查看: 2212|回復(fù): 0
12864時鐘顯示,僅供參考
ID:235522 發(fā)表于 2017-9-25 16:12 | 顯示全部樓層 |閱讀模式
#include <reg52.h>
#define        ui unsigned int
#define        uc unsigned char
sbit cs2=P1^0;
sbit cs1=P1^1;
sbit e=P1^2;
sbit rw=P1^3;
sbit rs=P1^5;
sbit adcs=P3^0;
sbit adrd=P3^1;
sbit adwr=P3^2;
sbit eoc=P3^3;
sbit ada=P3^4;
ui tt,miao,shi,fen,shig,shis,feng,fens,miaos,miaog;
uc bclie,bcye,gew,shiw,baiw,gew1,shiw1,baiw1;
uc code hz[][32]=
/*--  文字:  北  --*/
/*--  楷體_GB231212;  此字體下對應(yīng)的點陣為:寬x高=16x16   --*/
0x00,0x00,0x40,0x40,0x40,0xFC,0x00,0x00,0xFE,0x80,0x40,0x60,0x20,0x00,0x00,0x00,
0x00,0x08,0x08,0x04,0x02,0x1F,0x00,0x00,0x0F,0x10,0x10,0x10,0x10,0x0E,0x00,0x00,
/*--  文字:  京  --*/
0x08,0x08,0x08,0x08,0xC8,0x48,0x49,0x2A,0x24,0xA4,0x64,0x04,0x04,0x04,0x00,0x00,
0x00,0x00,0x10,0x0C,0x00,0x01,0x21,0x7F,0x01,0x00,0x04,0x08,0x18,0x00,0x00,0x00,
/*--  文字:  時  --*/
0x00,0xF8,0x48,0x44,0xFC,0x00,0xA0,0x20,0x20,0x20,0xFE,0x10,0x10,0x10,0x00,0x00,
0x00,0x0F,0x04,0x04,0x0F,0x00,0x00,0x01,0x10,0x20,0x3F,0x00,0x00,0x00,0x00,0x00,
/*--  文字:  間  --*/
0x00,0x00,0xF8,0x02,0x04,0xE0,0xA4,0x14,0xF4,0x02,0x02,0x02,0xFE,0x00,0x00,0x00,
0x00,0x00,0x1F,0x00,0x00,0x07,0x02,0x02,0x07,0x00,0x10,0x20,0x1F,0x00,0x00,0x00,
uc code sz[][16]=
/*--  文字:  0  --*/
/*--  楷體_GB231212;  此字體下對應(yīng)的點陣為:寬x高=8x16   --*/
0x00,0x00,0xF0,0x08,0x08,0x18,0xE0,0x00,0x00,0x00,0x0F,0x10,0x20,0x10,0x0F,0x00,
/*--  文字:  1  --*/
0x00,0x00,0x10,0xF8,0x00,0x00,0x00,0x00,0x00,0x00,0x00,0x1F,0x10,0x00,0x00,0x00,
/*--  文字:  2  --*/
0x00,0x30,0x08,0x08,0x08,0xF8,0x00,0x00,0x00,0x00,0x18,0x14,0x13,0x10,0x08,0x00,
/*--  文字:  3  --*/
0x00,0x00,0x10,0x08,0x88,0x78,0x00,0x00,0x00,0x00,0x10,0x20,0x20,0x11,0x0E,0x00,
/*--  文字:  4  --*/
0x00,0x00,0xC0,0x20,0x10,0xF8,0x00,0x00,0x00,0x03,0x02,0x02,0x02,0x1F,0x02,0x00,
/*--  文字:  5  --*/
0x00,0x00,0x70,0x48,0xC8,0x88,0x00,0x00,0x00,0x10,0x10,0x20,0x10,0x0F,0x00,0x00,
/*--  文字:  6  --*/
0x00,0x00,0xE0,0x90,0x88,0x80,0x00,0x00,0x00,0x07,0x18,0x20,0x20,0x19,0x06,0x00,
/*--  文字:  7  --*/
0x00,0x10,0x08,0x08,0x88,0x78,0x00,0x00,0x00,0x00,0x00,0x18,0x07,0x00,0x00,0x00,
/*--  文字:  8  --*/
0x00,0x00,0x78,0x88,0x88,0x78,0x00,0x00,0x00,0x0C,0x12,0x21,0x21,0x1E,0x00,0x00,
/*--  文字:  9  --*/
0x00,0x60,0x98,0x08,0x08,0xF8,0xC0,0x00,0x00,0x00,0x21,0x12,0x09,0x07,0x00,0x00,
/*--  文字:  :  --*/
0x00,0xC0,0xC0,0x00,0x00,0x00,0x00,0x00,0x00,0x30,0x10,0x00,0x00,0x00,0x00,0x00,
void xml(uc ml)
        rs=0;
        rw=0;e=1;e=1;
        P2=ml;
        e=1;e=1;e=1;e=1;
        e=0;
void xsj(uc sj)
        rs=1;
        rw=0;e=1;e=1;
        P2=sj;
        e=1;e=1;e=1;e=1;
        e=0;
void qingp()
        uc i,j;
        cs1=cs2=1;
        for(i=0;i<8;i++)
                xml(0xb8+i);
