查看: 4815|回復: 4
VB串口和單片機讀IC卡上位機源程序
VB寫的串口和單片機讀卡程序 有需要的下
自己寫的通過串口和單片機通訊的ic卡讀卡程序.rar (55.17 KB, 下載次數: 73)
vb源程序如下:
  1. Attribute VB_Name = "IC卡管理自動記錄系統"
  2. Attribute VB_GlobalNameSpace = False
  3. Attribute VB_Creatable = False
  4. Attribute VB_PredeclaredId = True
  5. Attribute VB_Exposed = False
  6. Option Explicit
  7. Public inData As String '串口中斷時讀入的字符串
  8. Dim TEXT_OK As Boolean
  9. Dim text1_temp As String
  10. Dim t7 As String
  11. Private Sub Command2_Click()
  12. data1.Recordset.MovePrevious
  13. If data1.Recordset.BOF Then data1.Recordset.MoveFirst
  14. Text1.Text = data1.Recordset("卡號")
  15. Text2.Text = data1.Recordset("姓名")
  16. Text3.Text = data1.Recordset("班級")
  17. Text4.Text = data1.Recordset("余額")
  18. Text5.Text = data1.Recordset("日期")
  19. Text6.Text = data1.Recordset("時間")
  20. Text9.Text = Format(CStr(CStr((CSng(Text4.Text) * 100) \ 60)), "#00") & "小時" & Format(CStr(CStr((CSng(Text4.Text) * 100) Mod 60)), "#00") & " 分鐘"
  21. data1.UpdateRecord
  22. End Sub
  23. Private Sub Command3_Click()
  24. If data1.Recordset.EOF = False Then data1.Recordset.MoveNext
  25. If data1.Recordset.EOF Then data1.Recordset.MoveLast
  26. Text1.Text = data1.Recordset("卡號")
  27. Text2.Text = data1.Recordset("姓名")
  28. Text3.Text = data1.Recordset("班級")
  29. Text4.Text = data1.Recordset("余額")
  30. Text5.Text = data1.Recordset("日期")
  31. Text6.Text = data1.Recordset("時間")
  32. data1.UpdateRecord
  33. Text9.Text = Format(CStr(CStr((CSng(Text4.Text) * 100) \ 60)), "#00") & "小時" & Format(CStr(CStr((CSng(Text4.Text) * 100) Mod 60)), "#00") & " 分鐘"
  34. End Sub
  35. Sub 找卡號()
  36. Dim n, m As Integer
  37. data1.Refresh
  38. data1.Recordset.MoveLast
  39. m = data1.Recordset.RecordCount
  40. data1.Refresh
  41. data1.Recordset.MoveFirst
  42. For n = 1 To m Step 1
  43.     If Text1.Text = data1.Recordset("卡號") Then
  44.         Text1.Text = data1.Recordset("卡號")
  45.         'Text2.Text = data1.Recordset("姓名")
  46.         'Text3.Text = data1.Recordset("班級")
  47.     End If
  48.     data1.Recordset.MoveNext
  49. Next n
  50. End Sub
  51. Private Sub Command6_Click()
  52. Timer2.Enabled = True
  53. Command9.Enabled = True
  54. Command6.Enabled = False
  55. End Sub
  56. Private Sub Command7_Click()
  57. Text1.Text = ""
  58. Text2.Text = ""
  59. Text3.Text = ""
  60. Text4.Text = ""
  61. MSComm1.Output = "rr12345678" '把查詢命令發出到串口
  62. End Sub
  63. Private Sub Command8_Click()
  64. Dim NUM, n, m As Integer
  65. Call CACK_TEXT
  66. If TEXT_OK = True Then
  67.     NUM = Val(Text4.Text)
  68.     n = NUM \ 256
  69.     m = NUM - n * 256
  70.     'Call 寫入單片機
  71.
