查看: 1838|回復: 0
紅外小車源代碼
ID:237486 發表于 2017-10-6 16:10 | 只看該作者 回帖獎勵 |倒序瀏覽 |閱讀模式
#include<reg52.h>
unsigned char zkb1=0 ;
//**左邊電機的占空比**//
unsigned char zkb2=0 ;
//**右邊電機的占空比**//
unsigned char t=0;
//**定時器中斷計數器**//
sbit LSEN1=P0^0;
sbit LSEN2=P0^1;
sbit MSEN1=P0^2;
sbit MSEN2=P0^3;
sbit RSEN1=P0^4;
sbit RSEN2=P0^5;
//**傳感器***/
sbit ENA=P1^5;
sbit IN1=P1^4;
sbit IN2=P1^3;
sbit IN3=P1^2;
sbit IN4=P1^1;
sbit ENB=P1^0;
//**********初始化定時器中斷***********//
void init()
        TMOD=0x01;
        TH0=(65536-10)/256;
        TL0=(65536-10)%256;
        EA=1;
        ET0=1;
        TR0=1;
//***********中斷函數+脈寬調制***********//
void timer0() interrupt 1
    if(t>=50)
      t=0;
    if(t<zkb1)
        ENA=1;
        ENA=0;
    if(t<zkb2)
        ENB=1;
        ENB=0;
    t++;
//******************直行******************//
void qianjin()
   zkb1=30;
   zkb2=30;
//***************小左轉函數***************//
void turn_left1()
{  zkb1=10;
   zkb2=25;
//***************中左轉函數***************//
void turn_left2()
{  zkb1=10;
   zkb2=20;
//***************大左轉函數***************//
void turn_left3()
{  zkb1=5;
   zkb2=25;
//***************小右轉函數***************//
void turn_right1()
{   zkb1=25;
   zkb2=10;
//***************中右轉函數***************//
void turn_right2()
   zkb1=20;
   zkb2=10;
//***************大右轉函數***************//
void turn_right3()
   zkb1=25;
   zkb2=5;
//***************循跡函數*****************//
void xunji()
      uchar flag;
      if((LSEN1==1)&&(LSEN2==1)&&(MSEN1==0)&&(MSEN2==0)&&(RSEN1==1)&&(RSEN2==1))
      { flag=0; }
//*******直行*******//
       if((LSEN1==1)&&(LSEN2==0)&&(MSEN1==0)&&((MSEN2==0)||(MSEN2==1))&&(RSEN1==1)&&(RSEN2==1))
      { flag=1; }
  //******小左轉*******//
       if((LSEN1==1)&&(LSEN2==1)&&((MSEN1==0)||(MSEN1==1))&&(MSEN2==0)&&(RSEN1==0)&&(RSEN2==1))
      { flag=2; }
  //******小右轉*******//
       if((LSEN1==0)&&(LSEN2==0)&&(MSEN1==0)&&((MSEN2==0)||(MSEN2==1))&&(RSEN1==1)&&(RSEN2==1))
      { flag=3; }
  //*******中左轉*******//
       if((LSEN1==1)&&(LSEN2==1)&&((MSEN1==0)||(MSEN1==1))&&(MSEN2==0)&&(RSEN1==0)&&(RSEN2==0))
      { flag=4; }
   //*******中右轉*******//
       if((LSEN1==0)&&((LSEN2==0)||(LSEN2==1))&&(MSEN1==1)&&(MSEN2==1)&&(RSEN1==1)&&(RSEN2==1))
      { flag=5; }
   //*******大左轉*******//
       if((LSEN1==1)&&(LSEN2==1)&&(MSEN1==1)&&(MSEN2==1)&&((RSEN1==0)||(RSEN1==1))&&(RSEN2==0))
      { flag=6; }
    //*******大右轉*******//
switch (flag)
        case 0:
          qianjin();
        break;
        case 1:
         turn_left1();
        break;
        case 2:
         turn_right1();
        break;
        case 3:
          turn_left2();
        break;
        case 4:
          turn_right2();
        break;
        case 5:
          turn_left3();
        break;
        case 6:
          turn_right3();
        break;
        default: break;
//****************主程序****************//
        init();
        zkb1=30;
        zkb2=30;
      qianjin();