                xml(0x40);
                for(j=0;j<64;j++)
                        xsj(0x00);
        cs1=cs2=0;
void csh()
        xml(0x3f);
        xml(0xc0);
        qingp();
void xhz(uc ye,lie,zi)
        uc i;
        bcye=ye;bclie=lie;
        if(lie<64)cs1=1,cs2=0;
        else cs1=0,cs2=1,lie=lie-64;
        xml(0xb8+ye);
        xml(0x40+lie);
        for(i=0;i<16;i++)
                if(lie+i<64)xsj(hz[zi][i]);
                        cs1=0;cs2=1;
                        xml(0xb8+ye);
                        xml(0x40+lie+i-64);
                        xsj(hz[zi][i]);
        ye=bcye;lie=bclie;
        xml(0xb8+ye+1);
        xml(0x40+lie);
        for(i=0;i<16;i++)
                if(lie+i<64)xsj(hz[zi][i+16]);
                        cs1=0;cs2=1;
                        xml(0xb8+ye+1);
                        xml(0x40+lie+i-64);
                        xsj(hz[zi][i+16]);
        P2=0xff;
void xsz(uc ye,lie,zi)
        uc i;
        bcye=ye;bclie=lie;
        xml(0xb8+ye);
        xml(0x40+lie);
        for(i=0;i<8;i++)
                if(lie+i<64)xsj(sz[zi][i]);
                        cs1=0;cs2=1;
                        xml(0xb8+ye);
                        xml(0x40+lie+i-64);
                        xsj(sz[zi][i]);
        ye=bcye;lie=bclie;
        xml(0xb8+ye+1);
        xml(0x40+lie);
        for(i=0;i<8;i++)
                if(lie+i<64)xsj(sz[zi][i+8]);
                        cs1=0;cs2=1;
                        xml(0xb8+ye+1);
                        xml(0x40+lie+i-64);
                        xsj(sz[zi][i+8]);
        P2=0xff;
        csh();
                miaog=miao/1%10;
                miaos=miao/10%10;
                feng=fen/1%10;
                fens=fen/10%10;
                shig=shi/1%10;
                shis=shi/10%10;
                TMOD=0x11;
                TH0=(-5000)/256;
                TL0=(-5000)%256;
                TR0=1;ET0=1;EA=1;
                xhz(2,32,0);
                xhz(2,48,1);
                xhz(2,64,2);
                xhz(2,80,3);
                xsz(4,32,shis);
                xsz(4,40,shig);
                xsz(4,48,10);//
                xsz(4,56,fens);
                xsz(4,64,feng);
                xsz(4,72,10);//
                xsz(4,80,miaos);
                xsz(4,88,miaog);
void time0() interrupt 1
        TH0=(-5000)/256;
        TL0=(-5000)%256;
        tt++;
        if(tt==200)
                tt=0;
                miao++;
                if(miao==60)
                        miao=0;
                        fen++;
                        if(fen==60)
                                fen=0;
                                shi++;
                                if(shi==24)shi=0;