  72.     Call 寫入數據庫
  73.     text1_temp = Text1.Text
  74.     Text1.Text = ""
  75. Else
  76.     n = MsgBox("請正確輸入", 5 + vbExclamation, "錯誤")
  77. End If
  78. End Sub
  79. Sub 寫入單片機()
  80. Dim adsafdds As String
  81. Dim yuer1, yuer2 As String
  82. yuer1 = Format(CStr(CStr((CSng(Text4.Text) * 100) \ 60)), "#00")
  83. yuer2 = Format(CStr(CStr((CSng(Text4.Text) * 100) Mod 60)), "#00")
  84. adsafdds = "ss" & Text1.Text & yuer1 & yuer2
  85. MSComm1.Output = adsafdds
  86. End Sub
  87. Private Sub Command9_Click()
  88. Timer2.Enabled = False
  89. Command6.Enabled = True
  90. Command9.Enabled = False
  91. End Sub
  92. Private Sub Form_Load()
  93. MSComm1.PortOpen = True
  94. MSComm1.RThreshold = 1
  95. Command8.Enabled = False
  96. Command6.Enabled = True
  97. Command9.Enabled = False
  98. End Sub
  99. Sub CACK_TEXT()
  100. TEXT_OK = False
  101. If (Len(Text1.Text) = 4 And Len(Text4.Text) < 6) Then TEXT_OK = True
  102. End Sub
  103. Sub 寫入數據庫()
  104. data1.Refresh
  105. data1.Recordset.MoveLast
  106. data1.Recordset.AddNew
  107. data1.Recordset("卡號") = Text1.Text
  108. 'data1.Recordset("姓名") = Text2.Text
  109. 'data1.Recordset("班級") = Text3.Text
  110. data1.Recordset("余額") = Text4.Text
  111. data1.Recordset("日期") = Date
  112. data1.Recordset("時間") = Time()
  113. data1.UpdateRecord
  114. End Sub
  115. Private Sub MSComm1_OnComm() '串口中斷
  116. 'On Error Resume Next
  117. Static bFlag As Boolean
  118. Static Xbyte As Long
  119. Select Case MSComm1.CommEvent '選擇事件
  120. Case comEvReceive '接收到字符
  121. Dim I As Integer
  122.         Dim InByte() As Byte '定義一個二進制指針放接收到的數據
  123.         InByte = MSComm1.Input '數據轉移到指針
  124.         Dim j As Long
  125.         For j = 0 To UBound(InByte) '循環到指針上標
  126.
  127.             inData = inData & Chr(InByte(j)) '取出一個字節換為16進制顯示用
  128.
  129.         Next j
  130. DoEvents
  131.     Text1.SelText = inData '將剛收到的字符串顯示出來
  132.     inData = ""
  133. Text1.SelStart = Len(Text1.Text) '光標置后
  134.   If Len(Text1.Text) = 10 Then
  135.     Call 計算
  136.     'Call 找卡號
  137.   End If
  138. Case comEventRxOver '接收緩沖區滿的處理
  139. MsgBox "接收緩沖區滿了!" '發出警告
  140. End Select
  141. End Sub
  142. Sub 計算()
  143. Dim temp As String
  144. Dim 標志 As String
  145. Dim k As Integer
  146. Dim yuer1   As String
  147. Dim 余額    As Integer
  148. temp = Text1.Text
  149. 標志 = Left(temp, 1)
  150. temp = Right(temp, Len(temp) - 2)
  151. Select Case 標志
  152.     Case "s"
  153.         Text1.Text = Left(temp, 4)
  154.
  155.     Case "r"
  156.         Text1.Text = ""
  157.         MsgBox "寫卡成功!!!!!"
  158.         GoTo 計算end
  159.     Case Else
  160.         Text1.Text = ""
  161.         MsgBox "通訊有誤??????"
  162.         GoTo 計算end
  163. End Select
  164.     temp = Right(temp, 4)
  165.     Text9.Text = Left(temp, 2) & "小時" & Right(temp, 2) & "分鐘"
  166.     Text4.Text = Format(CStr((CSng(Left(temp, 2) * 60 + CSng(Right(temp, 2)))) / 100), "#00.00")
  167. 計算end:
  168.
  169. End Sub
  170. ……………………
  171. …………限于本文篇幅 余下代碼請從51黑下載附件…………
收藏收藏3 分享淘帖 頂 踩
ID:130231 發表于 2017-10-8 22:25 | 只看該作者
請教一下用什么單片機好。
ID:241242 發表于 2017-11-17 13:37 | 只看該作者
真是不錯
刷卡器和單片機連接,然后單片機再和VB通過串口連接嗎?
ID:252862 發表于 2017-11-25 16:20 | 只看該作者
正在學習IC卡的單片機和上位機通信,多謝分享。
