:03 | 只看該作者
wenzedong 發(fā)表于 2018-5-6 11:08
在正點(diǎn)原子OV7670的基礎(chǔ)上做了一些更改,去掉了按鍵相關(guān)部分,main.c的更新顯示函數(shù),在照片更新后進(jìn)行判斷 ...
看懂了嗎?能解釋解釋?zhuān)?/td>
ID:267330 發(fā)表于 2019-2-26 18:38 | 只看該作者
感謝樓主分享
ID:267330 發(fā)表于 2019-2-28 17:52 | 只看該作者
ID:267330 發(fā)表于 2019-3-5 16:00 | 只看該作者
謝謝樓主分享,正在學(xué)習(xí)
ID:138247 發(fā)表于 2019-5-2 15:28 | 只看該作者
謝謝樓主分享。。
ID:199471 發(fā)表于 2019-6-14 09:20 | 只看該作者
謝謝樓主,好東西啊
ID:411625 發(fā)表于 2019-8-2 20:09 | 只看該作者
感謝樓主分享
ID:612668 發(fā)表于 2019-10-8 16:23 | 只看該作者
感謝樓主分享感謝樓主分享感謝樓主分享
ID:620995 發(fā)表于 2019-10-9 11:39 | 只看該作者
感謝樓主分享
ID:641287 發(fā)表于 2019-12-5 10:08 | 只看該作者
你下載這個(gè)程序代碼可以直接打開(kāi)工程嗎,還是自己建一個(gè)
