#include<reg52.h>
#include<stdio.h>
#define THC0 0xf8
#define TLC0 0xcc //2ms
unsigned char code Duan[]={0x3F,0x06,0x5B,0x4F,0x66,0x6D,0x7D,0x07,0x7F,0x6F};//共陰極數(shù)碼管,0-9段碼表
unsigned char Data_Buffer[8]={0,0,0,0,0,0,0,0};
unsigned char Data[4]={0,0,0,0};
unsigned char Arry[4]={0,0,0,0};
bit flag1=0;
bit flag0=0;
uchar i=0;
sbit AddSpeed=P1^1;
sbit SubSpeed=P1^2;
sbit PWM_FC=P1^0;
int e=0,e1=0,e2=0; //pid 偏差
float uk=0,uk1=0.0,duk=0.0; //pid輸出值
float Kp=5,Ki=1.5,Kd=0.9; //pid控制系數(shù)
//float Kp=10;
int out=0;
uint SpeedSet=1000;
uint cnt=0;
uint Inpluse=0,num=0; //脈沖計(jì)數(shù)
uint PWMTime=0; //脈沖寬度
unsigned char arry[];
void SendString(uint ch);
void PIDControl();
void SystemInit();
void delay(uchar x);
void PWMOUT();
void SetSpeed();
void SegRefre();
/**************主函數(shù)************/
SystemInit();//系統(tǒng)初始化
SetSpeed();//設(shè)置速度
SegRefre();//更新數(shù)碼管顯示
PWMOUT(); //PWM輸出
if(flag0==1)
flag0=0;
ES=0;//關(guān)串口中斷,避免TI引起串口中斷
TI=1;//printf前TI置1
printf("%f",(float)(num>>8));//脈沖計(jì)數(shù)
printf("%f",(float)num); //脈沖計(jì)數(shù)
while(!TI);
TI=0; //TI軟件清除
ES=1; //允許串口中斷
//PID偏差控制計(jì)算
void PIDControl() //pid偏差計(jì)算
e=SpeedSet-num;//設(shè)置速度-實(shí)際速度,兩者的差值
//對(duì)應(yīng)于增量式PID的公式Δuk=uk-u(k-1)
// duk=(Kp*(e-e1))/100;//只調(diào)節(jié)P
duk=(Kp*(e-e1)+Ki*e)/100;//只調(diào)節(jié)PI
// duk=(Kp*(e-e1)+Ki*e+Kd*(e-2*e1+e2))/100;//調(diào)節(jié)PID
uk=uk1+duk;//uk=u(k-1)+Δuk
out=(int)uk;//取整后輸出
if(out>250) //設(shè)置最大限制
out=250;
else if(out<0)//設(shè)置最小限制
out=0;
uk1=uk; //為下一次增量做準(zhǔn)備
e2=e1;
e1=e;
PWMTime=out; //out對(duì)應(yīng)于PWM高電平的時(shí)間
//較短的延時(shí)。注意delay的值不要超過(guò)255
void delay(uchar x)
uchar i,j;
for(i=x;i>0;i--)
for(j=50;j>0;j--);//接近500us
//PWM輸出
void PWMOUT()
if(cnt<PWMTime)//若小于PWM的設(shè)定時(shí)間,則輸出高電平
PWM_FC=1;
else //否則輸出低電平
PWM_FC=0;
if(cnt>250) //超過(guò)限制清零
cnt=0;
//系統(tǒng)初始化
void SystemInit()
TMOD=0X21; //T1用于串口的波特率發(fā)生器 T0用于定時(shí)
TH0=THC0; //2ms定時(shí),晶振頻率是11.0592MHz,事先算好裝入THC0中
TL0=TLC0; //2ms定時(shí),晶振頻率是11.0592MHz,實(shí)現(xiàn)算好裝入TLCO中
ET0=1; //允許定時(shí)器0中斷
TR0=1; //啟動(dòng)定時(shí)器0
EX0=1; //允許外部中斷
IT0=1; //中斷方式設(shè)置為下降沿
//用于串口調(diào)試時(shí)用
PCON=0x00; //SMOD不加倍
SCON=0x50; //串口工作方式1,允許接收
TH1=0xfd; //波特率9600
TL1=0xfd; //波特率9600
TR1=1; //啟動(dòng)定時(shí)器1
ES=1; //開(kāi)串口中斷
EA=1; //開(kāi)總中斷
e =0; //PID的差值初值均為0
e1=0;
e2=0;
//設(shè)置轉(zhuǎn)速
void SetSpeed()
if(AddSpeed==0)//按鍵
delay(200);//消抖
if(AddSpeed==0)//再次判斷按鍵
SpeedSet+=100;//速度增加
if(SpeedSet>9999)//超限
SpeedSet=9999;//設(shè)置為最大9999
if(SubSpeed==0)//按鍵
delay(200);//消抖
if(SubSpeed==0)//按鍵
SpeedSet-=100;//速度減
if(SpeedSet<0)//低于速度的最小值
SpeedSet=0;//速度置零
//數(shù)碼管顯示更新
void SegRefre() //顯示刷新
Data_Buffer[0]=SpeedSet/1000;
Data_Buffer[1]=SpeedSet%1000/100;
Data_Buffer[2]=SpeedSet%100/10;
Data_Buffer[3]=SpeedSet%10;
Data_Buffer[4]=num/1000;
Data_Buffer[5]=num%1000/100;
Data_Buffer[6]=num%100/10;
Data_Buffer[7]=num%10;
//外部中斷,統(tǒng)計(jì)脈沖數(shù)目,實(shí)際上是統(tǒng)計(jì)電機(jī)的轉(zhuǎn)速
//在實(shí)際中,電機(jī)沒(méi)有一根線引出來(lái)可以表示他的轉(zhuǎn)速,只能通過(guò)傳感器如霍爾傳感器的方式測(cè)量轉(zhuǎn)速
//脈沖一次下降沿對(duì)應(yīng)于一次自增
void int0() interrupt 0
Inpluse++;
//定時(shí)器T0操作
void t0() interrupt 1
static unsigned char Bit=0;//靜態(tài)變量,退出程序值保留
static unsigned int time=0;
static unsigned int aa=0;
TH0=THC0;//重新賦初值
TL0=TLC0;
aa++;
if(aa==50)//每100ms
aa=0;
flag0=1;
cnt++; //pid 周期
Bit++;
time++; //轉(zhuǎn)速測(cè)量周期
if(Bit>8) Bit=0;//數(shù)碼管總共只有8位,超過(guò)8位則在程序上進(jìn)行清零
//數(shù)碼管顯示部分
P0=0xff;
P2=Duan[Data_Buffer[Bit]];
switch(Bit)
case 0:P0=0X7F;break;
case 1:P0=0XBF;break;
case 2:P0=0XDF;break;
case 3:P0=0XEF;break;
case 4:P0=0XF7;break;
case 5:P0=0XFB;break;
case 6:P0=0XFD;break;
case 7:P0=0XFE;break;
//數(shù)碼管顯示部分
if(time>500)//每1s處理一次脈沖
time=0;
num=Inpluse*15;//實(shí)際轉(zhuǎn)速,*15是由電機(jī)決定的,電機(jī)的一個(gè)脈沖對(duì)應(yīng)著電機(jī)轉(zhuǎn)過(guò)了15轉(zhuǎn)
Inpluse=0; //清零,為下一次計(jì)數(shù)做準(zhǔn)備
PIDControl(); //調(diào)用PID控制程序
//串口中斷,用于對(duì)串口的數(shù)據(jù)進(jìn)行處理
void u_int(void) interrupt 4
ES=0;//關(guān)串口中斷,避免在數(shù)據(jù)處理的過(guò)程中造成影響
if(RI)//若有RI==1,由RI產(chǎn)生中斷
RI=0;//RI標(biāo)志位必須通過(guò)軟件進(jìn)行清零
arry[i]=SBUF;//將字符賦到arry中
i++; //下一個(gè)數(shù)
if(i>3) //接收完了指令,進(jìn)行數(shù)據(jù)處理,一共有arry[0],arry[1],arry[2],arry[3]四個(gè)數(shù)據(jù)
flag1=1;//將標(biāo)志置1
i=0; //i清零,重新計(jì)數(shù)
if(flag1) //若flag1==1
flag1=0;//flag1清零
SpeedSet=(arry[0]-'0')+(arry[1]-'0')*10+(arry[2]-'0')*100+(arry[3]-'0')*1000;//獲得的速度值
//由于串口發(fā)送的是字符,所以要減去'0'
else//對(duì)應(yīng)的由TI產(chǎn)生中斷
TI=0;//TI由軟件進(jìn)行清零
ES=1;//處理完后再開(kāi)中斷
PID自動(dòng)控速.zip
2017-9-24 16:41 上傳
點(diǎn)擊文件名下載附件
下載積分: 黑幣 -5
53.95 KB, 下載次數(shù): 76, 下載積分: 黑幣 -5
PID自動(dòng)控速
